| yankeedoodle |
 yankeedoodle Nearly there...
| Rockhopper |
 Rockhopper Trackday Trickster
| Rockhopper |
| yankeedoodle |
 Posted: 20:17 - 17 Jun 2008 Post subject: |
thankyou
much appreciated  ____________________ Bandit 600 |
 Posted: 21:57 - 17 Jun 2008 Post subject: |
As above.
Reality is the frames without title are quite possibly stolen frames (hence no log book).
If you buy a frame with a log book and then transfer the bits from your bike to it then effectively you have put the frame back on the road with its own registration number, not the number currently on your bike.
Brand new frames can come with no chassis number at all, and these are then stamped with the existing frame number.
| petemell |
 petemell Trackday Trickster
| StealthDJ |
 StealthDJ Nova Slayer
 Posted: 12:39 - 24 Jun 2008 Post subject: |
Sadly these days, it has to go through an SVA test - something that's significantly tougher than the old ones. (To the extent that it's now almost impossible to build a trike and get it approved). Far as I was aware, it's not exactly cheap, either, though the inspection manual can be found online to give you a clue as to what you're aiming for.
In some cases, you can apply for an age-related plate, though it depends on how much you can convince the DVLA that it's age is verifiable. I wouldn't, obviously, recommend transferring the piece of the frame with the number on it across to the new bike, though that's what always used to be done with chops. (Hell, in some cases, you could take the chunk of frame in your pocket to the inspection and that was enough) ____________________ Current garage: VFR800 FI-W | RD500LC YPVS | SV650 K2 | MZ TS250/1 | MZ ETZ251 | BSA WDB40
Previous notables: H100 S2 | CB250NA/B | CB250T | GT250X7 | Z650 B1 | SR650
Still owned, but long gone: RD250LC | CB750F2 SOHC | C50 |
| Phoenix |
 Phoenix Twisted Firestarter
 Posted: 20:02 - 24 Jun 2008 Post subject: |
| Rockhopper wrote: | The ones you are looking at that say no title are Cat B write offs, they have had the frame number ground off. You'll never be able to put a bike with a frame like that back on the road. All you can do with it would be to make a trackday bike. They should really have the headstock cut off so they can never go back on the road. |
Not really accurate.
A frame with no title is just that, doesn't mean it's a write off at all as there's no way to prove what frame it is or where it's from if the number is ground off. Any frame with no number or V5 is most likely stolen as there is little other reason to remove frame numbers.
A frame with a number but no V5 could be a cat B as often the log book is surrendered to the DVLA, the number wouldn't have been ground off though. Also the headstock does not get cut off, that is only for Cat A bikes. If the frame has a number and no log book it's worth applying for one from the DVLA as it could just have been lost, but it could've been stolen too, as far as the DVLA is concerned the frame IS the bike, the rest of it just bolts in.
Cat B bikes/frames can go back on the road, but not under the original registration, you need to apply to the DVLA they will usually issue it with a new registration number, you take it for MOT and that's that. |
| petemell |
| Rockhopper |
| NSR Mick |
 NSR Mick World Chat Champion
| Phoenix |
The last post was made 18 years, 103 days ago. Instead of replying here, would creating a new thread be more useful? |
