Piston bodgery (chipped skirt)
PostPosted: 13:24 - 07 Aug 2008    Post subject: Piston bodgery (chipped skirt) Reply with quote
So, if I fit this to the GPz305, will it bring about the end of the world as we know it?
https://i48.photobucket.com/albums/f216/stinkwheel/305/Image038.jpghttps://i48.photobucket.com/albums/f216/stinkwheel/305/Image039.jpg
I chipped it on the edge of the crankcase by turning the crank with no barells on. Doh!
Should I do the other side as well so it's the same (lots of filing!)? I presume I'll need to do the other side piston the same.
I can't think why it shouldn't work, after all, the piston skirt wouldn't come into contact with the bore under normal useage.
I'd buy a new one but Kawasaki want £80 for it! Not that I can't afford £80, it's just general principle. £80 is about 4 times what it's worth and I'm not paying it unless I absolutely have to.
PostPosted: 14:11 - 07 Aug 2008    Post subject: Reply with quote
Personally I wouldn't use it. Think that it would touch (although not hard), and it just doesn't feel right.
£80 is a fair amount for a piston. Suspect there must be a fair few floating around dealers as new old stock items.
MaybeGuy
PostPosted: 14:48 - 07 Aug 2008    Post subject: Reply with quote
if you file a very smooth, progressive chamfer then i dont see why it wouldnt work. just make sure you eliminate every trace of a sharp edge.
i know you shouldnt on anything to do with engines reall, but emory cloth/wet and dry could help with that.
FerretFing
PostPosted: 15:57 - 07 Aug 2008    Post subject: Reply with quote
For the sake of £80 it`s not worth the risk - get a new one!.
OR
get BCF to have a whip round for all the help you give & threaten to leave the forum Twisted Evil
PostPosted: 16:33 - 07 Aug 2008    Post subject: Reply with quote
If I have to spend £80 for a single piston, the whole engine can go in the skip and I'll sell the rest of the bike as a job lot of parts.
Whole, running bikes change hands for £300 or so.
PostPosted: 16:36 - 07 Aug 2008    Post subject: Reply with quote
Suspect a short wait and you will fine another piston attached to a trashed engine for a nominal amount of money.
Thom
PostPosted: 17:00 - 07 Aug 2008    Post subject: Reply with quote
i say try it!
if you dont wanna buy anyother and are willing to skip the engine anyway why not see how it goes?
PostPosted: 17:04 - 07 Aug 2008    Post subject: Reply with quote
I agree if you're gonna skip the engine then stick it in and see how far it goes.
Looks like the combustion-gases have been held back by the oil-control rings anyway Smile
PostPosted: 20:31 - 07 Aug 2008    Post subject: Reply with quote
Well, they're in. I did both the same.
I shall endeavour to make a recording of the first starting attempt.
Got the timing bang on first time too.
If the engine eats itself, I may be on the lookout for some alternative pistons. Maybe see if a couple of Honda 350 ones or some Z650 would fit with a bit of machining. I've got two sets of scored barrels anyway.
LanaTheGreat
PostPosted: 20:46 - 08 Aug 2008    Post subject: Reply with quote
So how did it go?
PostPosted: 22:34 - 08 Aug 2008    Post subject: Reply with quote
Aint tried it yet. Engine is sat here ready to go into the frame for a quick try. These things have a habit of taking longer than you'd think.
PostPosted: 00:25 - 10 Aug 2008    Post subject: Reply with quote
Engine runs. Started first push of the button. There is a big hole in the middle of the rev range. I reckon this is air filter/airbox related.
Unfortunately it's pishing oil out past the head gasket so I've had to strip it again. Annoying bacause I did that bhit properly. I even polished the mating surfaces on a sheet of glass. I'm putting it down to a cheap shite head gasket. Might try to make one out of copper instead.
Here's a short and crappy MP3. That is literally the first attempt at starting after I put the fuel tank on. I cranked it over a fair bit with no fuel in to start with the get the oil circulating.
LanaTheGreat
PostPosted: 07:17 - 10 Aug 2008    Post subject: Reply with quote
You might as well check if the piston did any damage to the sleeve etc since you did run the engine for a while.
The last post was made 18 years, 75 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.77 - MySQL Queries: 13 - Page Size: 79.83 Kb
