Bike Charger
scottjames1uk
PostPosted: 20:58 - 30 May 2008    Post subject: Bike Charger Reply with quote
I am going away in 2 weeks touring Spain and France on a 1200 Harley custom sportster, I am wanting to charge phone up etc, Is there a gadget that I can connect to the battery with a female charger to plug into. Also any help in what to take would be great, so far I have
Tent
First aid kit
Basis tools
Sleeping bag
Loads of bungees
Spare bulbs
Rear tyre has ultra seal in it and taking can of puncture repair stuff
Maps
Driving licence
Insurance
MOT
Passport
Travel insurance documents
Think that’s about it
Currently riding - Harley Davidson 1200 Custom Sportster
Previous Bikes - Suzuki RF600, Honda VTR 1000
PostPosted: 21:01 - 30 May 2008    Post subject: Re: Bike Charger Reply with quote
Don't know how reliable your bike is, but could be worth taking a list of dealers near your route.
I've plumbed-in a cigarrete lighter socket (maplins) into my CCM, to power my GPS from. Obviously using a standard car charger with it.
scottjames1uk
PostPosted: 21:04 - 30 May 2008    Post subject: Charger Reply with quote
Called to Maplins today and they said they had nothing!!! Its a 2005 with 7000 on clock and just been serviced recently. I have breakdown cover too
Itchy
PostPosted: 21:08 - 30 May 2008    Post subject: Reply with quote
maplins are liars ,
buy this:
https://www.maplin.co.uk/Module.aspx?ModuleNo=1056&C=Maplin&U=SearchTop&T=cigarette%20cocket&doy=30m5
cut the end off, (the bit that goes into your car socket)
and wire it to your battery, (solder on a couple of the solder tag hoops onto the ends) you might want to put a inline fuse on it also or a diode so you can't get it backwards.
https://www.maplin.co.uk/images/300/lr62s.jpg
jobs a gud'un
I did this to my NTV (as a test bed) , if you want to make it nicer stick a relay on the side light onto this so it cannot take power off the battery when the lights are off.
Scrap that I remember opening it up , all you effectively need to do is undo the screw on the plug in end and you have two wires which you can wrap onto your battery terminals or solder on those solder tag hoops
oh you forgot your EHIC (european health insurance card) but you have insurance so this is a moot point
also your V5C.
Itchy
PostPosted: 21:18 - 30 May 2008    Post subject: Reply with quote
anti chap stick, remember you are going to be riding lots of miles in the heat and your face is going to be air dried for hours at a time, to prevent your lips getting crusty sticking together and hurting loads.
PostPosted: 21:39 - 30 May 2008    Post subject: Reply with quote
Itchy wrote:
I got this:
https://www.maplin.co.uk/Module.aspx?ModuleNo=1055&C=Maplin&U=SearchTop&T=cigarrete%20lighter&doy=30m5
I used some appropriate terminals that were in a crimp set I had, however just wrapping the wire around is probably fine.
I also wired in a fuse.
If you want to get fancy, go for a switch or really fancy and go for a relay to turn it on when the bike's running.
Faldo
PostPosted: 22:09 - 30 May 2008    Post subject: Reply with quote
I bought two of these : Clicky
Then: One of these
Run the power leads from the battery (Fused of course), a splitter inside the box, mounted the two sockets in the box and bolted it in the compartment under the pillion seat on my ZX7R. Really was a piece of piss, and almost looks OEM. Charge phone + SNAV at the same time
Current: ZZR1400
PostPosted: 22:50 - 30 May 2008    Post subject: Reply with quote
If I'm sorting out my new toy for distance stuff, then I think I'll be looking at using some kind of smaller arbitarry socket and wiring my stuff up for that, not really worth the hassle for shorter trips, though.
Nb
PostPosted: 10:11 - 31 May 2008    Post subject: Reply with quote
I bought this from maplins https://www.maplin.co.uk/Module.aspx?ModuleNo=1056&&source=14&doy=31m5
Dismantled the end and your left with some soldered metal bits, just cut them in half and wedge them under you battery bolts. If you do that i'll go and see which side was which +/-
Flip
PostPosted: 20:10 - 31 May 2008    Post subject: Reply with quote
I bought a 12v socket with inline fuse from Hein Gericke (*sp) for about £11. Wires up to the battery, piece of p1ss.
scottjames1uk
PostPosted: 18:40 - 02 Jun 2008    Post subject: Sorted Reply with quote
Got a Cig Lighter extention and cut the male end off. Fitted a waterproof inline fuse and works a treat. Thanks
scottjames1uk
PostPosted: 08:24 - 07 Jun 2008    Post subject: Reply with quote
I finally found a Extention from Maplins for £3.99 Also got a waterproof inline fuse and connected it to battery and then Used Tie Wraps to fasten to Frame. Works a treat
natv4
PostPosted: 16:52 - 27 Jun 2008    Post subject: Re: Bike Charger Reply with quote
scottjames1uk wrote:
I am going away in 2 weeks touring...
If you can it is well worth learning how to use proper (plug) puncture repair kit.
They are really easy and can be used (in emergencies) to plug much bigger holes than either slime or squirty cans. They are safer than slime (you know the hole is there and how bad it is) and work for longer than a can (anything vaguely big will defeat a can).
I've ridden on a plug (simple large screw through tyre) for 5000 miles until the tyre was dead. If its really big, then keep plugging until you run out or fill the hole; it got a mate of mine the 50 miles to a tyre fitter. Much better to hobble (20mph) than push!
Your list looks good, you didn't mention cards, take 2 (in case one says no Wink if you can, preferably Nationwide (cheap to use abroad) and any credit card. You never know when you may need to pay for repairs etc.
I always take some music, but thats just me.
Travelling around the world...a bit at a time. Where am I now? / Visit my BLOG
Bike: Blue Honda VFR800fi (*NEW*) Mileage: 22k Countries visited: GB/F/D/CZ/PL/E/I/B/A/HR/H/Rus/E/MA
West Europe...2004, East Europe...2005, Russia/France...2006, Morocco...2007
Itchy
PostPosted: 17:04 - 27 Jun 2008    Post subject: Re: Bike Charger Reply with quote
erm hes been gone for nearly 2 weeks already!
R4nger
PostPosted: 20:30 - 27 Jun 2008    Post subject: Reply with quote
https://www.powerletproducts.com/products/ptb.php#
I used the above. The quality is good and provides a water resistant option.
The Tot
PostPosted: 08:58 - 28 Jun 2008    Post subject: Reply with quote
Hein Gericke sell them for £11.99. It did me well at the festival when i charged my phone and my mate's phone without any hassle. They don't drain your battery too much, probably the same amount as your alarm.
Never argue with autism
The last post was made 17 years, 295 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.68 - MySQL Queries: 13 - Page Size: 96.65 Kb
