| deliriousthun... |
 deliriousthun... Spanner Monkey
| petemell |
 petemell Trackday Trickster
| deliriousthun... |
 Posted: 10:11 - 01 Aug 2008 Post subject: |
um.. well I don't know what you mean by a wormscrew adjuster..
as far as I can tell there are only 2 places to adjust it.. at the lever, and an adjuster close to the clutch casing.. I've used both.. but the problem is that to get the biting point where I like it, I end up creating a lot of freeplay..
Is the one near the clutch casing the wormscrew adjuster?
Sorry I'm a complete n00b
Thanks again, ____________________ Tom |
| Keir |
 Keir World Chat Champion
 Posted: 11:23 - 01 Aug 2008 Post subject: |
| deliriousthunder wrote: | as far as I can tell there are only 2 places to adjust it.. at the lever, and an adjuster close to the clutch casing |
common misconception. there is usually a third one as pete says. on my GSXR there is a screw and locknut under a rubber cover by the front sprocket cover so i would assume others would be in this area too. have you downloaded a workshop manual for your bike? they are very useful if you havent. ____________________ Current : '08 Yamaha FZ1s
Previous: '99 Honda CBR 600FX, 03 ZX636 B1H, 99 Fazer 600 (red), 02 GSX-R 600 K2, 00 SV650s (red), 2008 ZX10R, 97 Bandit 1200N, 04 ZX6RR K1H, 04 GSX-R 1000, 98 Fazer 600 (gold), 05 Madness 110 Pit bike, 04 CR125R, 00 SV650s (black), 06 KTM 625 SMC, 99 SRAD 600 track bike, 03 SV650, 98 Bandit 1200N, Bandit 600SY, 03 GSX-R 600 K3, 01 GSX-R 600, 01 Fazer 600 (black), VFR 400 NC30 x3, 78 Honda Dream, 00 Speedfight 50 |
| deliriousthun... |
 Posted: 23:20 - 01 Aug 2008 Post subject: |
I have a haynes manual, and I can only find mentions of the 2 adjusters I have used so far.. not to say you're wrong.. just that it doesn't seem to be in the manual, or I'm not looking hard enough..
The section "Clutch - Check" that explains how to adjust it definately only mentions 2 ways to adjust though..
Bike is an xj600n btw.. if anyone reading happens to have done this on an divvy before
Thanks, ____________________ Tom |
| petemell |
| deliriousthun... |
| Wil |
 Wil Trackday Trickster
| deliriousthun... |
 Posted: 14:42 - 02 Aug 2008 Post subject: |
fair enough..
well thanks for help  ____________________ Tom |
| Wil |
| Kickstart |
 Kickstart The Oracle
 Posted: 15:27 - 02 Aug 2008 Post subject: |
The adjusters on each end of the cable just adjust the cable. Using these to adjust the biting point further in by more than a small amount will just result in a floppy lever.
There may also be an adjuster on the engine end on the clutch (but not on the Divvy). These are there to adjust out the play in the actual clutch linkage. Having these out of adjustment can result in the clutch being fairly heavy.
Only real way to adjust the lever position is an adjuster on the lever. Sometimes a convenient to adjust round adjuster knob, sometimes a small screw. But don't think the Divvy has either of those.
However check that you have not mislaid a spacer washer from the clutch lever.
| deliriousthun... |
| Kickstart |
| deliriousthun... |
| Kickstart |
 Posted: 22:04 - 02 Aug 2008 Post subject: |
A different length inner cable would have exactly the same effect as changing the adjusters. The important bit for how much slack you have / bitting point is the difference in length between the cable inner and cable outer, and effectively the adjusters on the cable are changing the length of the cable outer.
Fitting a shorter inner cable would be the same as adjusting the cable to have less slack. Would have the same effect on slack and bitting point.
The last post was made 17 years, 338 days ago. Instead of replying here, would creating a new thread be more useful? |
