Question about NSR models and carbs?
Leviathan
PostPosted: 16:01 - 08 May 2008    Post subject: Question about NSR models and carbs? Reply with quote
well basically im led to believe older models were supposed to be faster and i believe i was told this was achieved from larger ports on the barrel, and possibly a larger carb?
i was just wondering if anyone would like to put some light on the truth, and how exactly a wider carb helps performance where as the jets stay the same? and more importantly why using larger carbs are so risky.
not to sound like a fool, but to be honest its always interested me as to how we know where the limits of what combustion an engine can take, how an engine can combust for so long with a standard carb, but with a bigger input of more fuel can just make it seize?
2006 _p1
PostPosted: 17:10 - 08 May 2008    Post subject: Re: Question about NSR models and carbs? Reply with quote
Well wider carb lets more air and fuel in and some goes for the ports!
Welshd1k
PostPosted: 17:22 - 08 May 2008    Post subject: Reply with quote
lies ..........
older nsr's or ns's as they where called are slower than nsr's
they have a 26mm card where as all the newer nsr's have 28mm delorto carbs
and if i am correct all the heads' barrels are teh same on the nsr's 91 onwards?
Thom
PostPosted: 17:24 - 08 May 2008    Post subject: Reply with quote
ns125r is different to an nsr125 just so you know...
Welshd1k
PostPosted: 17:52 - 08 May 2008    Post subject: Reply with quote
oh really ... Rolling Eyes
what with the ns125 havign a 18" rear and 16" ??
or teh ns125 beign a kick start
or the ns125 not having a powervalve (some have teh atac valve)
or the small fact that the engines are TOTALY different
best one is teh ns poston has hole sin the skirts the nsr doesnt
i was only sayign that as most people call the ns's nsr's
as he said earlier nsr's so ...
Leviathan
PostPosted: 19:40 - 08 May 2008    Post subject: Reply with quote
yea i was looking for information based on the progress of the ns/nsr generally because im confused as to how an RS125 say can have a 34mm carb and still not explode....well...when i say wont explode you kno what i mean lol
cheers G.
PostPosted: 19:47 - 08 May 2008    Post subject: Reply with quote
RS is in a higher state of tune. A carb alone doesn't so much give you performance, more supply fuel and air adequate for the performance. If the rest of the engine can produce more power than that size of carb can flow the mixture for then you loose power.
The RS125 34mm carb runs far larger jets than the 28mm carb fitted to other RS125s.
Larger carb is a bit of a double edged sword. While they does supply mixture for the higher power output they will also tend to have more problems at lower engine speed.
Leviathan
PostPosted: 21:10 - 08 May 2008    Post subject: Reply with quote
i see, but what confuses my small brain is that how does the RS pull it in wheras the nsr obviously cant but the cc is still the same, the only thing i can assume this is down to parts with less friction and maybe the higher compression to suck it all in, i was led to believe the higher cc meant the more ability to suck in more fuel and compress it further and then bash it down faster with more power? please correct me if im wrong kickstart you seem to have a much better understanding of this than i do lol
cheers fellas for your help,
Leviathan
PostPosted: 21:18 - 08 May 2008    Post subject: Reply with quote
and so in theory putting a huge carb into a little engine would give better performance (i assume this from a mate of mine who put a 35mm carb on a mito, it ran like shit off a shovel but blew up shortly after) but then how is this possible without flooding? or a painfull de crease in performance as you pack on the accelerator?
and this is why i get confused lol,
so many terms and so many possibilitys,
it is a fine science but learning how something works gives me a better understanding of how to take care of it better lol
cheers,
PostPosted: 22:17 - 08 May 2008    Post subject: Reply with quote
No, a huge carb alone will do nothing. A larger carb will support an engine that is capable of producing more power, but will likely loose lower down power.
The larger the carb for an engine size then the lower the air speed through it, so less pressure drop which means it doesn't atomise the fuel as well. At higher engine speeds the gas speed is high enough. Hence you can land up with an engine that may make a bit more power but the loss of low down power makes it feel like it is making quite a lot more power.
Anyway, as such the size of carb on an engine is a compromise. And depending on the maker they may have already gone for as larger a carb as will work effectively on the engine. Or they might have used a smaller carb and lost nothing at the top end, or smaller again and lost some top end.
With fitting a larger carb yourself you then have all the fun of trying to get the jetting at least close to correct. And the makers have a lot more experience and equipment to get this right than most people do.
Leviathan
PostPosted: 12:01 - 09 May 2008    Post subject: Reply with quote
i see so am i right in thinking the pressure from the downwards piston action has to really suck the fuel past the jets or it wont enter the cylinder in the correct er... consistancy?
this is beggining to make sense, and i can see what your saying, so bogging down will happen in lower revs because there is less of a force present?
the only thing left to clear up is how my mates mito managed to pull it off, would you say the mito is just capable of doing more with its compression? and does that have something to do with the mito having a piston size slightly bigger than the nsr? or am i on a totally different page lol,
cheers kickstart, hows it going by the way mate?
PostPosted: 13:37 - 09 May 2008    Post subject: Reply with quote
Essentially yes. Carb provides a slight restriction, which causes the air speed to increase. Higher speed air lands up at a lower pressure and this results in fuel being drawn from the float bowl into the air stream (technically the atmospheric pressure pushes the fuel into the lower pressure airstream in the carb). Large carb at low revs and there is very little pressure drop so the carb works poorly at drawing the fuel into the airflow.
Same basic principle that an aircraft wing uses, but with a wing the air going round the top has further to go than that around the bottom, so the air on the top travels faster, hence lower pressure.
Basically yes. Also one reason why with slide carbs you need to open them progressively, rather than just yanking them fully open at low revs (and why CV carbs where the slide is also operated by air pressure is a lot more idiot proof).
[/quote]
Same as the RS125. A 34mm / 35mm carb is within reason for the rest of the engine. But the Mito / RS have more radical port timing, ignition timing, exhaust design, etc, enabling them to take perform better with a larger carb.
Leviathan
PostPosted: 00:19 - 10 May 2008    Post subject: Reply with quote
exellent thank you kickstart, thats some useful information, so ramming a huge carb isnt ever such a good idea, from what i had gathered before this post was that if you rammed as much fuel and air into the cylinder you get better performance which isnt really the case, althou maybe the case in superchargers lol. doesnt quite work for a 125 2 stroke!
cheers,
PostPosted: 22:08 - 11 May 2008    Post subject: Reply with quote
Larger carb might be necessary to take advantage of other engine mods. It is all a compromise.
Basically it is true that the more fuel / air you ram into the cylinder the more power you will get. But a carb doesn't really do that, it just allows in the fuel / air demanded by the engine up to a limit. You can use a larger carb to raise that limit, but if the engine cannot draw in more mixture it is a waste, and you will likely loose out at the bottom end.
Leviathan
PostPosted: 12:31 - 12 May 2008    Post subject: Reply with quote
ah, right now i see where iv been getting confused, i was under the impression that the carb would allow for extra fuel intake as the jets got wider (which i assume it still does) but what i didnt realise was that the engine is the limiter(which is what you were saying all along), the limit is when the piston stops moving down drawing the fuel in and returns to compress it, the idea of turbo chargers and super chargers are quite impressive, yet obviously you need an engine that can afford to compromise... its a shame that they dont make small ones for a laugh.
anyway cheers for that, at last finally i have got there.
cheers,
PostPosted: 12:42 - 12 May 2008    Post subject: Reply with quote
Trouble with both superchargers and turbochargers (well, technically a turbocharger is a type of supercharger) is that they take power to drive them. With a turbo this means that you likely loose a load of power at low revs and gain some at high revs, but also give it a trickier to control throttle response (ie, you open the throttle, the engine responds to that, the turbo gets speeded up by the engine waking up and then that shoves more fuel / air into the engine).
Carb jets flow fuel, and the size of the jets affects how much fuel they flow, but you need the air to go with them. Fuel air ratio should be around 14 parts air to 1 part fuel (by weight, not volume), but you have advantages running it a bit either side of that. Bit more fuel and you get more power, bit less fuel and you can reduce fuel consumption (at the expense of emissions of oxides of nitrogen going through the roof).
However it isn't only the size of the jets that affects the fuel they flow. As mentioned earlier the carb works by the pressure difference between the air going through an atmospheric pressure (basically the atmospheric pressure presses on the fuel in the float bowl). If you do something strange then this can have odd effects. For example full throttle on a slide carb at low revs and the air pressure through the carb will be barely lower than atmospheric pressure, hence barely any fuel gets pushed into the fuel / air mix going to the engine.
Worse than that run a wrongly designed turbo setup and you will pressurise the air going into the engine, and land up with it at a higher pressure than the air pushing on the fuel in the float bowl. Hence no fuel goes to the engine.
Leviathan
PostPosted: 16:43 - 12 May 2008    Post subject: Reply with quote
actually i didnt know that lol,
so if you dont mind me asking, why dont turbo chargers and superchargers come in like powervalves, engage when the engine is up to speed?
and so with the air filters does that mean say a huge air filter or no filter at all (excluding enviromental conditions) would perform badly because the suction would be drawn from the air instead of the float chamber? or is there some kind of force stoping this that im not taking into account?
cheers for the information,
PostPosted: 16:51 - 12 May 2008    Post subject: Reply with quote
Not sure if can really be done with a turbo reliably. There are electric superchargers designed to run in parallel with turbos to provide boost while the turbo spins up (mainly intended for diesel buses). It can be done with a supercharger, but superchargers tend not to have an issue at low revs just that at high revs they struggle more (and are also harder to engineer).
No. The air goes through the carb and has a slight restriction which causes it to speed up. Faster moving air has a lower pressure and it is this that draws the fuel up from the float bowl, not the suction of the engine.
You basically want the largest air filter you can have to provide the least restriction (ironically the tea strainer things you sometimes see are likely to be very bad as a restriction as well as not filtering out much rubbish).
Leviathan
PostPosted: 10:10 - 13 May 2008    Post subject: Reply with quote
lol, so the engine doesnt actually use suction pressure to move the fuel in alone? it s the air that sucks the fuel in using the atmospheric pressure? i mean how do airplane engines work at high altitude where pressure changes?
that makes alot of sense, at a guess id say thats the best way to make sure the fuel is regulated and mixed with the air as it enters the cylinder, but what just occured to me is that that a i thought a small or blocked air filter would cause the engine to run rich,
how does that work when the fuel is drawed in by the air passing?
cheers kickstart im slowly getting there,
Leviathan
PostPosted: 10:16 - 13 May 2008    Post subject: Reply with quote
lol, sorry i have another question,
so am i right in thinking the carb restriction is the diameter of the carb itself? seeing as the end of the carb where the air filter goes on is big, and the other end going into the manifold of the engine tents to be smaller?
hope im getting somewhere lol,
cheers,
PostPosted: 10:22 - 13 May 2008    Post subject: Reply with quote
Yep. The engine sucks the air in (technically the engine provides a low pressure and atmospheric pressure pushes the air in, but that is just semantics). The speed of the ari being sucked in provides a lower pressure to draw the fuel into the intake air (because the fuel is between the higher atmospheric pressure in the float bowl and the lower pressure air going through the carb).
The float bowl is vented to the atmosphere. However although the air pressure is lower, so is the pressure of the air flowing through the carb. The actual pressure is not as important as the pressure difference.
However it has to be said that carbs do not cope well with changes in atmospheric pressure.
The air passing at speed is lower pressure (due to its speed). However there are other ways to lower pressure. The engine can cause a low pressure area on its own, just by suction, but the rich mixture that would cause when you have a blocked air filter is the least of your problems (as you would also have virtually no air).
Leviathan
PostPosted: 10:40 - 13 May 2008    Post subject: Reply with quote
right exellent, i think i get it now, its amazing how much technology went into carbs and for them to change the system completely with injectors etc.
but this sorta stuff isnt covered in a haynes manual lol,
where did you get all this knowledge anyway kickstart??
cheers,
PostPosted: 11:24 - 13 May 2008    Post subject: Reply with quote
Too much reading over too many years.
In many ways electronic fuel injection is simpler than carbs.
Mechanical fuel injection seem to land up being very complicated.
The last post was made 17 years, 230 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.37 - MySQL Queries: 13 - Page Size: 131.53 Kb
