125 intruder - stalling when knocked into 1st?
getaf1x
PostPosted: 19:48 - 30 Jul 2008    Post subject: 125 intruder - stalling when knocked into 1st? Reply with quote
Can any bods suggest any causes for my bike stalling when I knock it in gear?
, Starts fine...idles fine...but as soon as I try to knock it into first (with the clutch lever pulled in) it stops dead like i've hit the kill switch (which i haven't Smile)
Its been standing for 36 hours and it got rained on a bit.
Could the clutch be gummed. Any thing I can try to find the cause & then fix?? I have tried giving it a good kicking.no joy.
any help is much appreciated
Cheers getafix
cyberglass
PostPosted: 20:15 - 30 Jul 2008    Post subject: Reply with quote
Is your side stand down ??
My bikes engine will switch off if you stick it in gear with the side stand down
djaaron
PostPosted: 20:23 - 30 Jul 2008    Post subject: Reply with quote
if the side stand is not down look at the wire's and see if any are cut .
Carl Howell
PostPosted: 20:26 - 30 Jul 2008    Post subject: Reply with quote
Does it jump as if you have stalled? If so then probably a slack clutch cable or something. If it just cuts out then it will most likely be the side stand switch playing up.
getaf1x
PostPosted: 20:44 - 30 Jul 2008    Post subject: cheers all Reply with quote
full power to you..I'll take a look.
Shay HTFC
PostPosted: 20:48 - 30 Jul 2008    Post subject: Reply with quote
Another vote for side stand switch. Check that nothing is gummed up stopping it from going in.
More likely though after saying it's after rain, is that you have a bad connection somewhere that is shorting out or something.
Might be worth spraying a bit of WD40 around.
Full Motorbike License - GS500E '95
tek-monkey
PostPosted: 07:50 - 31 Jul 2008    Post subject: Reply with quote
Only noticed it had a kill switch yesterday, thought I just kept stalling when I parked! Would def have a look at that first.
Don't suppose you have a manual for yours? Or any chance you can take a quick look at my thread here?
getaf1x
PostPosted: 11:04 - 31 Jul 2008    Post subject: its the side stand switch Reply with quote
everyone who voted for the side stand switch give yourself a pat on the back.
I didn't even know there was a side stand switch. thanks for enlightening me.
shorted the switch out back in the connector compartment and things are now working good again. Thanks
Any negative consequences to the electrics system if I leave it shorted until i can investigate the switch & fix properly?
And any suggestions for fixing the switch properly are gratefully recieved?
& tek monkey I'll take a look at your post now
full power to you
The last post was made 17 years, 212 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 53.13 Kb
