| stinkwheel |
| Kickstart |
 Kickstart The Oracle
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 14:48 - 07 Aug 2008 Post subject: |
if you file a very smooth, progressive chamfer then i dont see why it wouldnt work. just make sure you eliminate every trace of a sharp edge.
i know you shouldnt on anything to do with engines reall, but emory cloth/wet and dry could help with that. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| FerretFing |
 FerretFing World Chat Champion
 Posted: 15:57 - 07 Aug 2008 Post subject: |
For the sake of £80 it`s not worth the risk - get a new one!.
OR
get BCF to have a whip round for all the help you give & threaten to leave the forum  |
| stinkwheel |
 Posted: 16:33 - 07 Aug 2008 Post subject: |
If I have to spend £80 for a single piston, the whole engine can go in the skip and I'll sell the rest of the bike as a job lot of parts.
Whole, running bikes change hands for £300 or so. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Kickstart |
| Thom |
 Thom World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 17:04 - 07 Aug 2008 Post subject: |
I agree if you're gonna skip the engine then stick it in and see how far it goes.
Looks like the combustion-gases have been held back by the oil-control rings anyway  ____________________ a.k.a 'Geri'
| stinkwheel |
 Posted: 20:31 - 07 Aug 2008 Post subject: |
Well, they're in. I did both the same.
I shall endeavour to make a recording of the first starting attempt.
Got the timing bang on first time too.
If the engine eats itself, I may be on the lookout for some alternative pistons. Maybe see if a couple of Honda 350 ones or some Z650 would fit with a bit of machining. I've got two sets of scored barrels anyway. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| LanaTheGreat |
 LanaTheGreat Scooby Slapper
| stinkwheel |
| stinkwheel |
 Posted: 00:25 - 10 Aug 2008 Post subject: |
Engine runs. Started first push of the button. There is a big hole in the middle of the rev range. I reckon this is air filter/airbox related.
Unfortunately it's pishing oil out past the head gasket so I've had to strip it again. Annoying bacause I did that bhit properly. I even polished the mating surfaces on a sheet of glass. I'm putting it down to a cheap shite head gasket. Might try to make one out of copper instead.
Here's a short and crappy MP3. That is literally the first attempt at starting after I put the fuel tank on. I cranked it over a fair bit with no fuel in to start with the get the oil circulating. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| LanaTheGreat |
The last post was made 18 years, 76 days ago. Instead of replying here, would creating a new thread be more useful? |
