| c_dug |
 c_dug Super Spammer
 Posted: 15:35 - 26 Aug 2008 Post subject: town riding = stiffer gears? |
Last night myself and a few friends randomly decided to take a trip into london, after a while i found my gears were clunking into place rather than going smoothly, my friend on his XR said his were similar, is this just a result of the clutch heating up from constant use and dragging or is there something more worrying happening?
This morning on my way to work about half way there i pulled the clutch in and went to flick up a gear to find the gear thingy wouldnt budge this happened twice but for the rest of the journey it was fine.
Im a little worried that something is up, however its a new bike to me so mayby im doing something wrong
Any thoughts or ideas?
c_dug ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock.
| moog |
 moog Spanner Monkey
| neil. |
 neil. World Chat Champion
 Posted: 16:19 - 26 Aug 2008 Post subject: |
Is the gearbox lubricated by the engine oil? If so, are you due an oil change? Could help...  ____________________ CBT February 2008 | A2 June 2008 | Yamaha YBR125 (written off) | Honda CBF125 (current) |
| doggone |
 doggone World Chat Champion
| craigs23 |
 craigs23 Mr Muscle
| c_dug |
 c_dug Super Spammer
| bazza |
 bazza World Chat Champion
| Finglonga |
 Finglonga World Chat Champion
| c_dug |
 c_dug Super Spammer
 Posted: 19:17 - 26 Aug 2008 Post subject: |
sorry just realised why all the confusion, i meant stiffer
c_dug ____________________ I am a bellend, I am a man of constant sorrow, I am a gummy bear, I am a rock. |
| Carl Howell |
 Carl Howell Scooby Slapper
 Posted: 22:49 - 26 Aug 2008 Post subject: |
Engine oil isn't suited to lubricating gearboxes. With gearbox oil, EP80/90 - the EP stands for Extreme Pressure, meaning the pressure between the gear teeth and engagement dogs. Engine oil isn't formulated for this pressure so more frequent oil changes are required as the molecules get broken-down. Running the engine hotter in town traffic makes the situation worse. ____________________ a.k.a 'Geri'
| c_dug |
 c_dug Super Spammer
 Posted: 23:35 - 26 Aug 2008 Post subject: |
im guessing theres not much that i can do though as its one compartment in the engine? or should i be filling it up with gear oil instead?
 Posted: 05:30 - 27 Aug 2008 Post subject: |
Definately not!
Things you could do:
Use better quality oil
Change oil more often
Make sure your chain & sprockets are in good nick, well-lubed and adjusted right.
Fit an oil cooler
Experiment with different ways of changing gear. More revs = smoother changes, up to a point. ____________________ a.k.a 'Geri'
| DEN MONKEY |
 DEN MONKEY World Chat Champion
 Posted: 06:57 - 27 Aug 2008 Post subject: |
I definitely find it easier to change when I'm up the revs a little bit rather than short shifting.
Something I notice I do sometimes when Im giving a bit of stick is that I load up the shifter by pressing on it slightly when I'm about to change gears. More often then not when I do this from 1st to 2nd I will hit a false neutral
Not good when you rev the tits off it thinking you're in second and don't go anywhere.
A quick adjustment of the lever itself to a slightly higher position sorted this for the most part.  ____________________ meh |
| ben_wheely |
 ben_wheely Trackday Trickster
| chris-red |
The last post was made 18 years, 22 days ago. Instead of replying here, would creating a new thread be more useful? |
