Stupid Plumbing question
t121anf
PostPosted: 09:15 - 08 Sep 2008    Post subject: Stupid Plumbing question Reply with quote
i need to change my bedroom radiator since the bleed valve has snapped (TBH the rad isn't powerful enough either)
however instead of using standard copper pipe coming upwards from the floorboards i intend to use the chrome version that you can get for doing showers etc, i presume this will be fine for use on a radiator too?
pa_broon74
PostPosted: 14:29 - 08 Sep 2008    Post subject: Reply with quote
Yup.
Only difference between them is the chrome looks a wee bit better and is more expensive. (I think the chrome piping might be a wee bit harder to shape though...)
Didn't catch anything.
t121anf
PostPosted: 14:36 - 08 Sep 2008    Post subject: Reply with quote
literally only plan to use it for the verticals, so 2 pieces of straight pipe.
cheers
reu
PostPosted: 15:01 - 08 Sep 2008    Post subject: Reply with quote
Yep would be fine but its just the same as copper mate and more expensive so i wouldnt bother Thumbs Up
125cc Pitbike <sold> Aprilla Mx50 <current>
steve32
PostPosted: 16:41 - 08 Sep 2008    Post subject: Reply with quote
or just get some crome sleaves that go over the copper pipes and then you dont need to replace the coppers one, i did the same to a free standing bath i installed a few years ago
suzuki GSX 600F katana .: ~my bike up for sale~ :.
CBT = Completed
DAS= Working on it - theory test = Passed
Al
PostPosted: 17:28 - 08 Sep 2008    Post subject: Reply with quote
Crome plated pipe will be the same as copper, if all the joints are hidden just use compression fittings as you need to strip the crome plating for push fit and solder fittings to work properly.
I take it your be changing the pipe work anyway if your fitting a bigger rad.
Yamaha FZR400RR 3tj
My Instagram Thingy
S1KE
PostPosted: 17:59 - 08 Sep 2008    Post subject: Reply with quote
u cant use the chrome where its joining copper as they react with each other, if u join them with a speedfit joint then its ok, but tbh i just use chrome covers when i do bathrooms, looks justas good Thumbs Up
random twat!
* xbox live mickeyc26
* zx6r b1h 2004 GREEN !
Al
PostPosted: 18:36 - 08 Sep 2008    Post subject: Reply with quote
I've not herd of chrome pipe reacting with copper before Confused the chrome pipe is normally just plated copper or sometimes brass.
I've been told to not use pushfit fittings on chrome plating as they don't grip so well on the smooth finish.
Yamaha FZR400RR 3tj
My Instagram Thingy
S1KE
PostPosted: 19:08 - 08 Sep 2008    Post subject: Reply with quote
i wouldnt use em either, anything to do with heating an i solder.
had a job few years back where a copper pipe jointed to chrome pipe, maybe stainless steel, reacted and went green, hence abig leak!
stick with the chrome covers Thumbs Up
random twat!
The last post was made 17 years, 146 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.32 - MySQL Queries: 13 - Page Size: 60.65 Kb
