| Matthie |
 Matthie World Chat Champion
 Posted: 15:01 - 26 Aug 2008 Post subject: How do I.... |
...get my brake to 'bite' after refilling my system completely? The system was emptied, filled, bled, made air bubble free and then sealed back up. The pistons are pushing against the brake pads (not with much power), but the brake handle still has no resistance.
Any ideas?
Cheers,
M ____________________ ***Previous: GPR50, FZ750 *** Current: Monkey bike, yella SV 650 ***
Tutton says: I hate random hardons, they are so weird... |
| MarJay |
 MarJay But it's British!
| Matthie |
 Posted: 15:05 - 26 Aug 2008 Post subject: Re: How do I.... |
| MarJay wrote: | | Matthie wrote: | ...get my brake to 'bite' after refilling my system completely? The system was emptied, filled, bled, made air bubble free and then sealed back up. The pistons are pushing against the brake pads (not with much power), but the brake handle still has no resistance.
Any ideas?
Cheers,
M |
It hasn't been bled properly yet. Keep bleeding! |
I'm using the method of pumping the brake, holding it in, and undoing the bleeding nipple so fluid squirts out and not letting the reservoir go empty. This is right yeah?
Also, how will I know when its done? Will there be a resistance even when the top of the reservoir is off?
Cheers,
| prawny1 |
 prawny1 World Chat Champion
| pa_broon74 |
 pa_broon74 World Chat Champion
 Posted: 15:31 - 26 Aug 2008 Post subject: |
Undo the bleed nipple while pulling the lever in making sure to close the nipple before letting the lever back out.
Always keeping the res topped up. Bit of a two man job, makes it easier I find anyway.
Basically what marjay said too, you think its done but its not, you need to keep bleeding for a bit longer.
 ____________________ Didn't catch anything. |
| Matthie |
 Posted: 15:34 - 26 Aug 2008 Post subject: |
yeah thats what i was doing, pumping, holding in, undoing the bleed nipple, closing nipple, pumping....
Takes forever!  ____________________ ***Previous: GPR50, FZ750 *** Current: Monkey bike, yella SV 650 ***
| Carl Howell |
 Carl Howell Scooby Slapper
| philone |
 philone Two Stroke Sniffer
| Gazdaman |
 Gazdaman I did a trackday!!!
| Charlie |
 Charlie World Chat Champion
| MarJay |
| Matthie |
 Posted: 20:49 - 26 Aug 2008 Post subject: |
I got it bleeding and got loads of air out (I do have the proper tube ect just got it sealed properly this time). The pads do push up against the disc just with very little pressure. I can hold the brake fully in and walk it forward with a little effort and thats on the max setting with the allen bolt to adjust the brake lever (if you know what i mean )
Do I just keep bleeding? I have put about 1/2 a 500ml bottle of fluid through already. ____________________ ***Previous: GPR50, FZ750 *** Current: Monkey bike, yella SV 650 ***
| Carl Howell |
| tutton |
 tutton World Chat Champion
| st3v3 |
 st3v3 Super Spammer
| DEN MONKEY |
 DEN MONKEY World Chat Champion
| Wil |
 Wil Trackday Trickster
| MarJay |
| veeeffarr |
 veeeffarr Super Spammer
 Posted: 15:24 - 27 Aug 2008 Post subject: |
| Matthie |
 Posted: 15:43 - 27 Aug 2008 Post subject: |
| Matthie |
 Posted: 18:23 - 27 Aug 2008 Post subject: |
Fixed it
Did both banjos how you suggested MarJay and the brakes went solid instantly.
Did my back brake in like 5 minutes after  ____________________ ***Previous: GPR50, FZ750 *** Current: Monkey bike, yella SV 650 ***
| calum17 |
 calum17 Brolly Dolly
 Posted: 21:39 - 27 Aug 2008 Post subject: |
that doesnt work.
look at your brakes now and try it - you'll get that same 'bubble'.
that's just fluid being fished back into the master cylinder from the mechanism attached to the lever ... i think, but either way - its not helping him to bleed his breaks. it would happen even if i wasnt bashing the bars. |
The last post was made 18 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
