| nynfortoo |
 nynfortoo Trackday Trickster
 Posted: 18:12 - 12 Jun 2008 Post subject: Betor Shock Help, if you please |
Could do with a quick run-through of this new shock (I'm f'ing clueless) if you don't mind.
I've attached a couple of pics, and need to know the following:
1. The flathead screw in pic 1. What does it do?
2. The adjustment rings in pic 1. Why are there 2 of them, or are they 1 piece?
3. The dustcap in pic 2. There's a valve underneath - what is it for, and do I need to touch it at all?
4. The eyelets at each end of the shock are not quite aligned with eachother. Is this likely to be a problem, or will I be able to twist it when I fit it?
https://i34.photobucket.com/albums/d109/nynfortoo/IMG_2806.jpg
https://i34.photobucket.com/albums/d109/nynfortoo/IMG_2808.jpg
Cheers. |
| Finglonga |
 Finglonga World Chat Champion
 Posted: 18:41 - 12 Jun 2008 Post subject: Re: Betor Shock Help, if you please |
| nynfortoo wrote: | Could do with a quick run-through of this new shock (I'm f'ing clueless) if you don't mind.
1. The flathead screw in pic 1. What does it do? Rebound adjuster.
2. The adjustment rings in pic 1. Why are there 2 of them, or are they 1 piece? 2 Seperate rings that lock together when you have adjusted the pre-load with them.
3. The dustcap in pic 2. There's a valve underneath - what is it for, and do I need to touch it at all? Depends what the shock uses for damping, Air, Nitrogen?
4. The eyelets at each end of the shock are not quite aligned with eachother. Is this likely to be a problem, or will I be able to twist it when I fit it? Bottom and top parts separate and will twist to lign up.
Cheers. |
____________________ Andy Sez....
F.Y.Y.F.F. |
| nynfortoo |
| Noxious89123 |
 Noxious89123 World Chat Champion
 Posted: 19:46 - 12 Jun 2008 Post subject: |
Rebound dampening, or possibly just dampening in general, would be my guess.
One should be immovable, the other should be able to turn with a C-spanner. It's preload adjustment, if you didn't already know.
Could be compression dampening adjustment, or just a valve for gassing the shock when its manufactured?
The 2 moving parts aren't really fixed together as such, so you should be able to twist it. Can't be sure though.
Hope i've been of some help!
EDIT: Seems i was way too slow there
In reply to your other question; I'd imagine you turn the ring that is touching the spring to adjust it, and the other locks it in place. ____________________
'06 Honda CBR125RW-6 ~ '00 Honda CBR600F-Y ~ '07 Honda CBR600RR-7 ~ Bikeless
'53 Ford Ka 1.3 ~ '03 Vauxhall Astra SRi 1.8 ~ '52 Vauxhall Astra SRi 2.2 ~ '53 Vauxhall Astra GSi |
| virus |
 virus World Chat Champion
 Posted: 21:15 - 12 Jun 2008 Post subject: |
Adjustment rings, the one closest to the spring adjusts it, the other one locks the first one in place, undo the second one, more the first one so the spring is how you want it, then tighten the second ring into the first to lock it off.
John ____________________ own: 81 xs1100g...
stinkwheel Well I just had my hands up a pigs fanny. Which makes your concerns pale into insignificance. |
| nynfortoo |
| alun111 |
 alun111 World Chat Champion
| nynfortoo |
| alun111 |
The last post was made 17 years, 193 days ago. Instead of replying here, would creating a new thread be more useful? |
