can i use downshifting as a way of braking?
zxcvbnm
PostPosted: 17:33 - 19 Jun 2008    Post subject: can i use downshifting as a way of braking? Reply with quote
can i use downshifting as a way of braking? i would put the cluch in for each gear to. beouse ssome times when i am in gear 2 and i put it in to one the back tire well slide till it goes slow enough for 1 gear. is that bad or what. any suggetions?
ride it like you stole it!
PostPosted: 17:50 - 19 Jun 2008    Post subject: Reply with quote
Yes you can use the engine for braking. However blip the throttle between gears to avoid locking up the back wheel.
Red Mick
PostPosted: 10:45 - 20 Jun 2008    Post subject: Re: can i use downshifting as a way of braking? Reply with quote
zxcvbnm wrote:
...put it in to one the back tire well slide till it goes slow enough for 1 gear. is that bad or what...
This reads as if you are locking up the rear, not a good idea for the tyre, let alone the stress on the chain ( or drive shaft) As has been said, blipping the throttle during the change down will match revs and give the best engine braking.
PostPosted: 11:49 - 20 Jun 2008    Post subject: Reply with quote
I just slip the clutch to bring the revs up, is that bad?
Carl Howell
PostPosted: 12:02 - 20 Jun 2008    Post subject: Reply with quote
Either blip the throttle (which soon becomes natural) or just let the clutch out slowly.
Dom
PostPosted: 12:07 - 20 Jun 2008    Post subject: Reply with quote
Why work the clutch unnecessarily? Plus, blipping sounds ace.
Photos and that
PostPosted: 13:57 - 20 Jun 2008    Post subject: Reply with quote
I do similar to Vincent but I go down the gears letting the clutch out and once I get to first I keep the clutch held in, at this point I'm going at about 5mph. I never put it in neutral when sat at lights etc. I'm trying to do everything like they would teach you on the test.
Carl Howell
PostPosted: 15:02 - 20 Jun 2008    Post subject: Reply with quote
I usually go down into first but that's probably because first will do about 40 so its not like I'm gonna hit the limiter or anything.
ms51ves3 if your practicing for your test don't forget to keep your right foot on the brake and only put your left foot down and always do observations as you pull away. Its all bollocks for real life but needed to pass the test
PostPosted: 16:09 - 20 Jun 2008    Post subject: Reply with quote
Already got that one checked. Though it's really annoying because you have to push my rear brake down a fair bit of it to hold the bike on a hill and my leg starts twitching Laughing
Not been doing the observations though and I still don't have my mirros fitted Whistle
The only time I really do observations is exiting roundabouts and if I'm going down a long straight road just to check if anything is behind me.
I've never ridden with mirrors.
PostPosted: 16:58 - 20 Jun 2008    Post subject: Reply with quote
Down-shifting right down to 1st for engine braking can be very hard on the box, and if you over-rev the engine doing it can be very bad on the valvetrain possibly resulting in skipped teeth and bent valves. Best to work your way down to 2nd and just use 1st for pulling away.
Sparks!
Sir Tart-a-lot
PostPosted: 13:12 - 21 Jun 2008    Post subject: Reply with quote
LukeVFR wrote:
Just slam it down a cog, and then another, and listen to the bitch scream as you're fighting to keep the back end in a straight line -- nothing like it. Cool
Try doing it on a VTR storm Laughing this thing slides sooooo easy, sometimes I forget as I'm coming into a slow corner and bang it down the gears and end up sliding like fook Laughing
The engine braking is so good you could go on a ride without using the brakes if you went a bit slower and planned ahead, not that I would, but it's possible Mr. Green
+1 for blipping on down gears, sounds good, especially on a storm with loud cans Mr. Green
The last post was made 17 years, 282 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.5 - MySQL Queries: 13 - Page Size: 74.43 Kb
