| R6_Rider |
 R6_Rider Nitrous Nuisance
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 09:46 - 13 May 2008 Post subject: |
Prime is meant to be used to fill the carbs after you've had them off(it doesn't need a vacuum to push the fuel through), so I guess it could make it run rather funny.
Try it with "on" and see what happens. ____________________ My Flickr |
| R6_Rider |
| Vincent |
 Vincent Banned
| R6_Rider |
| Vincent |
 Vincent Banned
 Posted: 11:18 - 13 May 2008 Post subject: |
| GSXF-750 wrote: | | Vincent wrote: | Before vacuum taps, it was normal to turn your petrol On and Off everytime you use the bike. If you didn't, and the float valves were not working properly, it could start to fill the engine and exhausts with petrol with dire results. As far as I know, the vacuum tap was brought out so you didn't have to do this everytime you got on the bike. I suspect your problem may still occur with the tap in the "On" position and may just be a case of cleaning the carb and checking the float height and the condition of the float needle, esp if the bike's been standing. |
Thanks for your reply!
I will check the fuel tap when I get home but is cleaning the carbs something I can do or could I mess it right up?
Cheers |
If you are OK with following instructions, can use a screwdriver and are not hamfisted it's fairly easy. Sometimes heavily varnished, (expression given to thye sludge left by evaporated fuel), carbs will need to be done ultrasonicaly as the tiny airways, (galleries), can be blocked. However, 90% of the time, it's just a case of the pilot jet gettting blocked. i used to soak them in carb cleaner and blow them through with compressed air, now I use micro-drills and find them excellent. |
| R6_Rider |
 Posted: 11:41 - 13 May 2008 Post subject: |
Cheers
Cool, I might give it a go on the weekend then.
Is it in the haynes manual how to take them apart, I haven't looked yet but if it is then should be easy I guess.
Thanks very much!
Si |
| Vincent |
 Vincent Banned
| R6_Rider |
| Vincent |
 Vincent Banned
 Posted: 13:36 - 13 May 2008 Post subject: |
It differs on different bikes but most fours you'll have to take them off I'm afraid. it's really fiddly getting the bowls off when the carbs are on the bike anyway. Not sure about your bike but on my CB-1 it's a case of tank off, air filter off. Undo cables, (sometimes you can leave these on which makes it easier), undo jubilee clips where the carbs attatch to the motor and Bob's yer uncle - or in my case, yer half brother  |
| R6_Rider |
| StealthDJ |
 StealthDJ Nova Slayer
| R6_Rider |
| Ichy |
 Ichy World Chat Champion
 Posted: 20:34 - 13 May 2008 Post subject: |
What makes you think its running rich?
Backfiring can be caused by loads of things, weak mixture, poor spark, dodgy plugs or leads etc.
I wouldn't strip the carbs just yet. I know you have new plugs but give them a good clean and go for a decent ride.
There is some decent carb cleaner that goes in the petrol. BG44K has some decent feedback although it costs £20 - £25 a bottle. Seems a lot of money but when your trying to get the carbs to sit back in the manifold rubbers and the airbox boots you might just wish you'd tried it first.  ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| R6_Rider |
 Posted: 07:51 - 14 May 2008 Post subject: |
| Ichy wrote: | What makes you think its running rich?
There is some decent carb cleaner that goes in the petrol. BG44K has some decent feedback although it costs £20 - £25 a bottle. Seems a lot of money but when your trying to get the carbs to sit back in the manifold rubbers and the airbox boots you might just wish you'd tried it first.  |
Thanks for your reply.
the only reason I think it is running rich is that it is using loads of fuel and stinks of petrol.
I am going to clean the plugs and turn the tap to on and go for a big jaunt.
Cheers |
| R6_Rider |
| Ichy |
 Posted: 21:56 - 14 May 2008 Post subject: |
I guess the first thing to check is that the vacuum pipe is attached correctly. with the fairing off on the left hand side you should be able to see the pipes running to the petrol tap. One will lead to the rear of the carbs, thats the fuel line. The other should attach to the manifold in front of the carburettors. This is the pipe that turns the fuel on and off.
You need to clean your plugs. It sounds as if the float valves may be sticking / not working. This has caused excess fuel to get into the cylinders and foul the plugs. ____________________ https://www.metacafe.com/watch/1972097/how_to_behave_on_a_forum/ |
| R6_Rider |
The last post was made 17 years, 282 days ago. Instead of replying here, would creating a new thread be more useful? |
