QUICK IDLING QUERY
stirlinggaz
PostPosted: 19:49 - 24 Jun 2008    Post subject: QUICK IDLING QUERY Reply with quote
hi all,
my ch*nky 4t is idling too high, at around 3000rpm!
but if i turn out the idle adjust screw, it drops then dies. (& then i have trouble starting it & when started i have to keep revving it or it will conk out!)
turning it the other way & it idles higher.
any suggestions?
cheers,
GAZ
PostPosted: 20:36 - 24 Jun 2008    Post subject: Reply with quote
Adjust the mixture screw. Could be running too rich and flooding the engine.
stirlinggaz
PostPosted: 21:06 - 24 Jun 2008    Post subject: Reply with quote
hi,
& thanks, you just confirmed what i was thinking.
plug is black & sooty.
did adjust mixture screw, just half a turn or so, but plugs still black.
so will i keep adjusting till its a bit better?
cheers,
GAZ
PostPosted: 21:50 - 24 Jun 2008    Post subject: Reply with quote
stirlinggaz wrote:
hi,
cheers,
GAZ
Yes. Just remember how many turns you have done so you can put it back to where it was when you got it. Just keep adjusting it until it ticks over at about 1000-1500rpm.
bagger
PostPosted: 00:51 - 25 Jun 2008    Post subject: Reply with quote
sounds like the choke is on? is it correctly set?
stirlinggaz
PostPosted: 11:13 - 25 Jun 2008    Post subject: Reply with quote
hi,
no choke isnt on.
that was my 1st thought, so i even disconnected choke cable.
then removed airbox so i could see the choke flap (dunno the technical term, butterfly?)
choke mechanism is working fine.
ie it is open until i pull the lever, when it closes & it re-opens fine.
cheers,
GAZ
paddlesat16
PostPosted: 11:17 - 25 Jun 2008    Post subject: Reply with quote
Have you tried cleaning the air filter, could be clogged up..
I once saw a bloke shagging a donkey.... in Saudi arabia. Theory Test Passed 26/10/09 Mod 1 Passed 26/4/10, Mod 2 Passed 7/6/10 Current Bikes Suzuki GSX1400 K5, Aprillia Pegaso 650, Suzuki DR350T.
stirlinggaz
PostPosted: 11:45 - 25 Jun 2008    Post subject: Reply with quote
hi,
its been idling high since i got it.
fully serviced the bike when i got it at 1000 miles.
including removing carb & cleaning out thoroughly, cleaning the filter.
does it with airbox on or off.
UPDATE :just checked my plug, very clean, & insulator is white, metal tip is whithish/grey, this indicates a bit lean, right?
so now im stumped!
cheers,
GAZ
The last post was made 18 years, 117 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.64 - MySQL Queries: 13 - Page Size: 56.19 Kb
