c90 with thumpstar carb
hazza
PostPosted: 10:39 - 19 Jun 2008    Post subject: c90 with thumpstar carb Reply with quote
just got a carb off ebay for my c90 off a thumpstar pitbike thing in the hope for a cheap boost in power. fitted it no problems as they use the same engine etc its just a bigger carb. i didnt expect to get it running perfectly straight away but anyway with this carb fitted it needs choke to start and remain running and i noticed if i put my hand over the end of the exhaust then white smoke comes out of the exhaust. is this something i can sort with ajustment of the mixture screws? what causes this, as you would imagine tickover is very lumpy. or is the issue likley to be jetting?
thanks for any help ill go change back to the standard carb now so i can get to work Laughing
Whosthedaddy
PostPosted: 14:36 - 19 Jun 2008    Post subject: Reply with quote
You may have to experiment with the clip position on the needle to get it to run right rather than the mixture screw.
Took a while on the monkey but change position, go round the block, change again...until pulling, sounding and starting right.
The last post was made 17 years, 250 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 32.13 Kb
