30 more miles out of a tank ! ! ?
pyx_e
PostPosted: 17:08 - 09 Jun 2008    Post subject: 30 more miles out of a tank ! ! ? Reply with quote
Well I just got 150 miles out of my ER5 tank and I usually get 120. It has just come back from the garage and it had:
1 / New back wheel bearings.
2/ Valve clearance check and the exhaust valve timing was found to be a little off. It was corrected.
Was it one of these that caused the extra 30 miles or both and is it me or does that seem to be a hell of a jump?
Shiney!
Kawasaki: ER5, Versys, VN900.
Polo
PostPosted: 17:13 - 09 Jun 2008    Post subject: Reply with quote
Nah, you must have initiated ghey mode at some point.
Symptoms include bike not revving over 3k and the rider emitting a tutting noise every time a quick bike goes past.
My mum smells your fingers
.Chris.
PostPosted: 17:23 - 09 Jun 2008    Post subject: Reply with quote
Possibly both of them - if your old back wheel bearing was causing drag then that'd make the bike consume more fuel, plus if the valve gaps were off then that'd mean the engine wasn't running at full efficiency.
More likely to be the valve gaps having the most effect though in my estimation.
Chris
1985 Kawasaki Z550F
Ravo
PostPosted: 18:10 - 09 Jun 2008    Post subject: Reply with quote
I disagree. A worn wheel bearing can risk vibrating in place, which if you've ever played with cheap gyroscopes before you know will immediately dissipate all stored rotational energy. The valve gaps would make a big deal, but I think the bigger problem was a worn rear wheel bearing.
TUG
PostPosted: 18:49 - 09 Jun 2008    Post subject: Reply with quote
Bet they pumped you tyres up for you to cos u've never checked em?
If am wrong then sorry.
Haz ER-5, innit!
The last post was made 18 years, 31 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 43.78 Kb
