NSR 125 CDI Units.
RetroRacer
PostPosted: 15:18 - 27 May 2008    Post subject: NSR 125 CDI Units. Reply with quote
I am new to this chat game so please bear with me. I am an old Brit Iron man, but have recently been seduced by a young japanese model ( NSR 125R ). There is a problem, she is getting older and more tempremental.
She is a UK 1999 NSR125R and it looks like the CDI ( CI626 ) unit has stopped working. I have tested the unit and I get no readings across the green & red/white pins, which according to the manual should be between 2-150Kohms. I have looked on ebay etc but the CI626 seems to be very rare. I love riding her and I am not too bothered about speed and was wondering if I could just fit the restricted CI639 unit.
DaveG
Grifter
PostPosted: 17:47 - 27 May 2008    Post subject: Reply with quote
Yeah, it's a straight swap, but you might loose a bit of power. I swapped from a CI639 to a CI626 but I did have to bodge a new plug onto it.
I noticed you are in Lancashire. I you're anywhere near Chorley, Berties had a couple in (CI626) when I was last there.
Grifter
current: 1991 Honda VFR400R3-M NC30 Black and Grey
past: 1999 Honda NSR125RX F Black
alains
PostPosted: 18:41 - 27 May 2008    Post subject: Reply with quote
CI639 & CI626 are not swappable like that . you need to cross green and black/yellow wire at the CDI 4 wires connector
look my file https://www.geneva-racing.ch/~alains/NSRtips.doc
SeanMN
PostPosted: 18:17 - 06 Nov 2008    Post subject: Reply with quote
Does anyone know where I can get the CI626 CDi??
PM me!!
Thanks Thumbs Up
alains
PostPosted: 18:58 - 06 Nov 2008    Post subject: Reply with quote
look at breakers on ebay
but also you may fit an earlier model (CI572) straight away , the only problem is that you have no security stand
about fitting a CI639 download my file https://www.geneva-racing.ch/~alains/NSRtips.doc
if you need further infos , pm
by the way a new can be ordered to david silver spares ref 30410 KBS 901 and will cost £120ish
SeanMN
PostPosted: 00:09 - 07 Nov 2008    Post subject: Reply with quote
Thanks very much!
Do you have any info on how to set the throttle needle second from the top??
alains
PostPosted: 01:00 - 07 Nov 2008    Post subject: Reply with quote
on top of the carb , where the throttle cable arrive , you see 2 screws . undo them then pull out the throttle (it comes with the cable) . in the center of the throttle you see the needle . the throttle has a hole where the cable go through and at the end it's a lead ball . the throttle has a slit , pull a bit on the ball and make the cable escape through the slit . warning about the throttle spring going nowhere . on the needle you will see a clip , set it on the second notch from the top Very Happy
The last post was made 17 years, 335 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.84 - MySQL Queries: 13 - Page Size: 50.72 Kb
