Anyone use SpeedFan?
WildGoose
White Van Man
PostPosted: 15:29 - 13 Sep 2008    Post subject: Anyone use SpeedFan? Reply with quote
Neat little program, but hoping someone might be able to enlighten me as to how to get more meaning out of the temperatures..
I've managed to download a user made file that matches my motherboard, so the temperatures it details are as follows:
Arrow CPU
Arrow NB (northbridge I assume)
Both of these have the same temp chip IT8712F
Arrow PCB (no idea) - AMD K8 chip. What is this temp referring to?
Local Temp
Remote Temp
Arrow
MAX6648 Chip, no idea what these temps mean.
Arrow HD0 (assume this is HD, as it makes reference to 120GB).
:arrow:GPU (Geforce Video Card)
:arrow:Core (nVidia Video Card)
Arrow Ambient (nVidia Video Card)
Assume these are all to do with the G-card, but only core and ambient read a temp, GPU reads 0.
I'm not into fiddling with fan speeds or bus speeds, or any of its other features, just want to know what temps im actually looking at, and what I need to be concerned with.
Any pointers useful, ta.
WildGoose
White Van Man
PostPosted: 15:30 - 13 Sep 2008    Post subject: Reply with quote
Oh, also the only FAN rpm reading ive got is the CPU fan.
I have 4 case fans, and a PSU fan, but I think most of the case fans are powered from molex connectors, which I assume means I can't get a speed reading?
Any idea how to get the PSU fan to give a reading?
Finglonga
PostPosted: 16:58 - 13 Sep 2008    Post subject: Reply with quote
PCB sounds like your mother board.
HD is the hard drive temp, some have fans to keep them cool. Mine has one fan between 4 Hard drives.
I prefer Everest Ultimate for temperatures, less intrusive if your not changing fan speeds.
Andy Sez....
F.Y.Y.F.F.
Seb
PostPosted: 22:07 - 13 Sep 2008    Post subject: Re: Anyone use SpeedFan? Reply with quote
That'll be the temperature on the pcb underneath your cpu most likely.
WildGoose wrote:
Local Temp
Remote Temp
Arrow
That Max chip is a dedicated temperature monitor, local temp is the temperature on the chip itself, remote could be anything it's connected to. Your mainboard manual might have more on that.
the split core and gpu is mainly in mind of older cards with seperate 2d and 3d chips.
2010 Triumph 1050 Sprint ST
Fnatic
PostPosted: 12:14 - 14 Sep 2008    Post subject: Reply with quote
Mine says my Q6600 is at 18 degrees most of the time Confused
Must be the watercooling xD
divuk83
PostPosted: 22:59 - 15 Sep 2008    Post subject: Reply with quote
Try core temp.
https://www.majorgeeks.com/Core_Temp_d5665.html
Its not running at 18 degrees, I'm guessing the T-Junction is set wrong. Should be 100 for intel C2D/Quad CPU's. Dowload Core Temp and I bet its higher than that. Updating the bios on you motherboard will often make for more accurate temp readings as newer versions often correct inacuracies.
Dave
PostPosted: 08:23 - 16 Sep 2008    Post subject: Reply with quote
divuk83 wrote:
Interesting. That has given far more realistic values than SpeedFan (which seems to insist that one of the cores is running at about 71 degrees).
All theb est
divuk83
PostPosted: 10:04 - 16 Sep 2008    Post subject: Reply with quote
What CPU is it Keith? Is it an AMD as it looks a bit warm to be a C2D intel?
Dave
PostPosted: 10:36 - 16 Sep 2008    Post subject: Reply with quote
It is an AMD Athlon 64 X2 6400+ (Windsor). The software you posted is giving the temps as 40 degrees, varying a degree or so, for both cores.
Speed fan gives one at about 40 while the other is showing up at about 71 (77 at this moment).
veeeffarr
PostPosted: 10:48 - 16 Sep 2008    Post subject: Reply with quote
CoreTemp is the best, speedfan can be 15 degrees out in Vista as it used to have the wrong Tjunction.
Intel TAT is supposed to be pretty good, Core2Duo's run #THERMTRIP anyway so I couldn't give a shit about temp monitoring, I'll leave that to the PC mollycoddler brigade.
T
Stevie GooGs
PostPosted: 11:15 - 16 Sep 2008    Post subject: Reply with quote
Here is a screen dump of mine
Finglonga
PostPosted: 12:32 - 16 Sep 2008    Post subject: Reply with quote
Exactly the same temperature readings as Everest . . .
https://img.photobucket.com/albums/v112/finglonga/Temperature.jpg
Andy Sez....
F.Y.Y.F.F.
WildGoose
White Van Man
PostPosted: 20:15 - 16 Sep 2008    Post subject: Reply with quote
Thanks folks.
I'm not a mollycoddler or overclocker, this all stems from this once quick PC running like a bag of slow shite, was wondering if temps were owt to do with it.
Also bought a cheap socket 939 dual core processor a while ago(thinking being before all 939 CPU's disappear) and wanted to know the current temps of my single core athlon XP 3700 to compare to the running temps of the new chip, just as a point of interest.
If I ever get round to installing it Rolling Eyes
The last post was made 18 years, 1 day ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.17 Sec - Server Load: 1.09 - MySQL Queries: 13 - Page Size: 80.26 Kb
