Wiring a Cigarette lighter to your battery.....
AngelGrinder
PostPosted: 13:40 - 21 Jul 2008    Post subject: Wiring a Cigarette lighter to your battery..... Reply with quote
As per the title, I shall be wiring a cigarette lighter to my battery so I can charge my phone when I'm away at the Isle Of Man in a few weeks.....I'm going to head down to maplin shortly....
I will be buying this -
https://www.maplin.co.uk/Module.aspx?ModuleNo=1056&criteria=car%209v%20extender&doy=21m7
or this
https://www.maplin.co.uk/Module.aspx?ModuleNo=97951&&source=14&doy=21m7
What else do I need to buy.....and if anyone's done it before, please let me know how! Karma
Cheers.
kawakid
PostPosted: 14:26 - 21 Jul 2008    Post subject: Reply with quote
Hi,
If it were me doing this (I intend to do so, to use my car's Tom Tom).
I would use a relay.
You would also need an fuse, something like an inline fuse, can be bought from a car dealer for about £1. I'd probably go for quite a low ampage, a car charger doesn't require much.
The relay, allows the power to flow only when your ignition is on, thus removing the risk of the battery draining out.
A relay will cost you about £4
I did some instructions before on heated grip fitting, this would be just the same. I'll see if I could find them.
I've a twin and a 4.
kawakid
PostPosted: 14:36 - 21 Jul 2008    Post subject: Reply with quote
Follow this all you should need.
https://www.bikechatforums.com/download.php?id=52798
AngelGrinder
PostPosted: 15:39 - 21 Jul 2008    Post subject: Reply with quote
Cheers for the replies, managed to find one at the store that has a battery level reader and shut off when battery is low. Will probably put a 10amp fuse in the circuit and connect it up to the battery!
Kal
PostPosted: 15:57 - 21 Jul 2008    Post subject: Reply with quote
Go on Angel, chuck up a link - you know you want to... Wink
Kal...
AngelGrinder
PostPosted: 17:57 - 21 Jul 2008    Post subject: Reply with quote
https://www.maplin.co.uk/Module.aspx?ModuleNo=37962&criteria=car%20charger&doy=21m7
Cheaper than the original products aswell!
I'm told all you need to do is open the male end of the plug and get the two wires, the main one going to the centre connector of the plug goes to the +ve and the other wire goes to the -ve of the battery.....and that should work!
The Tot
PostPosted: 23:54 - 21 Jul 2008    Post subject: Reply with quote
Mine's 11 quid from Hein Gericke and was wired straight from the battery using an inline fuse. I didn't use a relay or a switch so that it would protect the circuit. Having said that, I don't run a battery so it doesn't matter much to me.
Never argue with autism
PostPosted: 01:07 - 22 Jul 2008    Post subject: Reply with quote
I made one, I have a switch an in line 5amp blade fuse and a 3 way cigarette socket adaptor.
I adaptor was bought from lidl for about £3 it was a male ciggy socket into 3 female sockets I cut the male part off then connected one end to the neutral and the other the switch then the fuse then the battery, it has been solid for months I have even moved it across bikes. Total cost was about £5 not including the conectors I already have, it's not particulary tidy but works I have it under my seat and plug my phone and satnav into it.
scanny
PostPosted: 15:14 - 23 Jul 2008    Post subject: Reply with quote
iv had an ex threaten to do that to me before https://www.v-rodforums.com/forums/images/smilies/rofl3.gif
deanoet
PostPosted: 15:49 - 23 Jul 2008    Post subject: Reply with quote
i used this website when i wanted power into a tankbag for a sat nav
Works really well. Probably a bit more expensive than maplins solution, but it is waterproofed, in a tankbag, and i have ridden through snow and hail with no problems with it leaking.
Ends in a standard cig lighter in the tank bag so can be used for anything really.
I posted some pics of the setup a while ago
My setup about 2 thirds the way down that page
Tavares
PostPosted: 16:03 - 23 Jul 2008    Post subject: Reply with quote
something like this, from ebay would be the easiest option.
the wires don't look up to much tho, but it has all the basics you would need.
Cool
sanchezz_182
PostPosted: 17:08 - 23 Jul 2008    Post subject: Reply with quote
Just a note be carefull what you run though it and what else you are running, lights ect. Or you mite end up with a dead battery in the middle of a french motorway at 3 oclock in the morning. Laughing
no sig, thats gay!!
Mjolnir
PostPosted: 18:13 - 23 Jul 2008    Post subject: Reply with quote
Don't know if it's any help or not but I did the same thing a while ago so that I could plug a GPS into the bike.
I made this thread about it in the workshop and got some great help.
https://www.bikechatforums.com/viewtopic.php?t=149703&highlight=
I took a list of the things I found that I needed to maplin and got one of the guys there to find all the stuff for me.
I used a switch rather than the relay wired into the back lights. It was a bit easier for me but remember to turn it off when you aren't using it. I suppose a relay would be more useable.
I nicked the diagrams from someone else and they were pretty handy. It worked too, even though I made the thing. You can see my results at the end of the thread.
Stelmer
PostPosted: 22:24 - 23 Jul 2008    Post subject: Reply with quote
I used an old temporary accessory connector from Motosave. It connected directly to a car battery and is rated at 15amps.
Choped the croc clips off, 5amp inline fuse in to replace the 15amp and wired into the battery. I plug a maplins 1AH solar pannel into it when the bike isn't in use.
sickpup
Old Timer
PostPosted: 23:00 - 23 Jul 2008    Post subject: Reply with quote
That makes no sense! Confused
Tricolor Fan
PostPosted: 00:22 - 24 Jul 2008    Post subject: Reply with quote
I've just skimmed through the thread, but I don't think anyone has mentioned this!! Might be the easiest option, especially if you already use an optimate.
Give me ambiguity or give me something else.
Carl Howell
PostPosted: 10:17 - 25 Jul 2008    Post subject: Reply with quote
Looks the best option so far. Can use it on any bike with the connector and link it up in about 30 seconds.
PostPosted: 10:30 - 25 Jul 2008    Post subject: Reply with quote
If you want to make something like that yourself then you can buy the Optimate connectors as they are just battery connectors used in Tamiya radio control cars (although they use the +ve & -ve the other way round so take care wiring it up).
The last post was made 17 years, 268 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.16 - MySQL Queries: 13 - Page Size: 100.44 Kb
