choke problem HELP
ljwalker
PostPosted: 14:08 - 15 Sep 2008    Post subject: choke problem HELP Reply with quote
Hi,
I have a rieju rs2 matrix 50 cc i have a slight problem when im going along it starts juddering like there is no fuel but as soon as i put my choke on its fine.
i have changed the spark plug and looked at the carb looks fine and clean.
i want to get this sorted asap so any help or guidence would be very much appreciated.
Many Thanks Thumbs Up
wardy-wardy-wardy
PostPosted: 14:43 - 15 Sep 2008    Post subject: Reply with quote
if it conks out when you close the choke then your engine is probibly a bit bunged up - especialy if its a 2 - stroke because of the oil . if bike has been stood for a bit petrol evaperates leaving oil in engine. clean the engine just try with a small brush with petrol on if not strip it and clean it.
wanted 125 or 110 dirt or pit or offroad
pm me if you have or you no if anyone has 1
garyd
PostPosted: 16:33 - 15 Sep 2008    Post subject: Reply with quote
Wardy, his bike goes FINE when he puts the choke on ,that indicates an air leak as it then overcomes the excess air,look for split carb boot ,no air filter loose clips etc,etc,before having to strip the carb for a blocked jet Thumbs Up
CRF230 all you need
wardy-wardy-wardy
PostPosted: 16:37 - 15 Sep 2008    Post subject: Reply with quote
what do you mean by on - do you mean its closed as in lets small amount of air though or open as in lets more air though?
garyd
PostPosted: 16:57 - 15 Sep 2008    Post subject: Reply with quote
On is ON "needs the choke ON in a morning Wardy"???????????????what would yu think i was telling you Shocked
CRF230 all you need
wardy-wardy-wardy
PostPosted: 17:21 - 15 Sep 2008    Post subject: Reply with quote
im mean what do you class as on - were it is closed or open ?
Carbon-Me1
PostPosted: 17:37 - 15 Sep 2008    Post subject: Reply with quote
I have the same bike as you.
Between the carb and air box there is a rubber ring which connects the two. On side is secured by a jubilee clip and the other side has nothing to stop its from slipping out. This is probably your problem its may have come out slighty. Take off your fuel tank and then push it back into place if it is out.
Hope that helps
Current: [MotorHispania RX50] [Blata 2.5] [Gilera DNA 125]
Sold: [Rieju RS2 Matrix 50] [Derbi GPR Nude 50]
Cigaro
Technically it's closed I suppose.
ljwalker
PostPosted: 19:22 - 15 Sep 2008    Post subject: Reply with quote
ok thanks everyone for your help tommorrow i will have a little look.
thanks again Thumbs Up
ljwalker
PostPosted: 14:33 - 17 Sep 2008    Post subject: Reply with quote
whats the carb boot ? Thumbs Up
PostPosted: 15:53 - 17 Sep 2008    Post subject: Reply with quote
You don't half talk some bollocks wardy.
Stay out of the workshop unless you're asking a question! Twisted Evil
Hutchysrs50
PostPosted: 18:13 - 17 Sep 2008    Post subject: Reply with quote
hey,
is the airbox/intake Stock or have you put a sports one on?
have you adjusted the air screw to help it flow better?
Any other Modifications onit?
ljwalker
PostPosted: 18:21 - 17 Sep 2008    Post subject: Reply with quote
no it has no modifications on accept front and rear sprocket.
but i have just fixed the problem it was the bit betwenn the carb and the air box was loose.
many thanks to everyone for your help much appreciated Thumbs Up
Carbon-Me1
PostPosted: 18:56 - 17 Sep 2008    Post subject: Reply with quote
Very Happy thought it might be, crappy design. Happens alot to me on my rieju and i just have to pull over and fit it in again properly.
garyd
PostPosted: 18:33 - 18 Sep 2008    Post subject: Reply with quote
So the Gazster was spot on and Wardy (as Marjay correctly put it )was spouting bollax Laughing Laughing
CRF230 all you need
The last post was made 18 years, 18 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.85 - MySQL Queries: 13 - Page Size: 84.37 Kb
