Problem :\ :\ ??
SpeedfightBoi
PostPosted: 11:18 - 26 Jul 2008    Post subject: Problem :\ :\ ?? Reply with quote
Hi,
I have been riding my ped all day today, reaching speeds of well over 50mph quite frequently. The thing is I was partly on my way through a 15 mile round trip when I went down this hill and clocked about 60 mph...The hill then levelled out and my speed dropped drastically to around 30/35 mph....It felt as if the bike was bogging out and the bike would not respond to all the throttle I was giving it....I pulled into the side for around 30 secs, revving the bike then set off and it was right as rain...I could have cruised all day at 40mph but as soon as I went over 50, it would slow to 35 and bog out....I recently had a Malossi Variator put in (well 24 hours prior to this) but it has been running fine for around 4 hours prior to this. Also there was a strange ringing/Howling/Whistling noise coming from I think my clutch...What is this??
Has anyone got any suggestions as to what happend to my ped? Or was it just sheer over-heating??
Thanks in advance
SpeedfightBoi
PostPosted: 21:13 - 26 Jul 2008    Post subject: Reply with quote
Been out today, was alright for ten minutes, Then after that as soon as i went over 50 it would bog out to 30/35 Sad
Help!!!
PostPosted: 21:33 - 26 Jul 2008    Post subject: Reply with quote
Overheating? It's just a stab in the dark though.
Is it air or liquid cooled.
When you go really fast down hills are the revs gradually increasing?
SpeedfightBoi
PostPosted: 21:47 - 26 Jul 2008    Post subject: Reply with quote
Air cooled, I was kinda hoping it had overheated but i only took it for a ten minute spin this morning, it was fine until after ten minutes so i brought it back home A.S.A.P
SpeedfightBoi
PostPosted: 21:59 - 26 Jul 2008    Post subject: Reply with quote
I have the original speedfight clutch spring in, The bike is totally standard apart from malossi variator and leo vince tt exhaust
Not even sure whether it got upjetted Confused
PostPosted: 11:10 - 27 Jul 2008    Post subject: Reply with quote
Pop the air box off and the air intake off. Two 8 mm bolts hold the carb on, undo them. Unscrew the float bowl which is held on by 2 screws. Undo the main jet (the large one in the middle) and have a look for a number on it. It should be 74, if it isn't you need to buy one Thumbs Up
Cigaro
PostPosted: 11:30 - 27 Jul 2008    Post subject: Reply with quote
It sounds like it may be the drivebelt?
When you say it 'bogs', does the engine bog at all, or does it just slow down for no real reason?
Is it a 50cc?
They seem to be about £20 on Ebay so as long as you fit it yourself it won't be expensive.
Finglonga
PostPosted: 14:19 - 27 Jul 2008    Post subject: Reply with quote
What state is the plug in?
Andy Sez....
F.Y.Y.F.F.
SpeedfightBoi
PostPosted: 17:04 - 27 Jul 2008    Post subject: Reply with quote
Hiya, I went out on it today, did about 5 mile on it, reaching over 50mph on three or four occasions - it was fine...Then after ten minutes i went over 50mph again and the bike bogged down again Sad
I dont think it is the plug as i fitted an iridium sparkplug in about 4 weeks ago, It feels as though the engine is being choked/ or the exhasut is being choked (Thats what it feels like anyway)
When i initially installed the malossi variator it was ok for a day or two, then this one time it just bogged out when i hit 50
Oh, yeah its 50cc
MaybeGuy
PostPosted: 17:25 - 27 Jul 2008    Post subject: Reply with quote
________________________
on a lighter note. i bet your sparkplug is shagged.
Naggedalot
PostPosted: 17:34 - 27 Jul 2008    Post subject: erm... Reply with quote
have you checked you have oil in it..or even the right oil in it?
SpeedfightBoi
PostPosted: 17:39 - 27 Jul 2008    Post subject: Reply with quote
Yes mate, plenty of that castrol scooter oil from halfords.
PostPosted: 17:43 - 27 Jul 2008    Post subject: Reply with quote
Point of checking the plug is to see whether it is a nice biscuit brown (jetting about right), black and messy (running rich) or blistered and white (running lean, with the piston probably about to seize).
SpeedfightBoi
PostPosted: 20:59 - 27 Jul 2008    Post subject: Reply with quote
Jeez, Hope it isnt the piston Crying or Very sad
Only an 07 bike
So say if the plug is white like you said...What do i do then?
PostPosted: 21:05 - 27 Jul 2008    Post subject: Reply with quote
White blistered plug is a sign of running way too lean. You need to richen the mixture up. Main jet only affects very large throttle openings, and you replace it with a larger one. For mid range you need to adjust the position of the needle or change to a different needle.
SpeedfightBoi
PostPosted: 21:13 - 27 Jul 2008    Post subject: Reply with quote
Thanks Keith for all the help
One more thing; Could it be anything to do with either the belt? Or clutch
Just trying to discount certain things Question
Thanks again
PostPosted: 21:35 - 27 Jul 2008    Post subject: Reply with quote
To be honest I have next to no experience of scooter transmissions (going for the clutch and locking the back wheel isn't fun), but I would doubt it.
Finglonga
PostPosted: 21:43 - 27 Jul 2008    Post subject: Reply with quote
Only an 07 bike
I am afraid that's what you need to expect when you de-restrict a engine.
But don't panic till you check your plug. Or best to try a new one, don't bother with iridium though unless you like throwing your money away.
Andy Sez....
F.Y.Y.F.F.
Spit-Fire
PostPosted: 08:40 - 28 Jul 2008    Post subject: Reply with quote
LOL! indeed,
going for the back brake and clutching in aint fun ever Wink
they say the good die young... i say we just live faster
SpeedfightBoi
PostPosted: 17:36 - 29 Jul 2008    Post subject: Reply with quote
Went out again on it today
Was fine for 10 mins, went over 50mph n it was good
Then it happened again, went over 50 and it bogged out to 35 Sad
Help
Finglonga
PostPosted: 17:44 - 29 Jul 2008    Post subject: Reply with quote
Andy Sez....
F.Y.Y.F.F.
The last post was made 17 years, 346 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.81 - MySQL Queries: 13 - Page Size: 111.01 Kb
