Will warped disk fail MOT?
Milo
PostPosted: 09:01 - 25 Mar 2004    Post subject: Will warped disk fail MOT? Reply with quote
Simple as really. The front brakes work fine but you do feel a knocking under braking. I've got the MOT in a couple of months but should I be worried?
Cheers,
Adam
Shaft drives rule. Razz
ProXimaCore
Dougal
PostPosted: 09:53 - 25 Mar 2004    Post subject: Reply with quote
I would say most probably yes it will fail. My car failed for having scored brake discs when the pads were really worn down. Warped disc is far worse if you ask me.
priller
PostPosted: 11:07 - 25 Mar 2004    Post subject: Reply with quote
Warped disk will fail. If the disc is warked you'll fell the lever pulse when breaking. If its making a knocking noise it could be the bearings.
vf1000f2f
PostPosted: 13:04 - 25 Mar 2004    Post subject: Reply with quote
this can translate into a premature lock of the wheel under heavy braking Sad you don't want to loose that front wheel in the wet.
the knocking could be the caliper hitting the end of it's free travel in the side ways limit(thats if it's not bolted rigid) of coarse
live bikes breathe bikes and sleep with bikes!
ProXimaCore
Dougal
PostPosted: 13:07 - 25 Mar 2004    Post subject: Reply with quote
Yeah if anything I'd replace it as a matter of safety rather than wondering if it will pass the MOT.
PostPosted: 14:17 - 25 Mar 2004    Post subject: Reply with quote
A warped disk should fail the MOT (if badly warped), but it is one of those things they might not notice.
Milo
PostPosted: 14:42 - 25 Mar 2004    Post subject: Reply with quote
Cheers for the info people.
I rarely use the front brake anyway but always keep it covered by my hand through traffic. I use engine braking mostly and the rear brake for the light stuff. It does pulse under braking and has been happening since a Croydon Council van disliked me so it must be a dodgy disk. No idea which one though as it looks fine. I'll see if I can take it apart this weekend to have a better look.
What type of disk doesn't corrode/rust? I think cast is the type I don't want isn't it?
Adam
The last post was made 22 years, 101 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 52.43 Kb
