rxs oil pump
piercedbiker6...
PostPosted: 16:35 - 15 Aug 2008    Post subject: rxs oil pump Reply with quote
My girlfriend has an rxs 100. It seems to smoke alot & only does about 50mph. Does anybody know how to adjust the oil for the two stroke oil delivery system. Thanx in advance, Mick.
Flat out or not out.
The_One
PostPosted: 20:44 - 15 Aug 2008    Post subject: Reply with quote
Get a new pump, or do as my mate did and fix it with a pencil and elastic band Thumbs Up
PostPosted: 21:50 - 15 Aug 2008    Post subject: Reply with quote
That's some shit advice Rolling Eyes
First find out how much oil it is using, my oil light comes on after 750ml of oil has been used then work out how much it is using to a litre.
When I first got my RX-S my bike would do 160 miles to a litre, now it's around 400 miles.
What you have to do is take off the cover on the right hand engine casing with 3 screws on it, in there is the oil pump.
Take the nut off, spring washer, adjuster plate and then the shims. Removing shims reduces oil flow Thumbs Up Remove maybe 1 or a couple for now and see how it goes, if it's still drinking loads of oil remove some more.
Watch out though, the shims are only supposed to be 0.1mm but in mine I had washers upto 0.7mm.
I think your 50mph problem will be something else other than the oil pump though.
The_One
PostPosted: 22:07 - 15 Aug 2008    Post subject: Reply with quote
Sorry your holiness, I was just saying what I would do.
No need to criticize.
MaybeGuy
PostPosted: 01:44 - 16 Aug 2008    Post subject: Reply with quote
that was shit advice.
if its smoking, its not the oil pump thats at fault is it. Rolling Eyes so why replace it?
''omg my bike haz run owt of teh fuel!! i need a new bikez''!
same sort of thing.
Pretendra
PostPosted: 04:22 - 20 Aug 2008    Post subject: Reply with quote
Have you tried adjusting the travel of your pump.
As far as i know, a standard way of adjusting the pump is to coincide the mark on the cable pully with the pully guide screw.
Good luck buddy... Smile
Pretendra
PostPosted: 04:30 - 20 Aug 2008    Post subject: Reply with quote
The last post was made 17 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 58.46 Kb
