Cornering? How do you do it?
John
PostPosted: 20:44 - 28 Mar 2004    Post subject: Cornering? How do you do it? Reply with quote
Long post, the short of it asking how you take corners?
So far on the 125 I've always tried to go into a corner at about the speed I wanted to, usually coasting round the corner and applying power on the exit.
However, I was reading the cornering info on the survival skills web site and it says you should go into the corner again at roughly the speed you want, then keep the throttle open slightly round the entire corner.
I've been trying it today and it seems to work good, seems to give the bike a little more grip and gets me round the corner a bit quicker too.
I tried doing it a bit quicker on some tighter roads and was having a bit of trouble slowing down enough to be able to hold the throttle open throughout the corner, but I think that will come with practice.
The main thing that concerns me with this is that I tend to lean over quite a long way, and if there was something in the middle of the road I think I would have big problems avoiding it compared to if i was just coasting round it like normal. The VFR seems to accelerate quite quickly (compared to the 125 OFC) even at minium throttle.
So, how do you do it, and what advice/tips can you give me?
Ta. Cool
TT600 neeeeeeeeeeeeeeeeeeowwww!
PostPosted: 20:57 - 28 Mar 2004    Post subject: Re: Cornering? How do you do it? Reply with quote
You will get best grip in a corner when each tyre is taking an equal load. Because the front tyre is smaller, so has a smaller contact patch, the weight distribution should be about 40/60 front/rear.
To get this distribution you need to be on the power slightly.
This does mean you have to plan for corners, but it's generally best to, to get the most out of them Smile. While it may seem harder to avoid things like this, your bike will be have more 'lean credit'.. because the weight distribution is correct it will be able to lean further without sliding. If you try to avoid something on a neutral throttle you may over-weight the front causing it to slide.
Note that the act of cornering slows you down and a neutral throttle can actually mean that you loose speed through a corner, making it even worse for the weight distribution.
Saying all that, I rarely bother going to those lengths on the road; I'm not pushing the limits anywhere near that that I would be on a track.
PostPosted: 21:06 - 28 Mar 2004    Post subject: Reply with quote
That's the idea; I do on the track anyway.
We're not talking wide open, but enough to give a little bit of acceleration.
A good example of this was when the KR had oil dripping on the rear tyre at Cadwell. Near the end of the day it got to the point that unless I was holding the throttle at a certain point the rear started to judder. Presumably this was the point where the weight distribution was correct and the bike was well 'balanced'; at two high or to low openings it started to judder unless I slowed down.
AcIdBuRnZ
PostPosted: 23:30 - 28 Mar 2004    Post subject: Reply with quote
Toe to edge of peg, knee out and lean... Thumbs Up Twisted Evil
Hope this helps Wink
Mark
PostPosted: 23:53 - 28 Mar 2004    Post subject: Reply with quote
I'd watch out putting your toe on the edge of the peg.... lean a bit to far and quie a bit of your foot can go down or even possibly get ripped off the peg.
The 'proper' way to hold your inside foot is to have the ball of the foot on the peg, facing forwards. This way even with the peg going down, your foot won't touch.
[rant]Unless you're like the bloke on that GSXR600 today who just stuck his foot out while harldy leaning.... FFS, you could do that while going in a straight line... still wouldn't look good though. [/rant]
PostPosted: 12:44 - 29 Mar 2004    Post subject: Reply with quote
Or if you're like me, just corner as quickly as you can without worrying about lean etc. Smile
Although I do worry that I don't seem to be leaning very far. I seem to generally be able to keep up though...
Throttle slightly on does seem to make the bike work better. Thats why I like to feed in the power early but gently and then power out of the corner.
I think the overall cornering nirvana comes through experience though really! Smile
chunkielad
PostPosted: 14:31 - 29 Mar 2004    Post subject: Reply with quote
Leaning more doesn't mean you are a better rider.
Infact leaning less actually means you have the 'technically best' technique.
Leaning very far is mainly for the track. You can do it for fun on the road but very rarely need to go to the extent of GYKD. A good rider can get round most corners at reasonable speed on not need to lean the bike until the pegs touch - it's fun but not necessary!
There are two schools of riding out there - riding safe and riding to look good. I'll stick with riding safe.
G got it right with the weight distribution argument though. You have to have some acceleration to keep the weight slightly rear of centre and keep the bike grounded.
Mark Harrison R.I.P - 26th March 2003.
Remember you always and will ride in your honour.
Big revvs up for Mark!
Milo
PostPosted: 15:39 - 29 Mar 2004    Post subject: Reply with quote
Reminds me of a time on my big old XJ900 when I had a shit-scared sports bike riding mate on the back and I had my centre stand scraping. Twisted Evil
I laughed at the wimp so much afterwards! And it's him that's meant to be the hard core racer (with his racing boots and leathers compated to my textile jacket) oh how I laughed.
I've starting pushing on my pegs recently and you do get a better feel for the corner. It all seems to be more stable. I'll give this giving it some throttle rather than coasting thing a go.
Adam
Shaft drives rule. Razz
AcIdBuRnZ
PostPosted: 17:37 - 29 Mar 2004    Post subject: Reply with quote
G...that's kinda what I meant...it was a quick post and wasn't going into the details of exactly where to place your foot!!!
Mark Rolling Eyes
T.C
PostPosted: 23:52 - 29 Mar 2004    Post subject: Reply with quote
chunkielad has hit the nail on the head in that the further over you lean doesn't mean you are a better rider, in fact the less angle of lean if you get your positioning right is often quicker.
The bike is most balanced when the engine is pulling evenly, so for optimate cornering, even a slight whiff of gas is desirable.
As a rule of thumb, if you come down one gear, this will afford you flexibility to accelerate or decelerate, and it means that with the slightest of throttle openings, not only can you apply the power as soon as the bend starts to open up, but you also have a little bit of engine braking if you need to fine tune your entry speed bearing in mind that the last thing you want to do is apply the brakes mid corner.
Position will also help you. For a left hander, a position as far out to the centre white line as you feel comfortable with will give you maximum visibility into the bend, and likewise a position towards the nearside kerb for a right hander will also benefit. It will also increase the radius, in other words the bend will not be as tight thereby allowing you to carry more corner speed.
Then you need to assess the bend. Roadside furniture, approaching vehicles, road signs, the centre white lines and what we in the trade call the "Vanishing or Limit point" which is the point where the two kerbs ahead of you appear to merge will assist you in determining the severity of the bend. As you approach the bend if it appears that the two verges are not separating, then it is likely that you have one hell of a tight bend, if it starts to separate (two verges) then that is the point where you can start to feed the power in and accelerate out of the corner.
There is an old adage of slow in and fast out. Having put all the above into practice, if you find that you are still carrying too much speed, (and it is a useful excercise anyway) look at the exit of the bend, you will find that the bike will follow your line of sight (anyone remember their shoulder checks on their test and how the bike used to wonder across the road?) As a secondary option, you can shift your body weight into the direction of the bend slightly which changes the dynamics of the machine, which coupled with looking at the exit, 99 times out of 100 will get you through.
Lastly, even though you may know the roads you are riding, treat every corner as if you are riding it for the first time. Never ride on local knowledge, that way it will always leave you a margin of error and a route out of trouble.
It is better to arrive 30 seconds late in this world, than 30 years early in the next
PostPosted: 00:15 - 30 Mar 2004    Post subject: Reply with quote
T.C.:
How to teach Vanishing points and special vision in one easy lesson. Laughing
Seriously though are you still doing the advanced riding stuff? I live in Reading and I could do with some advanced riding training.
I do try to use vanishing points and special vision though as well as the road positioning.
In fact I use the road positioning that you describe there just because I hate feeling like I might drift into an oncoming car/hedge! and it helps with the special vision. Smile
PostPosted: 00:28 - 30 Mar 2004    Post subject: Reply with quote
What's been mentioned up there and a lot, lot more can all be found in:
me in another thread somewhere wrote:
A couple of good books:
A Twist of the Wrist II; How to ride bikes fast on track/road + why they do what they do
Motorcycle Roadcraft: The Police Rider's Handbook; How to ride safely on the road while riding fast.
In the end the techniques you are using are going to depend on what you want out of your riding, where and when you are riding etc. And everyone's opinion of 'good' and 'bad' techinque is going to be different.
For instance in the past I have taken 'bad' (racing wise) lines on the road just to maximise speed/lean for fun.
AcIdBuRnZ
PostPosted: 02:28 - 30 Mar 2004    Post subject: Reply with quote
The real answer to the original question is...
...faster than anyone else Cool Wink
Mark
PostPosted: 09:55 - 30 Mar 2004    Post subject: Reply with quote
Which brings up another point....
Just because you see someone riding a corner/road/track faster than you... it doesn't mean you /can/ ride that fast.
They may just be faster, may be an ex BSB rider, may have ridden that bit thousands of times...
or, often more likley....
They may be just about to crash!... Or on the corner after that they're also taking faster than they can control.
So, ride for yourself and work on /your/ limits... not the person in front's.
Luke_Retrofly
Silly Lesbian
PostPosted: 10:44 - 30 Mar 2004    Post subject: Reply with quote
Thats the thing about riding on the road 99 times out of 100, you cant see whats round the next bend. This means that i never go to my full potential round a corner. Though taking the proper lines, ie wide/tight/wide does improve the speed you take the corner at, just watch your head when you apex mid corner on a right hander Mr. Green . Most of the time i try to get the revs at just before the powerband, this means that you got the acceleration when u need it, but when you do hold it open it dosnt fly off into the bushes. I have had to break mid corner a few time and its not the nicest thing, it usually sits up and start bucking about Neutral.
At the end of the day you've got to weigh up the "risk" and "fun" factor. The faster you go round a corner the riskerier it is to you, other road users/cows etc. But most of the time its more fun too. Damn if only biking wasnt so fun Cool .
Luke
Flounced - Long overdue
Fuck you bitch I'm in the top 10 list I can do the what the fuck I want!
Luke_Retrofly
Silly Lesbian
PostPosted: 10:45 - 30 Mar 2004    Post subject: Reply with quote
You can never know you limits till you surpass them Thumbs Up Mr. Green.
Luke
PostPosted: 14:29 - 30 Mar 2004    Post subject: Reply with quote
Quite agree, it's just that it's best to go slightly past your limits, rather than find that your's are actually signifcantly less than those of the person you are following.
Also you never know... the person infront might actually be on Rossi's RCV from last year, done up in old RS125 fairings Razz.
T.C
PostPosted: 14:51 - 30 Mar 2004    Post subject: Reply with quote
Yes I am, but at the moment I am pretty well booked up until mid July.
John
PostPosted: 16:59 - 30 Mar 2004    Post subject: Reply with quote
Thanks for all that, mainly TC.
Going to have to practice it. Thumbs Up
jimbo
PostPosted: 17:54 - 30 Mar 2004    Post subject: Re: Cornering? How do you do it? Reply with quote
Idea Well just a point of physics...
To a first approximation, the frictional force is directly proportional to the normal load, and not to the contact area of the tyre.
So with a smaller contact area, the front tyre should require the same loading as the rear to give the "balanced" weight distribution. ie 50/50 front/rear.
Difficult to understand at first, but F = PA, and inspection shows that PA must remain constant, so if area is reduced, pressure simply increases. (Up to a physical limit of course. Friction starts to get non-linear with sticky tyres).
However, analysis of the turning effect shows that the centripetal force (the force that makes the bike move in a circle) is applied through the contact patch of the front wheel. Thus the front wheel needs a higher frictional force than the back wheel, to prevent slipping and turn the bike. So counter to intuition, the front wheel always requires a higher loading than the rear wheel Exclamation 60/40 front/rear perhaps.
Interesting eh? Hence the reason why sports bikes always load the wrists. The weight of the body is used over the front wheels to contribute to this front-bias.
On the point of cornering, chunkielad is bang on
When a bike goes around a corner, the centre of gravity tries to rotate about the contact patches of the tyres. (as Mr. Newton said, if it's going in a straight line, it's not going to change direction without a fight).We use gravity to counteract this rotation (a counter torque). The heavier a bike is, the higher the inertia of the bike, and thus the more of the gravitational force we require to counteract it. We increase this force due to gravity by leaning over further. So big chunky, heavy bikes have to really lean over, and also go slower in a corner than light bikes. Ever seen a 125 racer with his knee down? If you have it's unnecessary or for show. A 125 racer with his knee down is wasting time. 250GP bikes were often just a few seconds off the lap times of 500GP bikes. Why? They went faster in corners, and racing bikes spend more time in corners than on straights (think about it..)
The best race i've ever seen was between a Suzuki GSXR1000 and a TZ250 in the open-entry Celtic Cup at Mondello Park. Both full on race-bikes, the GSXR blasted away down every straight, and the TZ250 ate him up and overtook on every bend, coming out way ahead. Guess how it ended? The TZ was coming in for the final pass on the last lap. GSXR knew he couldn't catch him in time, so he put both of them in the gravel. But you can pick a 250 up way quicker than a GSXR... victory for 2-strokes!yay Dance!
So slow knee-down cornering is for heavy bikes.
On a 125 cornering is very quick, it's about being neat and tidy,ready to get on the power as soon as possible.
PostPosted: 23:13 - 30 Mar 2004    Post subject: Re: Cornering? How do you do it? Reply with quote
I can't be bothered to think/argue about the physics now.... far to long since I've done such things. However, persoanlly I'm willing to believe and use what is accepted wisdom from racers over the last 30 years which they have discovered to work. What seems to be inuitive, also wins races and stops people from crashing, at all levels.
You tend to lean over the front to give better 'feel': infact generally you want the rear to loose traction before the front, while it may not be absoloutely the fastest way, it sure feels a lot safer because I a lot more rear wheel slides are recovered from than front wheel slides.
Yep... I don't think these guys are just 'showing off':
https://imgserv.ya.com/galerias2.ya.com/img/c/cf0d1072131a497i3.jpg
Note: people get their knee down to judge how leant over they are; a very useful way of knowing how fast you are going and not crashing etc.
Note that hanging off works on modern sports bikes thanks to their geometry (wide tyres etc)... and also means the bike is more upright, so has more grip and can relativly get round the corner faster.
I'd say that's the way you corner on a 1000cc bike more: getting the cornering finished as soon as possible and getting on the power.
Smaller bikes tend to go for corner speed over a tight line, because they don't have much power.
By leaning as far as possible you can get round the corner as fast as possible, which means you don't have to rely on your lacking power so much. Have a look at some pictures of 250proddy/gp bikes... some lean so far that their knee is practically against the tank:
https://images.google.co.uk/images?q=tbn:iTYg2u0Dpd0J:www.haltonsportbike.com/wp-14.jpg
They do this because it's quicker to get throught the corner at as high speed as possible rather than get through it then get on the power to catch up.
jimbo
PostPosted: 01:41 - 31 Mar 2004    Post subject: Reply with quote
Well i didn't mean to rattle your cage G.
I guess i was making a point about the difference in cornering styles and speeds for large and small bikes.
If you compare your cool 125 pic to the one below you should see the difference. The RCV rider HAS to hang off the bike, shifting his body mass well off-centre, and feeling for the touch-down with his knee. As you point out, the 125 riders are basically just leant over as far as they can go. Their body mass transfer is much less. These guys generally don't need their knee out or down to get round the corner. It's a by-product of their angle of lean.
Speaking from experience here. A friend of mine raced a CBR600 in the Regal clubmans here for 2 years, and has switched to a TZ250 for this season. The difference in style and body attitude is really obvious. The 250 brakes in half the distance, corners in half the time, and he still doesn't have to shift his weight as much as on the 600.
The word "neat" is an old term for streamlined (maybe i've been hanging around road race paddocks too long). As you point out, small bikes carry higher corner speed and can't afford to have anything out in the wind. Compare the pictures. The 125 riders are "neater", more tucked in, even at max lean.
Again if you analyse it, you'll notice that increased leaning is possible on modern bikes thanks to their geometry (wide tyres etc). From experience: a good aquaintance races a 1948 manx norton, and he has to really hang off because the chassis won't allow such angles of lean.
You must have been tired writing this... You mean bigger bikes choose to go slower in corners?Laughing In the real world racing bikes corner as fast as physically possible. It just happens that small bikes go faster round corners.
And finally:
I was wrong. Please forgive my hyperbole. I've got the 2003 Czech 125GP and MotoGP highlights on the computer and there are knees skimming the ground in the 125's too. But they are nowhere near the knee-out hanging off of the MotoGP bikes.
Peace man Karma
chunkielad
PostPosted: 10:13 - 31 Mar 2004    Post subject: Reply with quote
What you guys are discussing is based on racing and as such is not very relevant to the original question.
Any 'safe' road rider corners with the minimum ammountof lean required but the best line possible. A little throttle throughout the corner allows weight transfer to the rear and assists stability. (For whatever reason) then, when you hit the apex, a gradual acceleration out of the corner will allow a smooth entry.
Any other method is not the safest or most efficient but may be m,ore fun! Thumbs Up
needa400
PostPosted: 11:05 - 31 Mar 2004    Post subject: cornering Reply with quote
Yeah, i agree with T.C. Pre corner road positioning is important. When practising on some nice corners at home, I made the mistake of coming in fast on a corner that i had little experience of. This led to me not noticing the decreasing apex until too late, flying up over the kerb and ending up on a grass verge.
Embarassed Didnt come off though, luckily. So anyway, guess the moral of the tale is make sure you are positioned well before going into the corner so you dont get any nasty surprises!!! Twisted Evil
Hex
Party Boy
PostPosted: 11:15 - 31 Mar 2004    Post subject: Reply with quote
Cornering, how do you do it?
I just turn the handel bars, normally as I'm traveling that slow I don't need to counter steer etc. Laughing
After all its hard to get a good amount of speed when all your doing is taking your bike from the shed to polish it and then put it back. Laughing
</end monika mode>
Please not this is only a funny post although somewhat true as the low speed in which I take my bike out of the shed means I do actually turn the handle bars the way I want the bike to go.
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
The last post was made 22 years, 215 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.61 - MySQL Queries: 13 - Page Size: 151.59 Kb
