sva speedo q
chillpill
PostPosted: 15:44 - 12 Sep 2008    Post subject: sva speedo q Reply with quote
rite ive got my sva test on monday for my nsr and i need a mph speedo for it because mine kmph
i did have a digital speedo on it but some tosser nicked that today so im fucked
when i asked this q ages ago some people suggested just tippexing the mph on the speedo face but i was wondering wether they would pass this as its a bodge job pretty much
any help will be muchly aprreciated Very Happy
Peter3hg
PostPosted: 15:55 - 12 Sep 2008    Post subject: Reply with quote
You may get away with sticking a bicycle computer on it. The kind you get for a tenner from Halfords. Someone will have to confirm if this is sufficient however.
chillpill
PostPosted: 15:59 - 12 Sep 2008    Post subject: Reply with quote
yeah thats what i had before but some pikey nicked it Sad
i mite have to do that pete but the cheap ones are so anoying to fit because ill have to fabricate some sort of space to hold it close to the wheel, the gap between the spokes and forks is too big Mad
cheers for the input though mate Thumbs Up
PostPosted: 16:08 - 12 Sep 2008    Post subject: Reply with quote
For SVA the speedo must show mph and kmh (either all the time or at the press of a button switch between them). Suspect it also inists on a mile counter.
For SVA I would be surprised if you could get away with a digital bicycle speedo.
Kal
PostPosted: 16:12 - 12 Sep 2008    Post subject: Reply with quote
I bought a conversion unit for something like 15quid from Hein Gericke which included stickers to go over the kph
I thought KPH wasn't a requirement for older machinery, just had to have a reading in mph?
"A speedometer, or facing plate must be fitted that indicates ‘miles per hour’, in uniform intervals not exceeding 20 mph, up to the maximum design speed of the vehicle and which indicates the speed within the required limits of the actual speed.
A UK approved speedometer may have to be fitted from a UK model. It may be wise to have standard wheels/tyres fitted to the car as ‘after market’/non standard wheels/tyres may result in the speedometer accuracy being outside the acceptable limit. "
Kal...
chillpill
PostPosted: 16:23 - 12 Sep 2008    Post subject: Reply with quote
so you need kph and mph !!! alot of new bikes dont even do that Confused
are you sure about the mile counter becasue alot of scooters sold in this country have the odometer in kph
im hoping if i buy a converter to go on the cable they would pass it, hopefully they wont too strict
cheers for all the replies Very Happy
chillpill
PostPosted: 16:25 - 12 Sep 2008    Post subject: Reply with quote
kal where did you get that quote from ? a link would be loveley Very Happy
PostPosted: 16:32 - 12 Sep 2008    Post subject: Reply with quote
SVA is pretty strict on some of the rules, and the rules do say you need both mph and kmh markings (or one and being able to switch to the other, to cover digital speedos).
Fairly sure that the speedo face for a normal speedo must show both. You cannot just have a sticker on the speedo glass.
Not sure about the odo in kph. That might be OK. However not sure that one that can be easily reset (like a bicycle speedo) would be allowed.
You are right that some bikes have mph only speedos and in theory these should not have been allowed a UK registration. In practice once registered they are are going to get away with it.
chillpill
PostPosted: 16:43 - 12 Sep 2008    Post subject: Reply with quote
sounds like a dumb rule tbh, why would anyone need kph to drive in this country ?
sounds like im heading for a massive fail of this test then Sad
PostPosted: 16:47 - 12 Sep 2008    Post subject: Reply with quote
Think it is that kmh is required by European type approval, etc, and the UK requires mph in addition. Without the kmh then it doesn't pass the European rules.
And nothing to stop you riding a 125 to other countries that use kmh.
Have you bought the SVA manual to tell you what they check? There are all sorts of things, most of which you shouldn't have a problem with but some you might.
chillpill
PostPosted: 17:15 - 12 Sep 2008    Post subject: Reply with quote
no , didnt know there was one Confused
ive just been going on what ive read from there website
https://www.direct.gov.uk/en/Motoring/BuyingAndSellingAVehicle/ImportingAndExportingAVehicle/DG_4022106
from looking at it seem like i will only have a problem with the speedo, if i get a digital bike one and fit it alongside the existing one that should be fine right ?
cheers again for the help Thumbs Up
PostPosted: 17:39 - 12 Sep 2008    Post subject: Reply with quote
There is a full manual and they do charge for it (£30 it seems).
Bit more detail here:-
https://www.vosa.gov.uk/vosacorp/repository/Motorcycle%20SVA%20Guide.pdf
Page 5 mentions the inspection manual.
I honestly do not know about the push bike speedo, but it would surprise me if it is acceptable for SVA.
chillpill
PostPosted: 17:50 - 12 Sep 2008    Post subject: Reply with quote
cheers for the manual was a helpfull read Thumbs Up
i think im going to get a kph to mph converter and just try my luck Confused
cheers to all that replied
and
PostPosted: 18:48 - 12 Sep 2008    Post subject: Reply with quote
Kal
PostPosted: 00:36 - 13 Sep 2008    Post subject: Reply with quote
First part of the quote is out of the SVA manual, the second is a car importers interpretation. Pulled it as an average from sources on a google search.
SVA Manual Draft
Kal...
chillpill
PostPosted: 08:13 - 13 Sep 2008    Post subject: Reply with quote
cheers kal that link was really usefull
found this on there under reasons for speedo fail : which is less than the true speed of the vehicle
• in excess of the true speed plus the permitted
tolerance.
it was just those two so happy days Razz
Kal
PostPosted: 11:54 - 15 Sep 2008    Post subject: Reply with quote
How did your SVA go?
Kal...
chillpill
PostPosted: 10:53 - 16 Sep 2008    Post subject: Reply with quote
yeah mate it went sweet, cheers for askin Thumbs Up
just bought a motrax converter in the end and it worked a treat, the tester missed out a load of the things mentioned in the manual like sound level and a few others Confused
i would of been gutted if the bike failed on the speedo, the speedos ment to go up to the maximum speed but because it wsa a kmph it goes up to 200mph and in the application form i said the bikes restricted with a topspeed of 70mph Very Happy
i think he might of just gone easy on me because i had a little chat and a laugh with himas he did the test
driving down the dvla later to get registration sorted Razz
Kal
PostPosted: 11:11 - 16 Sep 2008    Post subject: Reply with quote
Excellent, thats what we like. The speedo should say at least the speed the vehicle is capable of - so most speedos are wildly optomistic on the righthandside anyway. Laughing
Have you got proof of age for it from Honda? If you haven't could be worth investing £30 to avoid getting a q plate.
Kal...
chillpill
PostPosted: 17:54 - 16 Sep 2008    Post subject: Reply with quote
yeah i got a dating letter off them, i needed proof of age to register it, its a 2001 bike so the last of the nsr's in production Very Happy
took it too the dvla today to get registered, 48-72 hours and ill be back on the road Twisted Evil
The last post was made 18 years, 33 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 106.96 Kb
