Clutch or Transmission problems
rac3r
PostPosted: 13:24 - 19 Aug 2008    Post subject: Clutch or Transmission problems Reply with quote
Adding to the list so far. This time the bike now starts perfectly but when you put it in first it jerks forward and the engine cuts out then the bike will not even start when you hold in the clutch. It now does not even find neutral! Can someone please help me because it's my first bike which i haven't even ridden yet!
(2000 RS125) Mad
Chequered Flag
rac3r
PostPosted: 14:29 - 19 Aug 2008    Post subject: Reply with quote
...Someone help please!!!
Chequered Flag
MaybeGuy
PostPosted: 16:23 - 19 Aug 2008    Post subject: Reply with quote
is your sidestand down?
if not, check your sidestand cutout switch.
bike gearboxes dont like being used when the bike isnt moving, so try rocking the bike back and forth when searching for neutral.
Cigaro
PostPosted: 16:27 - 19 Aug 2008    Post subject: Reply with quote
When you say it won't start with the clutch in after putting it in gear - does it not turn over at all? Or turn over slowly?
rac3r
PostPosted: 16:35 - 19 Aug 2008    Post subject: Reply with quote
You can only hear the starter motor when you try and hold the clutch in and start it. The sidestand cut off switch has been cut by the previous owner. The gear lever is now also very stiff.
Chequered Flag
MaybeGuy
PostPosted: 16:42 - 19 Aug 2008    Post subject: Reply with quote
if he cut it off, did he short the 2 ends? you need to in order to bypass the switch.
find where he cut it off, tie the 2 ends of wire together and see if it works then.
rac3r
PostPosted: 17:00 - 19 Aug 2008    Post subject: Reply with quote
i rocked it back and forward and found the rest of my gears but still no neutral. there are three wires and 2 are joined together. could it have anything to do with the oil
Chequered Flag
ratboy
PostPosted: 19:12 - 19 Aug 2008    Post subject: Reply with quote
is the clutch cable intact? sounds like its either loose or snapped. follow the cable to the engine and see if it pulls the lever.
fairly cheap to buy and easy to replace.
if not your side stand switch probably needs replacing.
with it being your first bike and all you may leave it down once in a while, and the switch can save you from finding out round a corner as it throws you off!
its also a cheap part and can be fitted fairly easily.
hope this helps
tom
rac3r
PostPosted: 19:35 - 19 Aug 2008    Post subject: Reply with quote
The side stand flips up as soon as you lift the bike so that shouldn't be a problem. Thanks for the info anyways i'll try it all out tomorrow. I'm sooo close to selling this bike!
Chequered Flag
rac3r
PostPosted: 09:46 - 20 Aug 2008    Post subject: Reply with quote
How do you take the clutch cable off?
Chequered Flag
The last post was made 17 years, 193 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 64.01 Kb
