| RetroRacer |
 RetroRacer L Plate Warrior
| Grifter |
 Grifter L Plate Warrior
| alains |
 alains World Chat Champion
 Posted: 18:41 - 27 May 2008 Post subject: |
CI639 & CI626 are not swappable like that . you need to cross green and black/yellow wire at the CDI 4 wires connector
look my file https://www.geneva-racing.ch/~alains/NSRtips.doc ____________________ the worst day fishing is better than the best day working |
| SeanMN |
 SeanMN L Plate Warrior
 Posted: 18:17 - 06 Nov 2008 Post subject: |
Does anyone know where I can get the CI626 CDi??
PM me!!
Thanks  |
| alains |
 Posted: 18:58 - 06 Nov 2008 Post subject: |
look at breakers on ebay
but also you may fit an earlier model (CI572) straight away , the only problem is that you have no security stand
about fitting a CI639 download my file https://www.geneva-racing.ch/~alains/NSRtips.doc
if you need further infos , pm
by the way a new can be ordered to david silver spares ref 30410 KBS 901 and will cost £120ish ____________________ the worst day fishing is better than the best day working |
| SeanMN |
| alains |
 Posted: 01:00 - 07 Nov 2008 Post subject: |
on top of the carb , where the throttle cable arrive , you see 2 screws . undo them then pull out the throttle (it comes with the cable) . in the center of the throttle you see the needle . the throttle has a hole where the cable go through and at the end it's a lead ball . the throttle has a slit , pull a bit on the ball and make the cable escape through the slit . warning about the throttle spring going nowhere . on the needle you will see a clip , set it on the second notch from the top  ____________________ the worst day fishing is better than the best day working |
The last post was made 17 years, 335 days ago. Instead of replying here, would creating a new thread be more useful? |
