| big d |
 big d Nitrous Nuisance
| chris-red |
| big d |
| Nufkamp |
 Nufkamp Traffic Copper
 Posted: 11:47 - 12 Sep 2008 Post subject: |
Why FAT32? It's so outdated and inefficient. ____________________ As seen on Google Street View https://tinyurl.com/yfdvojc |
| Luke_Retrofly |
 Luke_Retrofly Silly Lesbian
 Posted: 11:51 - 12 Sep 2008 Post subject: |
Use NTFS file formatting, FAT32 has problems with large files and is slower , unless its a MAC? I think they have problems with NTFS, but I may be wrong.
Luke |
| chris-red |
| big d |
| Nufkamp |
 Posted: 16:19 - 12 Sep 2008 Post subject: |
Doh! Just remembered there is a 32 gig size limit for FAT32, so I guess your only option is to use Partition Magic and create a partiton no bigger than this. You should then have the option to format to FAT32 from within Windows. ____________________ As seen on Google Street View https://tinyurl.com/yfdvojc |
| Fortuna |
 Fortuna World Chat Champion
| Nufkamp |
 Posted: 04:05 - 13 Sep 2008 Post subject: |
Sadly, percentage-wise, I think you'll find it does. All camera, printer, etc manufactureres assume its going on a Windowz box so all drivers and support apps are in this flavour. As to what filesystem the PS3 uses I have no idea, but the OP is of the impression that FAT32 will suit his needs, a filesystem introduced with, erm, Windows.  ____________________ As seen on Google Street View https://tinyurl.com/yfdvojc |
| Colin Edwards |
 Colin Edwards Brolly Dolly
| Colin Edwards |
| Fortuna |
 Posted: 22:44 - 14 Sep 2008 Post subject: |
| Nufkamp wrote: |
This is by Microsofts design, and only applies to windows. This limitation is removed using other OS's or third party formatters.
| Nufkamp wrote: | Sadly, percentage-wise, I think you'll find it does. All camera, printer, etc manufactureres assume its going on a Windowz box so all drivers and support apps are in this flavour. As to what filesystem the PS3 uses I have no idea, but the OP is of the impression that FAT32 will suit his needs, a filesystem introduced with, erm, Windows.  |
Most removable media has FAT as the filesystem, this includes SD and compactflash to name a few. The drivers and apps don't come into it as they are OS specific.
From wiki:
| Quote: |
File system
Like other flash card technologies, most SD cards ship preformatted with the FAT or FAT 32 file system. The ubiquity of this file system allows the card to be accessed on virtually any host device with an SD reader. Also, standard FAT maintenance utilities (e.g. ScanDisk) can be used to repair or retrieve corrupted data. However, because the card appears as a removable hard drive to the host system, the card can be reformatted to any file system supported by the operating system.
Windows 95b was the first to be released with FAT32 but was certainly not the first to be able to utilise it and make use of it.
To answer the OP.
The filesystem used on an external hard drive for the PS3 is FAT32.(NTFS will not work).
I think you have to add a couple of folders as well, been a while since I did it. |
| neil. |
 neil. World Chat Champion
| Fortuna |
| Neorion |
 Neorion World Chat Champion
 Posted: 16:03 - 18 Sep 2008 Post subject: |
not sure if this is still active I was just having a read...
From looking round the web the PS3 uses an encrypted file system as you can place any unformatted drive into the unit and it will format it in what seems to be a linux style setup
The command it appears to run is this livecd / # mkfs.ext3 -j /dev/sda1
this is what the linux live cd uses when you install it to a ps3. The Hypervisor sony use to mask the actual hardware from the linux user seems to pass commands from the linux install to the hardware and vice versa. We found this out at work as we wanted to buy about 70 Ps3's and use them for a Citrix dev farm, no such luck!
The web bods are saying that sony wont tell anyone what it uses as rightly so its the first step to cracking the file system and therefore cracking the Ps3.
the same thing happened when the XBOXMOD team cracked the 360 I think they used a game save from star wars KOTOR to access the code and create the firmware flash for the dvd drive (or so I've read)
Maybe slighlty off topic but interesting to some
 ____________________ VFR FI 2000- Shiney Red Thing
"some things man was never meant to know, for everything else there's Google" |
The last post was made 17 years, 361 days ago. Instead of replying here, would creating a new thread be more useful? |
