| TUBZ69 |
 TUBZ69 Trackday Trickster
 Posted: 14:15 - 25 Jun 2008 Post subject: starting zx6r (2001) |
its bin sitting for a few months with the tank off and emptied, ive connected the tank, filled it with bout 5litres of fuel, charged the battery and tryed to start it up, electrics work, alarm, lights (although the right hand headlight is dead!) indicators all work, but wont kick over yet. just the dreaded solunoid click!!
wot im thinking is prehaps there is fuck all fuel in the lines/carbs and therefore it will struggle to ignite atm, also wen i turned the key the lights all came on because i forgot to turn them off as this will drain power right?!! especially wen its guna need all the power it can giv wen startin a bike thats bin dry and sitting for a while.
so ive bin pumping the throttle to try an force some fuel in the lines and now im charging the battery again, and hopefully it will be gravy 2mora?
just wonderin if anyones got any thoughts/advice
thanx
Toby ____________________ those who risk nothing, become nothing, achieve nothing....
c90 rvf 400, vfr 400, gpz 500, Gsxr 750, R1, Zx6r.... |
| Pie-Roe |
 Pie-Roe World Chat Champion
 Posted: 15:24 - 25 Jun 2008 Post subject: |
Charge the battery tonight, don't bother pumping the throttle.
Is it 'coughing' at all trying to catch?
If you have it, try the position 'pri' for prime on the fuel tap.
Pyro ____________________ Previous: GSF600, FZR600 x2, ZXR750, XT600 Tenere, CB125, CZ125, ETZ 250, ER5, CCM R30, DRZ400, RF600x4, RF900x2, GS500, VTR1000F, 640 SMC, CB250 NIGHTHAWK, GT550x3, GPX750 TE610, CB500, X11x2, SV650, ZING 125, TL1000R,CB250 Superdream, CBR1100XX |
| Cigaro |
 Cigaro World Chat Champion
| TUBZ69 |
 Posted: 17:18 - 25 Jun 2008 Post subject: |
| pyroforlife wrote: | Charge the battery tonight, don't bother pumping the throttle.
Pyro |
nope no coughing at all, just literally the solunoid relay clicking over, il try chargin it again and jumping it from the other halfs car and see if that works.
The fuel tap only has 'off' 'on' and 'res' no 'pri' ____________________ those who risk nothing, become nothing, achieve nothing....
| TUBZ69 |
 Posted: 17:25 - 25 Jun 2008 Post subject: |
| TheBassJunky wrote: | If it's not turning over at all then that means either the battery isn't properly charged, or the starter is fecked (unlikely). Remember that batteries can and do go bad when they've been left for a while, so you may need a new battery.
Give it a jump from a car - if she starts, take her for a good long ride. If the battery is still dead, get a new one.
And yes, try the 'prime' position if it has one, but if not it should still eventually pull fuel through on its own if you crank it over long enough. |
taking it out for a spin is out of the question as its not road worthy atm.
i got the battery brand new bout a yr ago, maybe less actauly, but only used it once to turn this bike over in a less rebuild guise about 4months or so ago and it started ok then (eventually ! ), so it has bin sitting doin nuthin for a while, but it isnt an old battery?
Fuel is gettin through think, i took the fuel filter on the fuel line off an blew through it, no shit in there, lines seem to be clear etc.... ____________________ those who risk nothing, become nothing, achieve nothing....
| Aikman666 |
 Aikman666 World Chat Champion
 Posted: 18:57 - 25 Jun 2008 Post subject: |
I'd say go for bypassing the starter solanoid. That will tell you if your solanoid or your starter is dead.
Are you sure all things like sidestand switches, neutral switches etc. have been reconnected? ____________________ Will work for petrol
My Design Blog |
| TUBZ69 |
 Posted: 19:23 - 25 Jun 2008 Post subject: |
| Aikman666 wrote: | I'd say go for bypassing the starter solanoid. That will tell you if your solanoid or your starter is dead.
Are you sure all things like sidestand switches, neutral switches etc. have been reconnected? |
yea i havent altered the bike electrically since i started it last, so should be same as, how do i bypass the solanoid? ____________________ those who risk nothing, become nothing, achieve nothing....
| Cigaro |
| TUBZ69 |
 Posted: 18:39 - 26 Jun 2008 Post subject: |
| TheBassJunky wrote: | | TUBZ69 wrote: | i got the battery brand new bout a yr ago, maybe less actauly, but only used it once to turn this bike over in a less rebuild guise about 4months or so ago and it started ok then (eventually ! ), so it has bin sitting doin nuthin for a while, but it isnt an old battery? |
Doesn't matter - if it's been sitting for ages then it could quite easily be buggered.
Especially if you charged it once and then let it run down. I have batteries that don't work any more because I did that to them.
Like I said - try jump-starting it and I bet it will run. |
cock on it mate , jumped it 2day and it fired up, a little rough to start, but came up to temp ok, fan kicked in bout 102c as it should. but i think battery is fooked, as wen i take the jump leads off the bike dies?
gear selection seems as little groggy ( ive fitted rearsets, and pulled the clutch in an knocked it into 1st and it struggled to go back to neutral?)
also sounds a little stupid, but with the engine idleing and in neutral the front sprocket is dead still as u would expect, but wen i played with the throttle a bit it moved in time with the revs speeding up as i rev higher as if it were in gear? is that right?! i havent got the chain connected atm obviously.... ____________________ those who risk nothing, become nothing, achieve nothing....
| Grav |
 Grav World Chat Champion
 Posted: 23:25 - 26 Jun 2008 Post subject: |
Nowt wrong with the sprocket moving when you blip the throttle in Neutral, it's a perfectly normal thing to happen. Nowt to worry about there. ____________________ Dark Lord Of Custard
snigger.....  |
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| TUBZ69 |
The last post was made 18 years, 94 days ago. Instead of replying here, would creating a new thread be more useful? |
