| L3G3ND_MTX |
 L3G3ND_MTX Spanner Monkey
| stirlinggaz |
 stirlinggaz World Chat Champion
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 20:48 - 24 Jun 2008 Post subject: |
do you still have the stock exhaust? its probably restricted.
is the powervalve on the right way? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| L3G3ND_MTX |
| stirlinggaz |
 Posted: 21:30 - 24 Jun 2008 Post subject: |
My bike is 2007 model, i have the rave unit and it ISNT plugged in, i cant find where to plug it in, you say it plugs into the solonoid itself, from all the reading up i did its supposed to plug into a wire near the rear seat end coming out of the main loom but i cant find the plug anywhere its just not there? ill check tomorrow if it actually plugs into the solonoid.
Yes the valve is the correct way around i need to know where the rave unit plugs in as i dont have it plugged in yet thats the only thing im struggling with.
hi,
you could be right...
the black pv controller should have a cable coming from it with a white plug on it,
where does it plug into (follow it)
if it plugs into the loom, then your right & you should be following the loom for a spare outcoming cable/plug.
there is a cable coming from solenoid, right? have you plugged this into anywhere?
so you need to connect the solenoid to the rave controller.
im sure on mine the cable/plug was on the right side, under tank, just above the carb.
sure you will find the plug!
hope this helps.
cheers,
GAZ |
| L3G3ND_MTX |
 Posted: 21:42 - 24 Jun 2008 Post subject: |
I have followed the loom and i cant find any wires that match the Rave unit plug (the rave unit plug is a 6 quite wide pinned plug, 3 on top and 3 under like a dice).
Ive plugged the solonoid etc. in ive already mentioned that and not worried about that because i know everything is fitted properly EXCEPT the rave unit, ive checked EVERYWHERE for this connector and cant find it.
Does the rave unit actually plug directly into the solonoid unit (the little motor looking thing) or does it plug in somewhere under the back seat like it says everywhere i look?
Ive plugged the cable the comes from the solonoid into the correct plug it needs to go in, and the other cable from the solonoid is connected to the power-valve, im just looking for the one that the rave unit plugs into?
Thanks for the help so far  |
| MaybeGuy |
 Posted: 22:49 - 24 Jun 2008 Post subject: |
shit i have a stalker
post a pic of your bike.
im a mechanical engineer, and have built a few bikes and restored a few others... i know a little. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| stirlinggaz |
| L3G3ND_MTX |
 Posted: 23:11 - 24 Jun 2008 Post subject: |
Ok thank you for the information that has helped me alot, and yes it does plug into a female plug, that info helps alot saying its cable tied (might be the reason i didnt spot it) and i will do matt, ill put one up of me on the bike so you know what i look like, mainly black and red leathers with a white shoei helmet with iridium visor, riding new model red+black RS 125 (bit bashed up with some duct tape and stuff) if you see me maby we can stop for a chat or what ever, im called jamie just so you no and dont feel a plank asking my name
Ill have another look tomorrow and ill post pic up tomorrow thanks for the info its greatly appreciated. |
| stirlinggaz |
| L3G3ND_MTX |
 Posted: 16:13 - 25 Jun 2008 Post subject: |
Yes, ive found out from the dealer that my 'model' doesnt even have the connector which doesnt make sense as it has the connectors for the solonoid and the power-valve just goes straight in.
Ive ordered a new wiring loom now from a 2006 model which will fit mine and it has the rave unit plug on it so sorted and it only cost me £23 from ebay thats including P&P and my deal wanted over £150 for wiring loom
Thanks for all your help on this guys its greatly appreicated!
Jay. |
The last post was made 18 years, 109 days ago. Instead of replying here, would creating a new thread be more useful? |
