1200 bandit cutting out
bb210
PostPosted: 18:31 - 08 May 2008    Post subject: 1200 bandit cutting out Reply with quote
Hope someone can help ?
ive got a 1200 bandit (96) that cuts out when i stop but only if you put the brakes on, doesnt matter which one it will also do it if i just push the bike forward (out of gear) & apply a brake, ive checked the wiring & cant find any loose connections or chaffed wires the bikes standerd apart froma micron legal carbon can & k&n, it doesnt matter if the fuel tanks full or empty any ideas ?
MaybeGuy
PostPosted: 18:38 - 08 May 2008    Post subject: Reply with quote
it could be a shagged battery.
at idle, theres probably enough power from the alternator to power the sparks. if the battery is failing, applying the brakes will draw more power to light up the brake light.
does it do it if you flick the lights on?
StealthDJ
PostPosted: 18:59 - 08 May 2008    Post subject: Reply with quote
Was about to say that I'd be looking for a short in the live supply to the brake light, but if it's not blowing fuses then I wouldn't be sure.
If you have a wiring diagram, does the brake light have an earth in common with either the CDI or coils? If so, check and clean that connection - if it's bad, it could be trying to use either of the two as an earth, which would essentially cut the ignition.
The best way to tell which side of the bulb the problem is on would be to remove the bulb and see if the problem persists. If it does, it's on the live side. If not, it's the earth side.
Current garage: VFR800 FI-W | RD500LC YPVS | SV650 K2 | MZ TS250/1 | MZ ETZ251 | BSA WDB40
Previous notables: H100 S2 | CB250NA/B | CB250T | GT250X7 | Z650 B1 | SR650
Still owned, but long gone: RD250LC | CB750F2 SOHC | C50
bb210
PostPosted: 19:01 - 08 May 2008    Post subject: Reply with quote
Batts only a few months old & i can put lights indicaters on & brake light on when at stand still & it ticks over fine
bb210
PostPosted: 19:13 - 08 May 2008    Post subject: Reply with quote
Its nota probwith the brake light either because even with it disconnected it still happens
PostPosted: 19:19 - 08 May 2008    Post subject: Reply with quote
From what you say it is the sudden stop that it killing the engine, rather than the electrical load issue.
Only things I can think of are a wire shorting out under those circumstances (eg, wire to the side stand switch, or the stand moving the switch) or more likely the carbs flooding into the engine (possibly a sticking or dirty carb needle valve).
bb210
PostPosted: 19:29 - 08 May 2008    Post subject: Reply with quote
i did check the side stand but maybe its worth another check & i did think it might be a fuel prob so if iget time this wkend i might strip the carbs down because mpg's not brill either
finpos
PostPosted: 19:46 - 08 May 2008    Post subject: Reply with quote
Check the side stand again - you might find it's swinging down slightly when you come to a sudden stop and doing that means the sidestand switch becomes activated and that kills the engine.
f.
MaybeGuy
PostPosted: 20:35 - 08 May 2008    Post subject: Reply with quote
you dont have electric ABS do you?
bb210
PostPosted: 21:55 - 08 May 2008    Post subject: Reply with quote
abs wasnt an option on early bandits & just thought it cant be the side stand cut out because it happens even when bike is in neutral !
finpos
PostPosted: 22:30 - 08 May 2008    Post subject: Reply with quote
...I'm at least 80% certain suzukis of that age have only the kill, clutch and sidestand swiches in the engine cutout circuit. i.e. neutral makes no difference.
f.
The last post was made 18 years, 176 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 66.76 Kb
