Best 10w40 engine oil-4stroke
puremagic72
PostPosted: 18:55 - 24 Jun 2008    Post subject: Best 10w40 engine oil-4stroke Reply with quote
Ok folks, gonna give the gixxer an oil change & Filter since i bought it.
Done oil changes before, but whats the best, money no object, as i want the best out of it.
Castrol, Putoline, Rock oil, Mobil, Silkolene?
Thanks,
Baz.
Thumbs Up Thumbs Up
Make; cbr929cc blade Year; 2001
Gsxr 750 2000, alstare Corona, Current bike 1999 R6
(1) Kids in the back seat cause accidents; accidents in the back seat cause kids.
Itchy
PostPosted: 19:04 - 24 Jun 2008    Post subject: Reply with quote
https://i23.ebayimg.com/04/i/000/f7/48/95ac_1.JPG
I like to use this, for the CBR600
iooi
PostPosted: 19:10 - 24 Jun 2008    Post subject: Reply with quote
£4.99 for a gall supermarket special Thumbs Up
I would just go for any bike approved oil, just because you pay more for it does not mean its any better.....
If you want to pay loads, then buy from you loacl bike shop and not a motor factor such as Halfords Thumbs Up
puremagic72
PostPosted: 19:17 - 24 Jun 2008    Post subject: Reply with quote
Yeah thanks chaps, always bought Castrol for the blade before.
Just wanted other opinions on other oils.
Thanks,
Baz. Thumbs Up Thumbs Up
Trixie
PostPosted: 19:34 - 24 Jun 2008    Post subject: Reply with quote
I've always used Castrol GPS. Thumbs Up
Dead nobodies in company cars...
Phoenix
Twisted Firestarter
PostPosted: 19:52 - 24 Jun 2008    Post subject: Reply with quote
Any of the top brands I think are pretty much all as good as the other. There is definately a difference in cheaper oils as I used Motul for a while from Heine Gericke due to the free filter offer, stopped using it a while ago and went back to Silkolene and the gearchange has improved significantly.
puremagic72
PostPosted: 20:00 - 24 Jun 2008    Post subject: Reply with quote
Thinking of going with Silkolene, might just do that, but there is different types, comp, super, pro...wtf!!
Itchy
PostPosted: 20:20 - 24 Jun 2008    Post subject: Reply with quote
Ross cornered me in his shop once and lectured me about oil ,
I came away with several thoughts:
Cheaper oil often is recycled stuff
Cheaper oil has less additives in it the minimum required.
YMMV of course but I put Shell VSX into me NTV and it took 2300 miles for it to go black , NTVs are incredibly hard on oil and normal plutine 4T ST oil in it, which goes black at 1400 miles (silkolene goes black at 900 miles). Motul I once used went black in 300 miles.
PostPosted: 22:08 - 24 Jun 2008    Post subject: Reply with quote
School of thought that this is actually better. The oil does not really wear out, it is the additives that do. Oil is long chain molecules, and only the weaker of these will be damaged, and then removed when rerefined.
The additives are what wears out, and the lower additive level is the main reason synthetics last longer.
The black stuff is combustion chamber products that have been blown past the rings. Possible the Motul just did a better job of flushing the stuff out left in corners of the engine from previous other oils.
Phoenix
Twisted Firestarter
PostPosted: 22:29 - 24 Jun 2008    Post subject: Reply with quote
Silkolene website will tell you what's what, the comp is semi-synth and super fully synthetic, not sure on Pro. But you just want the 10w40 semi-synth for 4strokes which I'm sure is the Comp 4, start messing with fully synth and you risk introducing clutch slip and maybe small oil leaks and i'm not sure there is any benefit to it.
aletank
PostPosted: 22:40 - 24 Jun 2008    Post subject: Reply with quote
Would the 0w40 Mobil 1 fully synthetic that Costco sell for about £24 inc vat for 4 litres be any good for bikes ?
2004 05 Plate Yamaha R6, Mistral Black - SOLD
2009 Triumph Street Triple 675 R, Matt Graphite - SOLD
Phoenix
Twisted Firestarter
PostPosted: 23:14 - 24 Jun 2008    Post subject: Reply with quote
It's car oil and althought it'd work you're supposed to be using 10w40 not 0w40. Plus fully synth car oil in a bike with wet clutch, might work alright, might not. Most bike oils are about £28.
PostPosted: 06:54 - 25 Jun 2008    Post subject: Reply with quote
I've used Castrol Power1 superbike with no ill effects(yet) in the track bike.
PostPosted: 08:22 - 25 Jun 2008    Post subject: Reply with quote
I have used car oils (including synthetic car oils) in bikes without the clutch slipping loads of times.
aletank
PostPosted: 11:27 - 27 Jun 2008    Post subject: Reply with quote
I was just lookin at the different oils on the Halfords web site and was wondering between these 2 (Car & Bike Oils)
Mobil Super S 10w/40 5 Litres £23.99, Semi Synthetic Motor Oil
and
Halfords Motorcycle Engine Oil 10w/40 5 Litres £21.99, Part Synthetic
Would I be right in thinking that the Mobil Super S would be the better buy even though it doesn't mention motorcycles?
PostPosted: 12:22 - 27 Jun 2008    Post subject: Reply with quote
Both oils seem to comply to the same API and ACEA ratings. Neither mention comlpying with the motorcycle specific ratings (although plenty of bikes do not specify motorcycle specific oils). To be honest, beyond the alure of the brand names and the price difference there doesn't seem to be any detail available to choose between them.
Specs for that Halfords oil:-
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_221725_langId_-1_categoryId_129492
Specs for that Mobil oil:-
https://www.mobil.com/UK-English/Lubes/PDS/EUXXENPVLMOSuperS.asp
ACEA oil specs:-
https://www.acea.be/images/uploads/pub/070308_ACEA_sequences_2007_LD_and_HD.pdf
Phoenix
Twisted Firestarter
PostPosted: 12:42 - 27 Jun 2008    Post subject: Reply with quote
Halfords oil is Esso/Comma
ZRX61
Victor Meldrew
PostPosted: 17:52 - 27 Jun 2008    Post subject: Reply with quote
Mobil 1 MX4T. My bike has used this since it had about 10,000 miles on it.. & the inside of the engine looks new. Altho they have been checked, the valves haven't needed any adjustments for the past 50,000 miles.. & it doesn't use any oil between changes, in 81,000 miles I doubt it has used more than a pint in total...
sickpup
Old Timer
PostPosted: 18:15 - 27 Jun 2008    Post subject: Reply with quote
Please explain?
The last post was made 18 years, 87 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 108.05 Kb
