| Thom |
 Thom World Chat Champion
 Posted: 18:15 - 24 Jun 2008 Post subject: Gunson's Carbalancer, Help! |
https://www.gunson.co.uk/items/pdf/Products/G4053_Instructions.pdf
These are the instructions.
Those instructions DO NOT work on my GS500e for what appears to be two reasons, unless i use an alternative fuel delivery system in place of the tank, i only have limited access to the carbs, and secondly the mixture is simply too lean to even idle.
How can i use this device to sync my carbs?
Any advise would be great as i quite wanna sort the engine downpipe temperature difference problem thingy! ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
Previous Bikes: 1990 Honda NSR125 'Rothmans' (The smoking one), 1990 Suzuki GS500e 'Caf? fighter' (The loud one), 1987 Kawasaki GPX400r (The quick one), 1997 XJ600s Diversion (The reliable one), 2000 Kawasaki ER-5 (The spontaneously combustive one) |
 Posted: 18:35 - 24 Jun 2008 Post subject: |
Never seen anything like that before. I would say it's not working because it's crap. ____________________ a.k.a 'Geri'
| Thom |
 Posted: 19:42 - 24 Jun 2008 Post subject: |
What you could do is put two vac tubes to a tee-piece then connect it to the device. To test the balance just pinch first one tube then the other to get readings off either carb, and you'll be able to quickly compare readings. ____________________ a.k.a 'Geri'
| Thom |
| Rockhopper |
 Rockhopper Trackday Trickster
| Ichy |
 Ichy World Chat Champion
| Thom |
 Posted: 17:08 - 25 Jun 2008 Post subject: |
I got loads of old brass tee-pieces for vac lines send me your addy and I'll post one off to you. Let me know if you want 4mm or 6mm. ____________________ a.k.a 'Geri'
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 21:28 - 25 Jun 2008 Post subject: |
dont use the plastic peices just use the tube and plug in into the vacuum plugs, (they are on the top cap part of the carb, under a little rubber bung)
remove the bung, poke on the hose, take a measurement,
do the other side, and adjust accordingly.
that way the air box stays on the bike,
all you need is a temp fuel tank (a small coke bottle with a hole in the lid with a hose poked in)
10 min job max, ____________________ the humans are dead
I kick arse for the lord
| Thom |
| Thom |
 Posted: 19:01 - 26 Jun 2008 Post subject: |
aye, reckon i'll leave this to the pro's  ____________________ Current Bike: 1996 Yamaha TRX850 (The Japanese-Ducati One).
| hmmmnz |
The last post was made 18 years, 100 days ago. Instead of replying here, would creating a new thread be more useful? |
