| SoND |
 SoND World Chat Champion
 Posted: 14:58 - 09 Sep 2008 Post subject: Turbo CBR |
I've got it into my head recently that fitting a turbo to my nc23 is a feasible idea and I need someone to tell me otherwise.
What's involved in doing it? So far i'm thinking get a turbo, make a custom exhaust manifold and intake plenum, get a wastegate, intercooler (optional?), fuel pump and setting up the carbs. Engine internals will stay stock, I think because the cams are gear driven this limits my options with changing the compression. I'm not looking for stupid power and trying to keep it simple.
The bike at the minute:-
Heavy duty clutch kit fitted
Aftermarket CDI fitted - Improved ignition (So it says, I've no way to test it) and limiter removed
Radiator needs replaced so that's an excuse for a bigger one.
Brakes and suspension will be upgraded first.
I wasted money on a crap stainless exhaust system and I want to make a better one. I want to weld something.
I'm not sure of all the small things I'll run into and need done in a project like this but I think i've covered the big things. Any advice is greatly appreciated. ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister."
| Pete. |
 Pete. Super Spammer
 Posted: 16:44 - 09 Sep 2008 Post subject: |
My first advice is get a bike you don't need for transport for a while. Turbocharging is usually a long and painful process. ____________________ a.k.a 'Geri'
| SoND |
 Posted: 16:52 - 09 Sep 2008 Post subject: |
I have a 125 to keep me going through the winter and I'm off work with a broken ankle for the next 6 weeks or so i've a little bit of time to try and plan it. I'm in no rush for it this year, right now it's just an idea.
What size of turbo do you use on your busa? Can I use something of a similar size on the 400 and still have a controlled power curve?
What do you think's the most difficult bit in a turbo project? ____________________ Go back to bed - You have no rights - "Streetfighters ~ Mainstream motorcycling's crackwhore sister." |
| MarJay |
 MarJay But it's British!
| Blau Zedong |
 Blau Zedong Banned
| MarJay |
| Blau Zedong |
 Blau Zedong Banned
| MarJay |
| Pete. |
 Pete. Super Spammer
| Itchy |
 Itchy Super Spammer
 Posted: 19:30 - 09 Sep 2008 Post subject: |
150% stock power? so a 62bhp bike gets 91bhp? , erm you might as well just drop a CBR600 engine into it, THEN turbo it giving you a toasty 150bhp, though the NC23 frame probably couldn't take it. ____________________ Spain 2008France 2007Big one 2009 We all die. The goal isn't to live forever, the goal is to create something that will. In the end, your life will flash before your eyes. Make sure it is worth watching. |
| Blau Zedong |
 Blau Zedong Banned
| Pete. |
 Pete. Super Spammer
 Posted: 19:43 - 09 Sep 2008 Post subject: |
Yes you would need a custom-made thicker head-gasket or two gaskets and a 16-gauge spacer. Also you might suffer accellerated wear on the cam gears as the meshing would be out. ____________________ a.k.a 'Geri'
| MarJay |
| SoND |
| Pete. |
 Pete. Super Spammer
 Posted: 04:21 - 10 Sep 2008 Post subject: |
Diesel turbos aren't generally suitable. If you look at a diesel turbo next to a petrol turbo you'll notice big bifferences in the housing sizes. ____________________ a.k.a 'Geri'
| neatbik |
 neatbik World Chat Champion
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
 Posted: 06:46 - 10 Sep 2008 Post subject: |
You could just drop in a CBR600 Jelly mould motor. Much more reliable. Only need the 600 swinger, shock and wheel to go with it IIRC. ____________________ My Flickr
| chris-red |
| Pete. |
 Pete. Super Spammer
 Posted: 16:22 - 10 Sep 2008 Post subject: |
I've posted a pic on here before of a guy who did that - plus intercooled and shoved into a Mito frame  ____________________ a.k.a 'Geri'
| Kickstart |
 Kickstart The Oracle
| MarJay |
| SoND |
 Posted: 23:22 - 10 Sep 2008 Post subject: |
| SoND |
 Posted: 09:07 - 11 Sep 2008 Post subject: |
Says in one of those links the A/R is 0.7, is it too big? Is the housing size or turbine size more critical on a bike like this?
A quote from somewhere else about the Metro 1275 turbo and it only uses a 0.25 housing.
| from somewhere wrote: | Stevie, sorry dude, but you have to be corrected here. The metro never had a T2, it had a T3, with a 0.25 turbine housing - one that i understand was developed specially for the tiny 1275 engine. The T2 range of turbo's first appeared in '85 - three years after the first metro came off the line. The same T3 remained on the metro till it stopped in 89
The compressor on the stock metro T3 is a 40 trim - the smallest available, but still listed as a stock item, unlike the 0.25 turbine.
The 'cossie' compressor you say you ve got so that s a T35 compressor I wouldn t have thought you d be able to machine a Metro T3 compressor housing to take this size compressor. I suspect you have a 50 trim compressor, maybe a 60 trim, but I doubt the sierra Cosworth compressor will not be at all right for a tiny 1300cc motor
The 0.36 turbine is a normal upgrade for the metro turbos, the 0.25 is really limiting at high RPM, but again, as the 0.25 is NLA, you don t have a lot of choice but to have one..
The LDV 200 turbo has a 50 trim compressor and a 0.35 Exhaust, same as the R5GT except it isn t water-cooled. The 50 trim compressor with the 0.35 exhaust is perfectly matched to a 1293 in pretty good trim. I m sure the Montego TD unit is the same compressor and trim spec also again the main difference being these are not water-cooled (although the early R5GT units were also not water cooled). I used to reckon that TD s wouldn t do the job, only when I got the maps did I realise there is little different in a diesel turbo than a petrol one, other than the water-cooled core.
The stock R5GT unit in my mini regularly pulled low 14 s at Avon and York, and this year has been dipping into the 13 s on a regular basis following some detail changes to the induction and exhaust system. Trust me, they are about as perfect a turbo as you could want for a turbo A-Series. |
| Pete. |
 Pete. Super Spammer
 Posted: 04:27 - 12 Sep 2008 Post subject: |
The A/R is the area/radius ratio and determines the spooling characteristics for the given wheel size as well as the airflow. To know how much power it can support you need to find the compressor map for that turbo. If you go too big you will get surging which is bad for the turbo - too small and you'll be in the compressor choke zone and intake temps will skyrocket. ____________________ a.k.a 'Geri'
| Faldo |
 Faldo World Chat Champion
 Posted: 20:37 - 12 Sep 2008 Post subject: |
If it helps, Smart turbochargers are literally tiny. I've sold a couple before, and compared to one of a 306 Diesel, I'd say it was at least 4 times smaller (Literally fits in the palm of your hand), and much much lighter. Ideal for a bike in that respect, but as it's so small I don't think it would boost power much. ____________________ Current: ZZR1400
Previous: ZXR 400 L9, ZX-7R P5, ZZR 400, ZX-7R P6, Bandit 600, GSXR 750 Slingshot, DRZ400, DR650, ZX10R C1H, ZXR 750 L1, ZXR 750 L3, '99 ZX7R P4, KTM 300 EXC, ZX-9R E1, TDM850 |
The last post was made 17 years, 145 days ago. Instead of replying here, would creating a new thread be more useful? |
