cam chain rattle
philone
PostPosted: 20:10 - 26 Jun 2008    Post subject: cam chain rattle Reply with quote
hi i have a 96 fireblade with 19000 miles on her. at 18000 mile i changed the cam chain tesioner for a new gen honda one. the rattles come back but only on tickover then worming up then is ok,do the chain wear on this milage or just a duff tensioner?
mad4it028
PostPosted: 20:14 - 26 Jun 2008    Post subject: Reply with quote
on my cbr i changed the cct rattle came back so i changed the chain rattle came back i got another cct rattle came back so i opened up the cct and put a stronger spring init was fine after that but that was a cbr 600 not 900
philone
PostPosted: 20:24 - 26 Jun 2008    Post subject: Reply with quote
thanks for the reply,a stronger spring sounds good ,can you get them or did you just makeup your own?
mad4it028
PostPosted: 20:38 - 26 Jun 2008    Post subject: Reply with quote
ok 1st off if you do what i did and all goes tits up not my problem all im saying is what i did and worked for me
i think the spring i used was a escort front pipe spring it was an exhaust spring of some kind anyway
it fitted over the standard spring ie standard spring was inside escort spring so both springs worked
i covered 5000 miles like this with no problems and no rattles then i sold/swapped it with still no rattles
if you do try it make sure theres no whines when you start it up if there is then its too tight and you need a lesser spring
becarefull engines arnt cheap
PostPosted: 06:39 - 27 Jun 2008    Post subject: Re: cam chain rattle Reply with quote
Tensioners can go that quickly in honda's unforunately, the one in my hornet race bike is on the way out, I'm going to put a a manual one in there in the winter.
This one:
https://www.debben.co.uk/acatalog/CBR900R.html
It will fit your bike, it's similar money to the Honda OE replacement anyway. Thumbs Up
mad4it028
PostPosted: 06:53 - 27 Jun 2008    Post subject: Reply with quote
i made a maual tensioner but to be honist it did my head in have to keep adjusting them and too easy to over tighten
DONT use a spanner to adjust if you do use one just finger tight and then lock off the lock nut with a spanner
philone
PostPosted: 20:16 - 27 Jun 2008    Post subject: Reply with quote
cheers big-ham,manual it is then Smile
The last post was made 18 years, 85 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.93 - MySQL Queries: 13 - Page Size: 52.11 Kb
