Putting a write off back on the road
Steve-D
PostPosted: 05:09 - 17 Jun 2008    Post subject: Putting a write off back on the road Reply with quote
Basically I'm looking at buying a cat b write off. Nothing particulary wrong with it, a few scratches, but nothing serious. Frame, forks and engine fine.
Am I right in thinking all I need is a new frame to put it back on the road.
For the price its at and the price of frames I have seen it is definitely worth it.
Cheers.
www.southwestbikers.com
PostPosted: 05:22 - 17 Jun 2008    Post subject: Reply with quote
If you buy a frame that isn't a write off you won't be putting a write off back on the road. Get the good frame and V5 transfer parts from Cat B bike to good frame, then mot the bike sorted.
Tricolor Fan
PostPosted: 05:42 - 17 Jun 2008    Post subject: Reply with quote
Yes, all you need is a new frame with it's own V5.
just don't tell the DVLA what you've done, or you'll end up with a Q plate.
Give me ambiguity or give me something else.
map
Mr Calendar
PostPosted: 08:02 - 17 Jun 2008    Post subject: Reply with quote
FWIW a Cat B write-off is deemed not fit to go back on the road. However, it can be broken for parts.
So what you're suggesting would work. Use the parts from the Cat B to build/replace an existing bike - as chris-red says above.
The registration and V5 would match the existing non Cat B bike with let's say the engine number from the Cat B transfered onto it.
Hence, the bit above about the Q plate is wrong - don't believe everything you might read on an internet forum.
HTH Thumbs Up
NSR Mick
PostPosted: 08:31 - 17 Jun 2008    Post subject: Reply with quote
I'm pretty sure a cat B will have more wrong with it than a few scratches. Cat B's usually have serious structural damage.
A Category B Vehicle is a Salvaged Vehicle, which is so structurally damaged, or devoid of parts that it is not possible to repair it economically or safely.
Are you sure it's not a Cat D?
Steve-D
PostPosted: 09:44 - 17 Jun 2008    Post subject: Reply with quote
Awesome Thanks. Karma
I'm just going by what the add says. Will run a HPI check on it later.
It looks like its been down the road on one side and done a few scratches down the fairing as well as a small section missing from the front fairing. Snapped footpeg as well.
PostPosted: 10:00 - 17 Jun 2008    Post subject: Reply with quote
People have managed to get cat A and B bikes back on the road by just applying to the DVLA for a log book.
The write off categories are an insurance industry idea, and other than they way the insurance industry try and describe it I have never seen any legal reasons why one cannot go back on the road (although getting insurance might be fun).
Tricolor Fan
PostPosted: 12:19 - 17 Jun 2008    Post subject: Reply with quote
HTH Thumbs Up
When building a bitsa or swapping a frame, technically, the frame and so many other parts have to be from one bike to retain the frames original registration. Otherwise it has to be Q plated.
It rarely happens because anyone with sense just swaps the frame and alters the engine number on the V5.
colin1
Captain Safety
PostPosted: 17:46 - 17 Jun 2008    Post subject: Reply with quote
taking a bike apart to reassemble and put onto another frame may go smoothly even if you havnt done it before
or there may be little problems
good luck Thumbs Up
trevoriv
PostPosted: 19:07 - 17 Jun 2008    Post subject: Reply with quote
You won't get insurance for a cat b write off.
A cat B should not be put back on the road.
Rockhopper
PostPosted: 20:17 - 17 Jun 2008    Post subject: Reply with quote
But it won't be on the register if he uses a new (second hand) frame with a V5!
colin1
Captain Safety
PostPosted: 23:44 - 17 Jun 2008    Post subject: Reply with quote
he is using bits from the cat b, on a frame that hasnt been written off
trevoriv
PostPosted: 18:55 - 18 Jun 2008    Post subject: Reply with quote
Clearly didnt read the post properly, yeah should be fine then. Thumbs Up
NSR Mick
PostPosted: 21:06 - 18 Jun 2008    Post subject: Reply with quote
Apart from the fact that this cat b only has scratches. Confused
Steve-D
PostPosted: 00:13 - 19 Jun 2008    Post subject: Reply with quote
Well its a ZXR400, so I can understand why they would write it off considering age (1990). Been and seen it and apart from the scratches it looks fine. It's for sale for 500 and a new frame cost on average 150.
And it would give me a chance to get rid of the divvy Very Happy
NSR Mick
PostPosted: 08:10 - 19 Jun 2008    Post subject: Reply with quote
I'm not doubting you but they wrote my NSR off and that was bodywork and swing arm damage and that's a cat d.
Unless it's mistakenly been categorised wrong I'd look harder but as you say for the cost of a frame you might be onto a winner.
The last post was made 18 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 92.28 Kb
