| teuma86 |
 teuma86 Scooby Slapper
| MarJay |
 MarJay But it's British!
| teuma86 |
| MarJay |
 Posted: 11:02 - 16 Sep 2008 Post subject: |
Generally 2 ways for the gear change to attach. Either the lever attaches directly to the shaft from the gearbox or the lever attaches near the foot peg and then has a linkage to go to the shaft from the gearbox.
In the first case you can probably take the gear change lever off and put it back on in a slightly different position. Normally held on with a pinch bolt, so remove the bolt, slide the lever off, move it round slightly and put it back on, put the pinch bolt back in and tighten it up. Normally there is a small dot punched on the shaft to line up with the split in the lever for setting it up as standard.
In the 2nd case it is probably easier. Normally there is a shaft from the lever to the shaft coming from the gearbox. You can adjst the lever position by rotating the shaft, as it will have a thread on either end, one of which will be reversed. As you rotate it the shaft moves on the threads making the total length effectively longer or shoter. Probably a locknut (or maybe 2) on the shaft. Slacken the lock nut/s (note that one is probably on a reverse thread) then you should be able to rotate the shaft. Once adjusted toghten the lock nuts.
That said you are buying it from a dealer. I would expect them to adjust this for you. Only takes a few minutes for them.
| teuma86 |
The last post was made 18 years, 37 days ago. Instead of replying here, would creating a new thread be more useful? |
