brake cleaner
cearnshaw
PostPosted: 21:54 - 09 May 2008    Post subject: brake cleaner Reply with quote
is it OK to blast into the caliper with pads in place or do you need to take everything apart? TA
Honda XR 125, 2007 Bandit 650
TUG
PostPosted: 21:56 - 09 May 2008    Post subject: Reply with quote
Um, if it was me i would take the pads out to clean the pistons propperly by pumping them out a little bit but that depends how far out they are already, if there on the end of their stroke dont pump them out at all and just clean em with a tooth brush etc. Am unsure it will soak into the pads so cant comment on keeping them in.
Haz ER-5, innit!
alien.46.uk
PostPosted: 22:53 - 09 May 2008    Post subject: Reply with quote
Take the callipers off their mounts, stick a spanner or screw driver between the pads, pump the pistons out then use the cleaner and a tooth brush to give them a spruce, should only take an hour tops.
2007 Kawasaki ZX10R :: 1998 Kawasaki ZX-9R - SOLD
1998 Yamaha FZS600 Fazer - SOLD :: 1994 Aprilia Pegaso 125 - SOLD
Pie-Roe
PostPosted: 09:37 - 10 May 2008    Post subject: Reply with quote
I regularly give mine a quick shimmy of the can of cleaner. Although now I wear glasses, since when I was doing my front's the other month, it sprayed off, hit me in the eye and caused to cry uncontrollably for over 2 hours.
Nasty shizzle
Pyro
The last post was made 18 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.88 - MySQL Queries: 13 - Page Size: 39.21 Kb
