Car thread - Fiesta 1.25 16v Misfire
garth
PostPosted: 18:21 - 11 Aug 2008    Post subject: Car thread - Fiesta 1.25 16v Misfire Reply with quote
The woman has a 1.25 16v T reg Fiesta with ~70k miles on it.
Misfires all the time, whenever you try and give it any throttle. Changed the spark plugs today and it cured it for literally 2 or 3 miles, then it started intermittantly, and now it's back to its old tricks.
Any ideas?
Btw, anyone know how much it would be to chuck it into a dealers and get a diagnostic report?
Ta
Misc
PostPosted: 18:25 - 11 Aug 2008    Post subject: Reply with quote
Garth, i bought a diagnostic tool for my car, it cost me £25 from ebay & the dealers quoted me £60.
Works a charm although it came up clear. This one's a few more pennies.This
Phil_G
PostPosted: 18:54 - 11 Aug 2008    Post subject: Reply with quote
Does this car have ignition leads or does it have little coilpacks that connect to the plugs and then wire into the ECU?
If its leads, then check all the contacts are clean and tight. If that doesnt cure it, then try a set of new leads. If its on coilpacks, then it could be one of them is malfunctioning and causing the misfire..
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
Finglonga
PostPosted: 18:57 - 11 Aug 2008    Post subject: Reply with quote
If it has the single Coil pack (should have being the 1.25) they break down as they get warm it makes them worse. One HT lead won't have a spark if it is. Both the Festers I have had have had the same problem. Easy and cheapish fix.
Andy Sez....
F.Y.Y.F.F.
garth
PostPosted: 19:20 - 11 Aug 2008    Post subject: Reply with quote
How much ££?
I believe it is the single coil pack, where is it situated?
Finglonga
PostPosted: 19:35 - 11 Aug 2008    Post subject: Reply with quote
Right hand side of the cam cover, you can't miss it all the HT leads run into it and a lead with a plug from the ECU.
You may need a torque bit to remove it not sure on the size though.
Shouldn't be any more than £40 from a motor factors loads more from a main stealer! Think I got my last one for £26.
https://img.photobucket.com/albums/v112/finglonga/lengine.jpg
Better pic . . .
https://img.photobucket.com/albums/v112/finglonga/zetec1.jpg
*Edit* Make sure it is that before you buy one, but it is a known fault of the Zetec 1.25.
Andy Sez....
F.Y.Y.F.F.
garth
PostPosted: 11:30 - 20 Aug 2008    Post subject: Reply with quote
Bought a new one and intend on fitting it tonight.
Any special procedures to fitting it? Disconnect battery, or not?
Don't wanna bugger the ECU.
Ta Thumbs Up
Wave2k
G's Stalker
PostPosted: 12:32 - 20 Aug 2008    Post subject: Reply with quote
Test the HT leads mate, had the same thing on me polo.
Ducati 1299 Panigale
2009 Corvette C6 z51
Cigaro
PostPosted: 13:36 - 20 Aug 2008    Post subject: Reply with quote
Ta Thumbs Up
I don't see why you'll bugger the ECU by disconnecting the battery. It may run a bit rough at first as it re-learns, but as long as you know your radio code and you don't have a weird immobiliser, you should be fine.
It's generally a good idea to disconnect the battery when doing anything like that, even though nothing should be powered with the key off.
Graham88
PostPosted: 15:22 - 20 Aug 2008    Post subject: Reply with quote
Disconnecting the battery won't harm the ECU. That would be a very silly design if it did.
Finglonga
PostPosted: 17:44 - 20 Aug 2008    Post subject: Reply with quote
He means disconnecting the battery before replacing the coil pack. Wink
Andy Sez....
F.Y.Y.F.F.
Graham88
PostPosted: 17:54 - 20 Aug 2008    Post subject: Reply with quote
Oh, you don't need to disconnect the battery to do that.
garth
PostPosted: 06:25 - 21 Aug 2008    Post subject: Reply with quote
All sorted last night just in time for her to drive up to Reading this morning.
What a difference! Bloody goes for a 1.25!
Finglonga
PostPosted: 06:59 - 21 Aug 2008    Post subject: Reply with quote
Yamaha helped Ford design the engine, they love to be revved! Thumbs Up
Andy Sez....
F.Y.Y.F.F.
R6jonny
PostPosted: 14:27 - 21 Aug 2008    Post subject: Reply with quote
Hmm my car has exactly the same problem, fancy coming and fixing it for me !!
Honda NSR125 - Yamaha R6 - Ducati 748 - Suzuki GSXR750K6/GSXR1000K7/GSXR750K8 - Ducati 848 - Honda SP1 - Triumph Daytona 675
"simply because she is a female and is thus her actions largely make no sense whatsoever by default"
Graham88
PostPosted: 18:59 - 21 Aug 2008    Post subject: Reply with quote
Just replace the coilpack, common problem!
mistergixer
PostPosted: 19:37 - 21 Aug 2008    Post subject: Reply with quote
Going off topic somewhat, wasn't the only Yamaha-for-Ford engine the one in the 1.7 Puma? I didn't think Yamaha had anything to do with the other engines.
Space Monkey #7
The last post was made 17 years, 220 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.97 - MySQL Queries: 13 - Page Size: 93.11 Kb
