How do I....
Matthie
PostPosted: 15:01 - 26 Aug 2008    Post subject: How do I.... Reply with quote
...get my brake to 'bite' after refilling my system completely? The system was emptied, filled, bled, made air bubble free and then sealed back up. The pistons are pushing against the brake pads (not with much power), but the brake handle still has no resistance.
Any ideas?
Cheers,
M
PostPosted: 15:03 - 26 Aug 2008    Post subject: Re: How do I.... Reply with quote
Any ideas?
Cheers,
M
It hasn't been bled properly yet. Keep bleeding!
Matthie
PostPosted: 15:05 - 26 Aug 2008    Post subject: Re: How do I.... Reply with quote
MarJay wrote:
Any ideas?
Cheers,
M
I'm using the method of pumping the brake, holding it in, and undoing the bleeding nipple so fluid squirts out and not letting the reservoir go empty. This is right yeah?
Also, how will I know when its done? Will there be a resistance even when the top of the reservoir is off?
Cheers,
M
prawny1
PostPosted: 15:27 - 26 Aug 2008    Post subject: Reply with quote
Its good to periodicaly tighten the bleed nipple up and pump the lever a few times when bleeding brakes, it helps build the pressure up in the caliper and expell all the air also try to make sure the bleed nipple is at the highest point possible so that any air floats towards the nipple instead of getting trapped (airlocked) in the caliper.
Some scoots have the bleed at the bottom of the caliper which means you have to take the caliper off to bleed them.
pa_broon74
PostPosted: 15:31 - 26 Aug 2008    Post subject: Reply with quote
Undo the bleed nipple while pulling the lever in making sure to close the nipple before letting the lever back out.
Always keeping the res topped up. Bit of a two man job, makes it easier I find anyway.
Basically what marjay said too, you think its done but its not, you need to keep bleeding for a bit longer.
Didn't catch anything.
Matthie
PostPosted: 15:34 - 26 Aug 2008    Post subject: Reply with quote
yeah thats what i was doing, pumping, holding in, undoing the bleed nipple, closing nipple, pumping....
Takes forever! Laughing
Carl Howell
PostPosted: 20:07 - 26 Aug 2008    Post subject: Reply with quote
Why did you empty it? I just keep bleeding until I see the colour of the fluid change.
Make sure the pipe is submerged in fluid then once there are no bubbles in the pipe you can leave the nipple open and pump all day.
philone
PostPosted: 20:20 - 26 Aug 2008    Post subject: Re: How do I.... Reply with quote
[quote="Matthie"]...get my brake to 'bite' after refilling my system completely? The system was emptied, filled, bled, made air bubble free and then sealed back up. The pistons are pushing against the brake pads (not with much power), but the brake handle still has no resistance.
Any ideas?
Cheers,
the seals in the mastercylinder could have gone .is can happen when the cylinders bleed dry how old is the bike?
Gazdaman
I did a trackday!!!
PostPosted: 20:23 - 26 Aug 2008    Post subject: Reply with quote
Master cylinder seals are possible, but I must say unlikely. Much more likely that it's just poorly bled.
Go to Halfords and buy one of their bleeding tools. It's just a one way valve. You put it on the bleed nipple, loosen it, and just pump and pump whilst topping up the fluid.
Bingo.
Gaz
Charlie
PostPosted: 20:27 - 26 Aug 2008    Post subject: Reply with quote
Using the the one way value is good, helped me bleed my brakes a couple of times. Well worth it.
PostPosted: 20:39 - 26 Aug 2008    Post subject: Reply with quote
That doesn't work. You have to open the bleed nipple with positive pressure on the lever, and close it still with positive pressure. They way I do it is:
Finger on the lever with a little pressure
Slowly open the bleed nipple
Keep moving the lever until its near the bar
close the bleed nipple while the lever is moving and when it is nearly touching the bar.
If you do it any other way you allow air back into the system, and some of it goes between the threads on the bleed nipple. Make sure the reservoir doesn't get below the 'min' mark.
Matthie
PostPosted: 20:49 - 26 Aug 2008    Post subject: Reply with quote
I got it bleeding and got loads of air out (I do have the proper tube ect just got it sealed properly this time). The pads do push up against the disc just with very little pressure. I can hold the brake fully in and walk it forward with a little effort and thats on the max setting with the allen bolt to adjust the brake lever (if you know what i mean Laughing )
Do I just keep bleeding? I have put about 1/2 a 500ml bottle of fluid through already.
Carl Howell
PostPosted: 21:04 - 26 Aug 2008    Post subject: Reply with quote
It shouldn't need that much fluid. You are doing something wrong or something is knackered.
tutton
PostPosted: 21:37 - 26 Aug 2008    Post subject: Reply with quote
If its still getting air out after 250ml of fluid then you have air getting in system.
First, see the lever at the bottom of the master cylinder, unscrew it (the nut) and take it out and have a gander at the seals, do they look broken/split? if fine put the lever back in but put it in at an angle and then bleed the fook out of it again.
st3v3
PostPosted: 22:40 - 26 Aug 2008    Post subject: Reply with quote
Failing Marjay's suggestion maybe try:
Open nipple fully;
keep brake fluid going in;
pump the brake non stop, so fluid is constantly squirting out(maybe into a clean container to re-use it) but keep an eye out that it isn't getting too low in the master cylinder bit.
As you're filling and pumping and there's a nice amount of pressure built up with constant squirt-age, tighten up the nipple AND still pump for another couple. Should be nice and effective, so then top the master cylinder up to the "max" mark, put it all back together and it's a good job well done.
DEN MONKEY
PostPosted: 07:23 - 27 Aug 2008    Post subject: Reply with quote
Might be worth trying this trick too
https://www.youtube.com/watch?v=oA3HIVkup94
meh
Wil
PostPosted: 11:21 - 27 Aug 2008    Post subject: Reply with quote
It sounds to me very much like you need to remove the caliper and move it about, turn it upside-down etc to make sure there are no air bubbles trapped inside.
'07 Triumph Speed Four
Aw look, a baby driving a car. And look, there's a dog driving a bus!
PostPosted: 15:04 - 27 Aug 2008    Post subject: Reply with quote
It could also be that air is trapped in the top banjo above the master cylinder. I find this mainly happens on twin line systems, but it does happen on a single line system occasionally.
Just have everything tight, squeeze the lever a little, then undo the banjo a bit with the lever pressure constant. When it spurts out fluid, tighten the banjo before the lever reaches the bar. This will get rid of any air trapped in the banjo.
veeeffarr
PostPosted: 15:24 - 27 Aug 2008    Post subject: Reply with quote
Leona Lewis hates doing this job as well; https://www.youtube.com/watch?v=sF84pIhP5UM
Matthie
PostPosted: 15:43 - 27 Aug 2008    Post subject: Reply with quote
Rolling Eyes
Matthie
PostPosted: 18:23 - 27 Aug 2008    Post subject: Reply with quote
Fixed it Mr. Green
Did both banjos how you suggested MarJay and the brakes went solid instantly.
Did my back brake in like 5 minutes after Laughing
calum17
PostPosted: 21:39 - 27 Aug 2008    Post subject: Reply with quote
that doesnt work.
look at your brakes now and try it - you'll get that same 'bubble'.
that's just fluid being fished back into the master cylinder from the mechanism attached to the lever ... i think, but either way - its not helping him to bleed his breaks. it would happen even if i wasnt bashing the bars.
The last post was made 18 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.42 - MySQL Queries: 13 - Page Size: 119.72 Kb
