NSR How do I get the clutch off?
ncrn
PostPosted: 20:16 - 27 May 2008    Post subject: NSR How do I get the clutch off? Reply with quote
I'm trying to strip the engine out so I can get to the gear box to try to work out why it won't select 2nd gear or lower.
I've got this far with the gear box but there's a nut in the middle that I don't have a tool for, what tool do I need or is there a clever way to get it off?
https://i55.photobucket.com/albums/g123/ncrn/27052008085.jpg
Any help would be appreciated.
Thanks.
Timmeh
PostPosted: 23:07 - 27 May 2008    Post subject: Reply with quote
If it's a castellated nut then the easiest method is to get a socket of the same size and cut notches into with with a dremel or something similar.
The same thing goes for engine mount bolts.
ncrn
PostPosted: 13:11 - 28 May 2008    Post subject: Reply with quote
Cool cheers I'll give cutting up an old socket a go. Why do they use such an odd nut to hold it in?
Timmeh
PostPosted: 13:22 - 28 May 2008    Post subject: Reply with quote
They have a greater surface area and therefore higher tensile strength, I think.
PostPosted: 13:23 - 28 May 2008    Post subject: Reply with quote
I'm sure someone will come up with a 'good' reason such as it being to allow the nut to sit down into a recess only slightly wider than itself. If it was a standard hex, you wouldn't be able to fit a socket round the outside of it.
I suspect the real (and more cynical) reason is that it makes you either take the bike to a dealer for servicing or buy a special tool off Honda.
Honda clutch socket tool, part no.: 07716-0020100
£14
ncrn
PostPosted: 13:57 - 28 May 2008    Post subject: Reply with quote
Yeh I suppose that makes sense, I'll give the socket thing a shot and if it doesn't work I'll try to get hold of an official tool.
There is a gap of 14 years, 82 days between these two posts...
tamkiraly
PostPosted: 09:05 - 16 Aug 2022    Post subject: Re: NSR How do I get the clutch off? Reply with quote
Hey! I know it's quite an old post, but I'll give it a try... Have you figured what caused the problem? I've just encountered the same thing on my NSR-125 (and yet at the stage of getting the nut off the clutch Very Happy).
Thanks!
The last post was made 3 years, 237 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.48 - MySQL Queries: 13 - Page Size: 55.27 Kb
