Idea of raising handlebars...
Clanger
Stirrer
PostPosted: 10:47 - 01 Sep 2008    Post subject: Idea of raising handlebars... Reply with quote
I had an idea of raising the handlebars on my sv, to make the riding style a little more upright, and therefore put paid to the numb problems I've started experiencing on long rides as late.
I have asked on the sv650 forum, but noone is interested in helping, funnily enough?!? I have heard of Helibars, but for some £200 it seems a heck of a lot of money...anyone here suggest anything else, something that won't cost the earth and can be bought locally and/or easily.
Ta muchly in advance.
PostPosted: 10:56 - 01 Sep 2008    Post subject: Re: Idea of raising handlebars... Reply with quote
Have you got clip ons or traditional bars?
Charlie
PostPosted: 13:48 - 01 Sep 2008    Post subject: Reply with quote
Do you mean something like this:
https://www.busters-accessories.co.uk/productInfo.aspx?catRef=MAP528423&kw=risers
Dappa D
PostPosted: 13:50 - 01 Sep 2008    Post subject: Reply with quote
clanger....whats ya name on sv650.org ???
theres a few things on there today about raising bars....
although yes its a ref to helibars....
Current: Suzuki SV650s Curvy (X reg)
Previous : Suzuki GSF400 "Mini Bandit!" (J reg) :- Honda CLR "Cityfly" 125 (w reg)
www.myspace.com/mcdappad
PostPosted: 14:05 - 01 Sep 2008    Post subject: Reply with quote
LSL make risers too.
petemell
PostPosted: 14:47 - 01 Sep 2008    Post subject: Reply with quote
Hi Clanger, have you thought about getting a pair of SW Motech handlebar risers from M&P.
I have some 20mm ones on one of my bikes.
I put some flat bars on but couldn't get master cylinder on because top yoke was in the way. These solved the problem.
They do 25mm and 30mm also.
You will need to buy longer clamp bolts. Better to get some in high tensile steel, not stainless steel.
https://www.mandp.co.uk/largeImage.aspx?image=GQQRASW.jpg
Clanger
Stirrer
PostPosted: 11:18 - 02 Sep 2008    Post subject: Reply with quote
Same as it is everywhere on the net...my online nickname is clanger
Very Happy
Clanger
Stirrer
PostPosted: 11:21 - 02 Sep 2008    Post subject: Re: Idea of raising handlebars... Reply with quote
I'm more than sure they are standard...naked sv standard bars (I think), I haven't changed them and the previous owner only had the bike 5mths and I don't think he changed them....
I'm a bit of a duffer when it comes to technical stuff (I can do standard service for car & bike and that's it I'm afraid)
PostPosted: 12:54 - 02 Sep 2008    Post subject: Re: Idea of raising handlebars... Reply with quote
So you've got traditional bars in which case you need some bar risers. They won't cost much, and the helibars may actually be worse (as they are a type of clip on).
PostPosted: 13:05 - 02 Sep 2008    Post subject: Reply with quote
It should be easy enough to find some slightly higher bars. Plenty of aftermarket ones, and also plenty of other bikes with slightly different shape bars. You might find, for example, that 600 Bandits (or the new 650) has higher bars.
Only issue you might have is the length of cables, hoses and wires. Longer cables (clutch, throttle, choke) should be easy to source from someone like Venhill. Same for a longer brakehose. Wiring is trickier. However I would suspect that you could lift the bars an inch or so without having to change anything.
Clanger
Stirrer
PostPosted: 15:13 - 03 Sep 2008    Post subject: Reply with quote
Hmmmm...had the wiring all changed to braided hoses a few years back, not sure how much play I have with them...need to do a little research.
Marjay...I have heard of Helibars but I'm not forking out that sort of money this late in the stage of owning the sv... realistically I should be wondering what bike next, problem is the one's I like the look of I'll probably get @rse-ache about because they haven't the torque of the v-twin...
Ideal situation would be to get myself to a bike supermarket where I could test ride a whole range of different bikes, to see which would suit my needs perfectly.
I don't think such a place exists, so I'm thinking the cheapest way to improve my ride is the raising of handlebars.
Cheers for the advice guys, it's handy being affiliated to these different bike forums, you get different things from each.
PostPosted: 15:38 - 03 Sep 2008    Post subject: Reply with quote
What I'm saying is don't bother with helibars. They are really replacement clip ons for bikes which already have clip ons. Being you have normal bars you should be able to just buy something from Busters or somewhere to raise your bars. Just search for bar risers...
I think what you want might be found here:
https://www.bustersclassic.co.uk/products.asp?id=77
colin1
Captain Safety
PostPosted: 15:39 - 03 Sep 2008    Post subject: Reply with quote
Something which helps without changing bars, is leaning your upper body much farther forward than you normally do, and finding a position that feels comfy.
Try to keep your forearms paralellel to the ground and your shoulders forward way in front of your hips.
Feels a bit wierd at first, but when you get it, its much better than the natural upright position which results in pain on a bike with low bars.
Quote Me Happy
PostPosted: 15:41 - 03 Sep 2008    Post subject: Reply with quote
I bought some bar risers for my bike.
Just unbolt the current clamps, put the risers in and screw back together.
10 minute job at the most and a 1 out of 10 on the difficulty scale.
Clanger
Stirrer
PostPosted: 18:59 - 03 Sep 2008    Post subject: Reply with quote
Sweet, ta muchly Thumbs Up
Moonie
PostPosted: 19:02 - 03 Sep 2008    Post subject: Reply with quote
Sorry to be OT but how do you go about swapping clip ons for Renthals? I see mounts and stuff on the internet, but where do they go?
Clanger
Stirrer
PostPosted: 19:05 - 03 Sep 2008    Post subject: Reply with quote
Try to keep your forearms paralellel to the ground and your shoulders forward way in front of your hips..
I've tried everything - apart from a new bike, and raising the handlebars. Pre-accident and advancing years I was fine, but nowadays...it just gets tougher and tougher...especially in the damp cold conditions. (oh woe! Mr. Green )
I had been seriously thinking of ditching the sv for something like XT650 or MT-03 (but have been told they're totally gutless on dual carriageways compared with the v-twin), and having owned v-twins for many years now....I think it would irk me somewhat!
PostPosted: 09:14 - 04 Sep 2008    Post subject: Reply with quote
Depends on the setup. Some are like the clip on part of a normal clip on bar, but going inwards and up with a mount for the bars. Others you drill holes in the top yoke and bolt them on. Others are complete replacement top yokes. May be other ways of doing it as well.
The last post was made 18 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 104.88 Kb
