nsr oil levels
baldy
PostPosted: 23:52 - 23 Mar 2004    Post subject: nsr oil levels Reply with quote
Hi,
Just been looking at the oil levels on my NSR and noticed that when the bike is started it shows that there is no oil in it, but when it is stopped it reads full. Which one should i take notice of as it really needs a oil change. Any help would be good Very Happy
Cheers.
One day i will rule the world, just not today.
PostPosted: 23:55 - 23 Mar 2004    Post subject: Reply with quote
When it's running the oil is going all round the engine. When you stop the engine, it sits in the sump.
Measure the oil level when the engine off.
baldy
PostPosted: 00:04 - 24 Mar 2004    Post subject: Reply with quote
Cheers.
Oh yeah also i have a problem with the powervalve cable thingys (i think). When the engine revs to about 4k the cable sticks and then slaps shut. Also when you turn the bike on it makes a sound like a baby crying and then the cable snaps shut. The time it takes to do this varies all the time but it is really anoying me. It makes the bike sound like a tank Exclamation I have put it down to the servo cable with the sprig on it sticking. Any help would be useful Thumbs Up
Dr Nick
PostPosted: 11:39 - 24 Mar 2004    Post subject: Reply with quote
This happened to my NSR, i think the problem was that the powervalve was coked up, so wouldn't allow it to open fully or something. Thus the wires stick. Showed it to my Honda dealer and got it done under warranty.
is that it
priller
PostPosted: 13:04 - 24 Mar 2004    Post subject: Re: nsr oil levels Reply with quote
baldy wrote:
Hi,
I hope your taking about gearbox oil Very Happy
Kris
PostPosted: 13:40 - 24 Mar 2004    Post subject: Reply with quote
I too was wondering what oil you were reffering to...
Confused
www.prisonplanet.com
PostPosted: 14:25 - 24 Mar 2004    Post subject: Reply with quote
From the description, it could only be gearbox oil he's talking about. Either that, or something is really fucked Laughing .
baldy
PostPosted: 17:49 - 24 Mar 2004    Post subject: Reply with quote
Thanks for the help. I was talking about the gearbox oil, and do i have to take apart the cylinder to get the powervalve out? It is all covered in a black sludgy substance. Maybe this is the problem?
Cheers Thumbs Up
mr jamez
PostPosted: 18:02 - 24 Mar 2004    Post subject: Reply with quote
No, you should be able to get it out with the engine in the frame. Just remove the dust seal and pull the shaft and the two valve things out Smile
baldy
PostPosted: 18:08 - 24 Mar 2004    Post subject: Reply with quote
Thank's for the help Very Happy Thumbs Up Try it later tonight.
mr jamez
PostPosted: 18:47 - 24 Mar 2004    Post subject: Reply with quote
Oh yeah, and the little nut that holds on the assembly is left-hand thread so remember to undo it the opposite way that you normally do Wink. That's if you can get the allen key bolts out, little bastards Mad
baldy
PostPosted: 18:57 - 24 Mar 2004    Post subject: Reply with quote
Yeah, it says that on the gold metal thingy Thumbs Up
Thanks for the help Very Happy
baldy
PostPosted: 23:53 - 24 Mar 2004    Post subject: Reply with quote
Hmm, found the problem. powervalve was stuck to the block with carbon. Took a lot of tugging to get them out. Also fixed the servo cable, it was frayed on the end and had jammed up. Only problem now is that I have to set it all up again....
Any hints or tips would be VERY helpful.
Cheers Very Happy Thumbs Up
PostPosted: 10:32 - 25 Mar 2004    Post subject: Reply with quote
Can I just say...
On most bikes the oil light comes on when you start the bike to demonstrate that the bulb is not blown.
Also, the NSR doesn't have a sump afaik and the oil light relates to the 2-s oil not the gearbox oil.
The oil should be reasonably well circulated in the 'box pretty much all of the time.
Smile
Kris
PostPosted: 10:38 - 25 Mar 2004    Post subject: Reply with quote
True but not so on the NSR. If the light is blinking/illuminated on start-up then that's not normal.
The last post was made 22 years, 164 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 86.45 Kb
