upjetting
leigh3292
PostPosted: 15:12 - 17 Sep 2008    Post subject: upjetting Reply with quote
ive got a gilera smt 50 , i want to upjet it, wat wud the consequences be if i upjet it and also if i get a performance exhaust on it ?
TUG
PostPosted: 15:20 - 17 Sep 2008    Post subject: Reply with quote
It would use more petrol and take you ages to jet it correctly, you'd probably fuck its performance up. Save you time an effort for a bigger bike or car.
Ow btw we have a workshop section too, where this kind of belongs to be.
Wolf
Haz ER-5, innit!
leigh3292
PostPosted: 15:24 - 17 Sep 2008    Post subject: Reply with quote
okay lol and wat cud i do to make it faster or isnt it worth it on a 50
PostPosted: 15:26 - 17 Sep 2008    Post subject: Re: upjetting Reply with quote
So...
You want to 'upjet' it... but you have no idea what it will do to the bike?
The term is 'rejet' and you only do it in combination with other modifications. And we have a Workshop section for questions like that.
Thanks!
leigh3292
PostPosted: 15:28 - 17 Sep 2008    Post subject: Reply with quote
i no but cant find that workshop thing!
so wat could i do tell me wat i can do to it ?
PostPosted: 15:39 - 17 Sep 2008    Post subject: Reply with quote
You my lad, are the future of this country so you'd better sort your life out.
You'll have to pay for my pension, don't you know?
leigh3292
PostPosted: 15:56 - 17 Sep 2008    Post subject: Reply with quote
:S wat are u on about thats nothing to do with wat i asked lol
PostPosted: 15:59 - 17 Sep 2008    Post subject: Reply with quote
I'm 'on' Telling you that you need to ask in the workshop. And write in English if you can.
leigh3292
PostPosted: 16:01 - 17 Sep 2008    Post subject: Reply with quote
I CANT find the workshop tho and iam writing in english , i only wanted to find out stuff maybe il go somewhere else who helps and are polite Cool
skinny
PostPosted: 16:04 - 17 Sep 2008    Post subject: Reply with quote
You should ask your long lost relation speedfight2 50cc https://www.bikechatforums.com/viewtopic.php?t=156298
oops I did it again....
Jefr0
PostPosted: 16:07 - 17 Sep 2008    Post subject: Reply with quote
You sir are an idiot.
If your bike is standard then it is set up correctly. If you upjet it then you will be running it rich. Only when you add parts too it, like a sports exhaust then you should upjet etc etc. But I bet it has gone in one ear and out the other and you'll ask again you numpty
Rides: Honda XR 125 ('03) Honda CBR 600F ('91), Ducati 916 Biposto ('95)
PostPosted: 16:12 - 17 Sep 2008    Post subject: Reply with quote
I am being perfectly polite, and my picture I posted has directions to the workshop.
Ok, because you cannot understand simple instructions like 'Ask in the workshop section' then I will answer your question.
Rejetting is done when other modifications are done to the engine that make the fuelling either richer than standard or leaner than standard. Usually its leaner.
Fitting a sports exhaust, derestricting, fitting a 'performance' air filter, tuning and other modifications usually make the mixture leaner. This means you need a bigger jet.
When this is done, it usually needs setting up on a dynamometer (which is like a rolling road) Or, it needs setting up using frequent plug chops. Plug chops work, but IMO they can be a bit dangerous because you can run the bike too lean and heat seize. If this happens when you are riding you need to be quick on your clutch hand otherwise you'll be spat off into the street.
A plug chop is a method of examining the mixture of a bike. It involves riding the bike a bit, and then removing the spark plug and examining it. If it is black and oily you are running too rich and need to lower the needle or swap the main jet for a smaller one. If it is white in colour then it is running too lean and you need to raise the needle or increase the size of the main jet. You want to aim for the plugs to be a tan colour. This cannot easily be done by an amateur though, and it won't get you that much more performance on a 50cc. If it isn't done properly or not done at all, then you could seize the bike.
My personal opinion on this is that you should wait until you are 17 and buy a 125. Or you can do your test.
This still does not mean that you asked a proper question, or asked it in the correct section or that you are actually speaking English.
TXT Spk duz nt count az nglish dunthca know innit blud?
Ariel Badger
PostPosted: 16:13 - 17 Sep 2008    Post subject: Reply with quote
leigh3292 wrote:
tho and iam writing in english , Cool
Mr. Green Middle Finger
leigh3292
PostPosted: 16:16 - 17 Sep 2008    Post subject: Reply with quote
cool people Thumbs Up
and i am getting a performance exhaust thank you very much
Fnatic
PostPosted: 17:00 - 17 Sep 2008    Post subject: Reply with quote
Right get a performance exhaust.
Then see how it performs. Then buy jets in ranges of 5-10.
For example you may have a 70 in there now....
Buy 80, 90, 100
Try them all and then try 95 if 90 isn't right and 100 is boggy.
It's a guessing game.
The jet is the valve type thing that allows petrol through to the carb.
Too small and underpowered, too big and boggy performance.
*I Think* Thumbs Up
leigh3292
PostPosted: 17:03 - 17 Sep 2008    Post subject: Reply with quote
okay thanks for the advice
bazza
PostPosted: 21:39 - 17 Sep 2008    Post subject: Reply with quote
https://teacher.nsrl.rochester.edu/phy_labs/Measure_g/Measure_g01.gif(2.1)
where G is Newton's gravitational constant, M is the mass of the earth and r is the distance to the center of the earth. Inasmuch as the radius of the earth is very large compared to laboratory dimensions, an object near the surface of the earth, r is approximately constant and equal to the radius of the earth, . Thus an object near the surface of the earth will experience a nearly constant acceleration,
https://teacher.nsrl.rochester.edu/phy_labs/Measure_g/Measure_g04.gif(2.2)
https://www.dslruser.co.uk/cpg1410/albums/userpics/11563/Beachy-Head-Sunrise-2.jpg
Endless Nameless
PostPosted: 21:58 - 17 Sep 2008    Post subject: Reply with quote
Bazza, see my reply to the OP's thread in workshop Razz
A2 passed 22/07/08; restriction up 22/07/10 (just so I don't forget)
'79 Suzuki GS550E. Yes, that's a GS550, not a GS500.
Supersports "In a video editing competition I'd kick your sorry ass"
bazza
PostPosted: 22:11 - 17 Sep 2008    Post subject: Reply with quote
Heh.
Don't cry.
Don't raise your eye.
It's only teenage wasteland.
Edit: Practical guide to ped speed boosting: https://www.youtube.com/watch?v=HcyuJTgKjZc
Ariel Badger
PostPosted: 22:15 - 17 Sep 2008    Post subject: Reply with quote
Buy 80, 90, 100
Run it hard and lean your pistom will melt BTW.
*I Think* Thumbs Up
rotax81
PostPosted: 22:47 - 17 Sep 2008    Post subject: Reply with quote
ffs!!!
he only asked a question, not everyone knows everything like you do lol
ZX636C6F road. ZX636C1H track. ZX7R redundant. ZX0.5R minimoto as ornament.
Audi A4 Avant 1.9TDi and VW Transporter 2.5TDi 888 Special (no mot and tax lol)
rotax81
PostPosted: 22:55 - 17 Sep 2008    Post subject: Reply with quote
Buy 80, 90, 100
*I Think* Thumbs Up
there is your near on correct answer
a good starting point is to leave as is until you mod it.
fit your exhaust.
find your carb size in mm's.
multiply it by 5 and that will be slightly over the jet size you will need.
i.e. 18mm carb x 5 = 90 jet.... i would fit 85 and it will be very close.
before anyone jumps on me i have used that method since i was 16 in 1977 lol.
including setting up my karts i used to race Thumbs Up
PostPosted: 05:29 - 18 Sep 2008    Post subject: Reply with quote
ffs!!!
TBF after not understanding the workshop section I feel he earnt that title.
Jefr0
PostPosted: 08:47 - 18 Sep 2008    Post subject: Reply with quote
ffs!!!
Looking back it seems a bit harsh but I just didn't think he was listening to people and he couldn't find the workshop Neutral
rotax81
PostPosted: 11:08 - 18 Sep 2008    Post subject: Reply with quote
perhaps he is deaf AND blind Laughing
The last post was made 17 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 133.01 Kb
