| Smethy |
 Smethy Derestricted Danger
 Posted: 20:08 - 20 Jun 2008 Post subject: yam yz250 no gear select |
10 yrs without a crosser, just got one (mid-life crisis?). 30 mins after going out, it wont select gear - stuck in neutral. Any ideas please. Thanks.  |
| TUG |
 TUG World Chat Champion
| jim-cr 250 |
 jim-cr 250 Nitrous Nuisance
| Smethy |
 Posted: 08:47 - 22 Jun 2008 Post subject: |
Hiya,
The bike is a 2000 yr...I thought I'd start on a cheaper one in case the thrill wasnt there anymore...as if !!!
The bike was running fine, then stalled it, then no gear select. The gear lever does move, but wont select.
Any advice on how I can get it sorted would be much appreciated.
Thanks for the replies.  |
| jim-cr 250 |
 Posted: 11:12 - 22 Jun 2008 Post subject: |
Hi mate, I think it might be worth just taking the right hand side casing off and taking a look at the actual gear selecting mechanism, like i say there is a collor on it which if it falls off it will do the same as what your bike is doing.To have a proper look you have to take the clutch basket off as it gets in the way, you do need a special tool, but if you have a air gun you can just use that, its really straight forward, Do you have a worshop manual?
Anyway im not sure how good you are with engines but when i did mine i took a picture of what it should look like, bare in mind this is a 1995 model but im sure there are probaly the same, it should all look like this, with the collor in place.
Make sure it is all pushed on to it, then just move the gear lever up and down and see if everything moves.
https://i86.photobucket.com/albums/k117/lee125_2006/DSCF6487.jpg
If all looks to be ok them im affriad you might have to split the casings and have a good look inside, its more than likley the problem will be clear, if you have all the basic tools and a windy/air gun it is really straight forward, just a case of remebering what goes where.
Anyway good look, i would deffiantly have a look at the selcter mechnism as in the photo.
Thanks
Jim |
| Smethy |
 Posted: 16:16 - 22 Jun 2008 Post subject: |
Hi Jim - thats great - I'll have a bash and let you know how I get on! Why don't they put photos like that in manuals!
Once again, thanks very much.  |
The last post was made 17 years, 187 days ago. Instead of replying here, would creating a new thread be more useful? |
