Torque Wrench Appeal
Bofh5
PostPosted: 19:49 - 07 May 2008    Post subject: Torque Wrench Appeal Reply with quote
Hi all
Need to change my clutch at the weekend and need a torque wrench. Bought one on ebay but just found out it hasn't been posted yet !!! Argghh
Anyone in the Reading area know where i can hire one or have one i can borrow for a couple of hours ?
Tried HSS but they don't have them, local garages told me to sod off and i can't think of anywhere else.
Thanks
Jon
(L)users...Disk space is to good for them.
Bikes: Honda 50 / CB125-TDC / 93 CBR600 F2 (Stolen & Trashed) / 2001 SP-1 (Sold) / 95 CBR600 F3
PostPosted: 20:04 - 07 May 2008    Post subject: Reply with quote
I've changed quite a few motorcycle clutches and I've never used a torque wrench to do it.
If you can both hold a clutch basket still and put enough pressure on the bolts to shear them, you're a better man than I.
Bofh5
PostPosted: 20:12 - 07 May 2008    Post subject: Reply with quote
Its the clutch plate spring bolts that need to be tightened to 9 lb/ft
Is it ok just to tighten them using your judgement ?
I don't want to shear the bolt off.
edit: just reread your post so plz ignore
andi
PostPosted: 21:11 - 07 May 2008    Post subject: Reply with quote
am fairly close and available Sat afternoon and all day sunday. Thumbs Up Got a wrench too Laughing
Before: Suzuki GT 185. Honda Superdream 250. Yamaha RD350LC. Suziki RG250. Yamaha FZS600. Honda CBR600F3
Now: Honda Fireblade 929
Faldo
PostPosted: 21:21 - 07 May 2008    Post subject: Reply with quote
I bought one from Machine Mart the other day for approx £16 quid. Not really worth hiring one is it?
Clicky
Current: ZZR1400
PostPosted: 21:43 - 07 May 2008    Post subject: Reply with quote
Halfords will have them.
Screwfix will have them.
Maplins will have them.
Drews will have them.
But as said, you don't need one for changing the clutch. Smile
PostPosted: 22:39 - 07 May 2008    Post subject: Reply with quote
I am in Reading and also have them - but my one that goes that low is a bit knackered if I remember, so you'd probably be as well doing it up by hand Smile.
You're welcome to borrow it if you want, though.
Incidentally, Argos sell an 'ok' one too the last time I checked.
Bofh5
PostPosted: 01:04 - 08 May 2008    Post subject: Reply with quote
Thanks everyone for your support with this.
Sods law that the one i bought won't arrive in time but guess thats life.....
If i don't use a torque wrench how tight do you need to do them ?
I've read thats its about a quarter of a turn past finger tight but not sure about that.
G - Providing the plates turn up then i'll take you up on your offer if it starts looking dodgy as your the closest to me.
Haven't done a bike clutch since my first 125 many many years ago so can't really remember it so i'll see how it goes.
Thanks again i really appreciate all your support
PostPosted: 07:14 - 08 May 2008    Post subject: Reply with quote
Many torque wrences won't go that low.
The tightening torque on the clutch spring bolts have no bearing whatsoever on the clamping-pressure of the springs, if that's what you're worried about - the spring tension is set by the installed height, which is determined by the amount of clutch wear. They are just normal bolts in every way. You should tighten them just like any other ordinary bolt, with a dab of Loctite Blue on the threads.
P.S. If you tighten the bolts by hand with a ratchet, chances are they will be higher than 9 foot-pounds - you'll be surprised how little is it.
PostPosted: 08:33 - 08 May 2008    Post subject: Reply with quote
As Geri says - you're tightening to metal-on-metal, not tightening against the spring.
I'll try and dig mine out (and check it does go that low; though pretty sure it /just/ did for my 3/8" one - the 1/2" one starts at 29Nm).
Bofh5
PostPosted: 11:30 - 08 May 2008    Post subject: Reply with quote
Ok so common sense then. Just enough till it feels right.
Sounds good. probably just being paranoid over this.
Thanks all i'll let you know how it goes.
Jon
Ravo
PostPosted: 15:42 - 08 May 2008    Post subject: Reply with quote
I'd say go out to a real store and buy a nice one. The odds have it if you needed one this time you'll need it again in the future.
PostPosted: 16:50 - 08 May 2008    Post subject: Reply with quote
Jon
You'll be taking them off first so put them back on something similar.
9ft/lb is not at all tight, probably about as tight as you can get them using one finger on a 3/8" drive ratchet handle. At a guess, something like screwed all the way in then add another 1/4 turn.
Ravo
PostPosted: 17:05 - 08 May 2008    Post subject: Reply with quote
That, good sir, is EXACTLY what we do for oil filters; which makes it a good reference for how tight that would be.
PostPosted: 17:11 - 08 May 2008    Post subject: Reply with quote
Reasonably good but not exact because air filters have a fine pitch thread, the torque on clutch bolts (corse pitch) will be higher for the same amount of turning.
The last post was made 18 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 86.27 Kb
