Need help finding a main jet
StickyNick
PostPosted: 20:53 - 05 May 2008    Post subject: Need help finding a main jet Reply with quote
My shitty Piaggio NRG needs a new main jet because it's fucking up spark plugs like there's no tomorrow, but nowhere in my local area has any with a thread to match the one I have.
Does anyone know of anywhere online where I could get one? and whether I gotta get a smaller or larger jet?
Cheers.
Riding a 2001 Piaggio NRG MC3 DT (Well, would be if it worked right now)
Saving for Yamaha YZF-R125 Very Happy
2006 _p1
PostPosted: 20:56 - 05 May 2008    Post subject: Reply with quote
Tryed adjusting the air/fuel mixture?
StickyNick
PostPosted: 20:59 - 05 May 2008    Post subject: Reply with quote
Nah, how do i do that? I'm getting pretty desperate here Smile
Forgot to mention it needs to be for a Weber carb.
2006 _p1
PostPosted: 21:22 - 05 May 2008    Post subject: Reply with quote
There should be a screw on your carb adjust untill your spark plug looks like thishttps://www.lambretta.co.uk/downloads/image/plugyes.jpg
That should sort out your problem.
If your scooter has a air/fuel mixture screw?
StickyNick
PostPosted: 21:28 - 05 May 2008    Post subject: Reply with quote
My mate played with a screw that changed what it was like when the scooter was sitting idle? Is it the same 1?
2006 _p1
PostPosted: 21:35 - 05 May 2008    Post subject: Reply with quote
I think you have found the idle screw!
StickyNick
PostPosted: 21:38 - 05 May 2008    Post subject: Reply with quote
I have no idea what's what, it's him that plays with it not me Laughing
Is this the right one or not?
and if it makes any difference or even matters, the circled part is black on the plugs...
https://i242.photobucket.com/albums/ff114/nickmccann/plug.jpg
alains
PostPosted: 22:50 - 05 May 2008    Post subject: Reply with quote
the colour is pretty good for me , compare with that
https://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
StickyNick
PostPosted: 13:08 - 06 May 2008    Post subject: Reply with quote
That isn't my plug, i'm just showing which bit is black on mine.
And I found the air/fuel mixture screw, gonna fuck around with it when my hand's out of plaster Smile
2006 _p1
PostPosted: 13:22 - 06 May 2008    Post subject: Reply with quote
If its black you need to lean it up.
alains
PostPosted: 13:30 - 06 May 2008    Post subject: Reply with quote
dont be confused between oil fouled and too rich
PostPosted: 13:34 - 06 May 2008    Post subject: Reply with quote
Mixture screw affects idle mixture. Will not change the mixture when you are using any throttle at all. The main jet only affects full throttle mixture (and there are a lot of factors rather than just the thread size, different carb makers, or even different series of carbs from the same maker, mark the jet sizes differently). Needle jet is what affects the mixture through most of the throttle range.
To go with Alains comment, none of the jets should wear and leaning it off too much stands a good chance of resulting in a seizure.
The last post was made 18 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1 - MySQL Queries: 13 - Page Size: 71.26 Kb
