Running rich
R6_Rider
PostPosted: 09:41 - 13 May 2008    Post subject: Running rich Reply with quote
Hi all,
Having passed my test yesterday I got home and got straight on my 1991 Teapot. I have just got the bike Mot'd as it has been stood for a year and all seemed ok but I was getting a lot of backfires and it seemed to be running really rich. Now after reading a few things on here I have noticed that the fuel tap was on prime and not on. Now would this cause too much fuel? I havent tried it to put it on just on to see how it runs as yet but just wondered if this would cause it to run a bit odd?
Many thanks,
Si
PostPosted: 09:46 - 13 May 2008    Post subject: Reply with quote
Prime is meant to be used to fill the carbs after you've had them off(it doesn't need a vacuum to push the fuel through), so I guess it could make it run rather funny.
Try it with "on" and see what happens.
R6_Rider
PostPosted: 09:48 - 13 May 2008    Post subject: Reply with quote
Nice one!
Thanks for your reply, I will give it a go tonight!
Si
R6_Rider
PostPosted: 10:12 - 13 May 2008    Post subject: Reply with quote
Vincent wrote:
Before vacuum taps, it was normal to turn your petrol On and Off everytime you use the bike. If you didn't, and the float valves were not working properly, it could start to fill the engine and exhausts with petrol with dire results. As far as I know, the vacuum tap was brought out so you didn't have to do this everytime you got on the bike. I suspect your problem may still occur with the tap in the "On" position and may just be a case of cleaning the carb and checking the float height and the condition of the float needle, esp if the bike's been standing.
Thanks for your reply!
I will check the fuel tap when I get home but is cleaning the carbs something I can do or could I mess it right up?
R6_Rider
PostPosted: 11:41 - 13 May 2008    Post subject: Reply with quote
If you are OK with following instructions, can use a screwdriver and are not hamfisted it's fairly easy. Sometimes heavily varnished, (expression given to thye sludge left by evaporated fuel), carbs will need to be done ultrasonicaly as the tiny airways, (galleries), can be blocked. However, 90% of the time, it's just a case of the pilot jet gettting blocked. i used to soak them in carb cleaner and blow them through with compressed air, now I use micro-drills and find them excellent.
Cool, I might give it a go on the weekend then.
Is it in the haynes manual how to take them apart, I haven't looked yet but if it is then should be easy I guess.
Thanks very much!
Si
R6_Rider
PostPosted: 12:40 - 13 May 2008    Post subject: Reply with quote
Thanks!
Do I need to remove them at all from the engine then or leave them attached?
Think I should just read the manual I guess
Cheers for your help!
R6_Rider
PostPosted: 16:01 - 13 May 2008    Post subject: Reply with quote
Nice one!
Cheers, i will get cracking on that one night in the week then, I have just bought some carb cleaner too made by wuff? Is that any good?
StealthDJ
PostPosted: 16:14 - 13 May 2008    Post subject: Reply with quote
Couple of things, before you go pulling your carbs apart (cos it involves less pain...)
1. What sort of condition is the air filter in? If it's clogged, that'll make the bike run rich.
2. You mention it's been stood for a year. Have you been regularly running in during this time? On the choke, perhaps? If that's the case, your plugs are probably pretty well sooted up, which will have a similar end effect - either clean them or replace them. While you're in there, check the condition of the plug caps and leads.
You'll probably still want to clean out the carbs, but those two jobs are a lot easier to do and might well solve your problem...
Current garage: VFR800 FI-W | RD500LC YPVS | SV650 K2 | MZ TS250/1 | MZ ETZ251 | BSA WDB40
Previous notables: H100 S2 | CB250NA/B | CB250T | GT250X7 | Z650 B1 | SR650
Still owned, but long gone: RD250LC | CB750F2 SOHC | C50
R6_Rider
PostPosted: 17:45 - 13 May 2008    Post subject: Reply with quote
Cheers for that!
I only bought the bike in Feb and it was stood by the previous owner so the first thing I done was dump the oil and change the oil and plugs and air filter but since I have been running the bike on pri like a fool i havent checked the plugs again as I think they might be clogged up again.
Will check the above first and see what happens!
Cheers all,
Si
Ichy
PostPosted: 20:34 - 13 May 2008    Post subject: Reply with quote
What makes you think its running rich?
Backfiring can be caused by loads of things, weak mixture, poor spark, dodgy plugs or leads etc.
I wouldn't strip the carbs just yet. I know you have new plugs but give them a good clean and go for a decent ride.
There is some decent carb cleaner that goes in the petrol. BG44K has some decent feedback although it costs £20 - £25 a bottle. Seems a lot of money but when your trying to get the carbs to sit back in the manifold rubbers and the airbox boots you might just wish you'd tried it first. Wink
R6_Rider
PostPosted: 07:51 - 14 May 2008    Post subject: Reply with quote
Thanks for your reply.
the only reason I think it is running rich is that it is using loads of fuel and stinks of petrol.
I am going to clean the plugs and turn the tap to on and go for a big jaunt.
R6_Rider
PostPosted: 21:07 - 14 May 2008    Post subject: Reply with quote
Right then peps,
I have been out on the bike tonight again. I tired putting the fuel tap to on and about 5 mins on the road the bike cut out and wouldn't run unless I put it back on to Prime. The bike is sort of a bit better as far as if I pull the throttle the bike wait's a small time and then it goes and goes all the way but it isn't ticking over very well and i can here backfires most of the time.
I want to get it sorted as it is taking a shine of just passing my test and I really wan to get out there but it's doing my head in. I have called a few places today but nonone can fit me in for a few weeks as they are so busy getting others ready for the summer.
I haven't taken the plugs out too see the state of them as yet, I am going to do that tomorrow.
Anyone got any other suggetions for me to look at?
Many thanks,
Simon
Ichy
PostPosted: 21:56 - 14 May 2008    Post subject: Reply with quote
I guess the first thing to check is that the vacuum pipe is attached correctly. with the fairing off on the left hand side you should be able to see the pipes running to the petrol tap. One will lead to the rear of the carbs, thats the fuel line. The other should attach to the manifold in front of the carburettors. This is the pipe that turns the fuel on and off.
You need to clean your plugs. It sounds as if the float valves may be sticking / not working. This has caused excess fuel to get into the cylinders and foul the plugs.
R6_Rider
PostPosted: 07:38 - 15 May 2008    Post subject: Reply with quote
Thanks,
I am going to strip it tonight to see whats what with the fuel pipes and plugs.
Cheers,
Si
The last post was made 17 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 105.36 Kb
