Gunson's Carbalancer, Help!
Thom
PostPosted: 18:15 - 24 Jun 2008    Post subject: Gunson's Carbalancer, Help! Reply with quote
https://www.gunson.co.uk/items/pdf/Products/G4053_Instructions.pdf
These are the instructions.
Those instructions DO NOT work on my GS500e for what appears to be two reasons, unless i use an alternative fuel delivery system in place of the tank, i only have limited access to the carbs, and secondly the mixture is simply too lean to even idle.
How can i use this device to sync my carbs?
Any advise would be great as i quite wanna sort the engine downpipe temperature difference problem thingy!
PostPosted: 18:35 - 24 Jun 2008    Post subject: Reply with quote
Never seen anything like that before. I would say it's not working because it's crap.
Thom
PostPosted: 18:41 - 24 Jun 2008    Post subject: Reply with quote
£15 i can afford it to be to be honest!
I reckon, and this is just a theory, by removing that spinny roundy thing and just using the guage and pipe, i can connect it to the vacuum on the carb and get a measurement of the 'good' side of the bike and then try and replicate that figure on the other side.
PostPosted: 19:42 - 24 Jun 2008    Post subject: Reply with quote
What you could do is put two vac tubes to a tee-piece then connect it to the device. To test the balance just pinch first one tube then the other to get readings off either carb, and you'll be able to quickly compare readings.
Thom
PostPosted: 06:24 - 25 Jun 2008    Post subject: Reply with quote
that aint a bad idea!
Just need to find a 'T' Piece now!
Rockhopper
PostPosted: 07:31 - 25 Jun 2008    Post subject: Reply with quote
Think i only paid £30 to my dealer the last time i had my (four) carbs balanced on the GSX750F.
That Gunsons thing does look a bit crap to be honest!
Ichy
PostPosted: 08:17 - 25 Jun 2008    Post subject: Reply with quote
I've got one and used it plenty of times, on a car. Its ok on a bike with pod filters but the amount of effort required to remove the air box just isn't worth it on a bike.
If you want to be cheap just make your own.
https://regionb.tripod.com/tech_tips.htm#Carb%20Tool
https://www.powerchutes.com/manometer.asp
https://www.vfrdiscussion.com/forum/lofiversion/index.php/t16200.html
Thom
PostPosted: 09:29 - 25 Jun 2008    Post subject: Reply with quote
hmmm yeah it seems it could actually be a bit too sensetive as when i connected it upto the vacuum it just shot all the way up, obviously that isnt how it was meant to be used but nvm!
I think what im going to do is finally give in to the men in the garages and ask them to do a full service of the bike including carb balancing.
I must admit i adjusted the screw thingy and it did stop the revs sticking at 3k which is good!
PostPosted: 17:08 - 25 Jun 2008    Post subject: Reply with quote
I got loads of old brass tee-pieces for vac lines send me your addy and I'll post one off to you. Let me know if you want 4mm or 6mm.
hmmmnz
PostPosted: 21:28 - 25 Jun 2008    Post subject: Reply with quote
dont use the plastic peices just use the tube and plug in into the vacuum plugs, (they are on the top cap part of the carb, under a little rubber bung)
remove the bung, poke on the hose, take a measurement,
do the other side, and adjust accordingly.
that way the air box stays on the bike,
all you need is a temp fuel tank (a small coke bottle with a hole in the lid with a hose poked in)
10 min job max,
the humans are dead
I kick arse for the lord
Thom
PostPosted: 06:45 - 26 Jun 2008    Post subject: Reply with quote
hmmmmnz, i did try it that way but the reading just shot straight upto the top of the gauge, however it was pretty steady, if i adjusted the balance at all the reading would go right up but jump from anywhere between 3 and 5 on the scale, yet very quickly.
I think i need a decent balancer...
PostPosted: 18:38 - 26 Jun 2008    Post subject: Reply with quote
That's because there is no damper on your device. Most carb balancers have a restrictor in the line to slow down the passage of air to the gauge so that it gives you a reading of average vacuum rather than reading it in real-time, which could damage the dial. You could try putting a restrictor into the tube something like a carb jet, a blockage with a tiny hole in it. That will stop it oscillating, but won't cure the "flying off the top of the gauge"
Thom
PostPosted: 19:01 - 26 Jun 2008    Post subject: Reply with quote
aye, reckon i'll leave this to the pro's Razz
hmmmnz
PostPosted: 19:46 - 26 Jun 2008    Post subject: Reply with quote
make some,
i use 2 small bottles, some clear cable a couple of cable ties and some water
works like magic, by far and away the best balancers ever
Very Happy
https://i58.photobucket.com/albums/g257/hmmmnz/balanncer.jpg
make sure that the water level is less than half the over all volume, so you dont suck water into the carb...
or just fill one side 4/5 full
the humans are dead
The last post was made 18 years, 99 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.21 - MySQL Queries: 13 - Page Size: 86.21 Kb
