helmet sizes???
The Artist
PostPosted: 19:11 - 13 May 2008    Post subject: helmet sizes??? Reply with quote
I am getting a new helmet and I though my size was large but I tried a large (59-60cm) and it was way too tight i think. Cheeks pushed up and hair stretched (longish) wan't comfortable. Helmet had no slack at all and was too tight to ride anything comfortably.
My question is this,
How tight should a helmet be to be safe?
Do all companies use the same measuring guide? I want to know because I may order off tinternet.
Some helmets cost £400 while others £40. Obviously the more expensive the more stylish and supposedly safer they are but does it make any realy difference to someone coming off at low-medium speed, my bike only does 60 and thats pushing so I cruise at around 45-50.
Thanks
iooi
PostPosted: 19:56 - 13 May 2008    Post subject: Re: helmet sizes??? Reply with quote
Thanks
A big fat NO.......
Diffrent brands suit diffrent shaped heads.
If you want to order of the internet then at least go to a store and try some on till you find a good filt then see if you can get cheaper, just be aware that if you have to return, any savings can soon be wiped out by postage charges.
There are several threads in New Bilers about this very subject and the 40 V 400 as well.
Best advise no matter how much you pay it has to fit well. Thumbs Up
DMan
PostPosted: 20:04 - 13 May 2008    Post subject: Reply with quote
Fit is most important but your budget is the limiting factor. You may only go 60 but if car hits you at 30 thats a combined impact of 90, so the better materials will keep you alive (albeit a crippled cabbage) whereas the cardboard helmet will save on future private care costs , just have to pay for the cremation Laughing
2001 Hornet 600 - "Faster than yellow" Blue; Current: 1998 Yammy FZS 600 "Fazer" Black
You show me how to control a wild fucking gypsy and I'll show you how to control an unhinged, pig-feeding gangster.
The Artist
PostPosted: 20:09 - 13 May 2008    Post subject: Reply with quote
thanks dman for the encouragement!!
Yeah, im thinking going to a shop try on a certain make and size then lookup exact same on tinternet and see if i can get it cheaper.
I always wanted a stig helmet but they are £200 and something
Whosthedaddy
PostPosted: 20:48 - 13 May 2008    Post subject: Reply with quote
The amount of helmets I recently tried on was unreal, from cheap to expensive, all fitted diffrently even so far as to say different fit from different models by the same manufacturer.
In the end there was only one helmet that just felt right as soon as it squeezed onto the old hat rack, that being a Shoei.
The size and fit just varies too much, go and try them on, then it may be safe to buy from the interweb if cheaper.
DMan
PostPosted: 21:10 - 13 May 2008    Post subject: Reply with quote
thats probably the best way, worth a shot is finding best in shop, look at web price, then back to shop for price match. Most will do, you can get at least 5% just by asking regardless and then if close enough price to web its always worth shop bought as easier to take back if clip breaks or something. good luck
Nixon
PostPosted: 21:27 - 13 May 2008    Post subject: Reply with quote
first off have you actually measured your head or are you just guessing at what size you need?
If you havent then:
get a soft tape measure and measure around the fattest part of your head just above your eyebrows all the way round including the big bump at the back, then take the measurement
That is the size you are aiming for but as already said every company has different shapes and sizes.
you can add a little for longer hair but it doesnt make much of a difference
Question The helmet when you first buy it should feel over tight like it is very very tight indeed as the comfort padding will bed down and get softer the more you use it - like a matress.
With the helmet on your head and with the chin strap done up you should look in a mirror grab the chin piece of the helmet and try twist it up and down and twist it left and right. There should be absolutely minimal movement, a very slight bit is acceptable but anything over 2cm movement and it is too big try a smaller one.
There are thousands of things i could go into telling you about helmets and shell sizes and the inefficiencys of EC2205
(if you really want to know then PM me and i will put it all in a word doc and e-mail it to you)
But basically buy one that fits or try lots on to find those that fit
and make sure whatever you buy, You buy one with a Double D chin strap
The last post was made 18 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 54.64 Kb
